Guess this part!
Discussion in '1st Gen Tundras (2000-2006)' started by shet4breinz, Aug 20, 2020.
  1. Aug 20, 2020 at 5:17 PM
    shet4breinz
    shet4breinz [OP] New Member
    I found this where my 05 toyota tundra is typically parked. Nothing else I own is this rusted. This is one of the unimportant bolts, right? There is a serial number on the grommet looking thing, but it didnt turn up anything.
    48817-00010
    I've been surfing through too many russian websites with that serial number. Thought it was worth a question.
  2. Aug 20, 2020 at 5:19 PM
    Almost looks like a bumpstop???
  3. Aug 20, 2020 at 5:19 PM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Strut top bushing is what it looks like, check the tops of your shock towers
    GeezePlease and Tundyfundy like this.
  4. Aug 20, 2020 at 5:20 PM
    ^^^ this is what I believe it is too
  5. Aug 20, 2020 at 5:25 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Suspension Stabilizer Bar Link Bushing - Toyota (48817-0C010)
  6. Aug 20, 2020 at 5:26 PM
    Or rear shock mount.......
  7. Aug 20, 2020 at 5:52 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I agree with this post. Typically the second set of numbers have an alphabet in there instead of all ten digits being numbers.
  8. Aug 20, 2020 at 5:56 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Dude! Well done! I think I'm just going to have all my internet searches run through you.
  9. Aug 26, 2020 at 5:12 AM
    shet4breinz
    Thank you, golden hands! the road is a little safer today...
  10. Aug 26, 2020 at 11:00 AM
    bmf4069 Yup, that's car parts in a dishwasher
    Golden hands. :rofl:
  11. Aug 26, 2020 at 11:14 AM
    AZTundra
    Paul
    Phoenix, AZ
    Broken shock mou n t?
  12. Aug 29, 2020 at 6:36 AM
    04TundraTRD
    04TundraTRD Once upon a time....
    Neil
    Kentucky, near Louisville
    2004 Tundra TRD 4WD AC
    Bilstein 5100's on all four corners, Setting 4 on the fronts, 1" Front Diff Drop Kit, Suspensionmaxx Front Sway bar end links, 1" lift shackles out back, 1.5" wheel spacers all around, 285/75R16 BFG AT TA/KO2's, Front Brush Guard with 20" LED light bar, Kool Vue Dodge style tow mirrors, Yellow Box Speedo Corrrecter by Yellr, Volant CAI, Banks Monster 3” Catback Exhaust, LED's on the interior, LED Headlamps and LED Back Up Bulbs
    This is the right one.
  13. Aug 29, 2020 at 6:41 AM
    Fred
    Hand Protectors
    You are welcome breinz. Sometimes I am full of shet like you, but I’m glad you feel safer. In return for me helping you, might I ask you kindly plant a tree today to facilitate Wurrld Peas.
    bmf4069 and 2truckornot2truck like this.
  14. Aug 29, 2020 at 7:27 AM
    omgboost
    East Coast
    I hate trees because birds always be chilling there and sheting all over my car.
  15. Aug 29, 2020 at 7:34 AM
    Fred
    Hand Protectors
    Its a sign. The birds need their ground space so that the ants can enjoy the droppings, and the birds drop down and enjoy the ants. You are disturbing Earths inner Circle of Chi. Please park in the direct sunlight to help keep the Earth warm.
    bmf4069 and bassman417 like this.
  16. Aug 30, 2020 at 3:28 PM
    shet4breinz
    guys I got a new part but, I'm seeing an issue..
    I tried my ole oil pipeliner trick of trying to use a strap to ratchet it into place, but didnt have the blow torch on at the moment... any doctors in the house?
  17. Aug 30, 2020 at 3:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Are you able to put a jack under the Lower Control Arm to use the vehicles weight to push the sway bar link upward? That should also make the passenger side droop a little pulling the sway bar downward. Lifting the passenger rear may have a similar compression of the opposite corner (front driver) I think. You may have to play with it a little. A part of my mind wonders if maybe the sway bar is bent. Driving the front drivers wheel onto a flat 2x4 may work too.
  18. Aug 30, 2020 at 5:32 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Maybe loosening up the other side will allow you to get that started. Then you can tighten them down a little at a time.
  19. Sep 1, 2020 at 9:26 AM
    shet4breinz
    Good idea, sir... I backed it up the hill and slipped it on! We'll give er a go... yahoo(?)
    Wynnded[QUOTED] likes this.
  20. Sep 1, 2020 at 9:40 AM
    Haslefre
    Haslefre New Member
    TN
    You need to get some rust prevention done under there... I guess it wouldn't be prevention anymore, rather mitigation.
    Warden3564 likes this.
