Largest tire you can run stock for all generations
Discussion in 'Wheels & Tires' started by T-Rex266, Jan 9, 2017.
  1. Feb 26, 2017 at 8:06 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    I've tried to use it and maybe I'm not searching the key words or phrases. Keeps drawing a blank on mine. Or maybe I'm just expecting the genie to come out of a bottle do all the work for me;) this would constitute laziness and generally a non-DIY'er I suppose. Don't tease me for it!! I'm just getting in to this game
    Tundra2, 040Tundra, Sunnier and 2 others like this.
  2. Feb 26, 2017 at 8:16 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Your circle and arrow reminds me of this guy. Maybe it's a sign I'm using too many memes in my life LOL!
  3. Feb 26, 2017 at 8:16 AM
    T-Rex266 [OP] Elon approved Staff Member
    That meme life :cool:
    Tundra2 likes this.
  4. Feb 26, 2017 at 8:18 AM
    TXMiamiFan
    Jose
    You should get that tatted on your abs like Tupac. "The Meme Life".
  5. Mar 13, 2017 at 9:17 AM
    Reel Irie
    Reel Irie New Member
    FLA
    2017 Tundra CrewMax SR5 2wd
    275/60 20 Will fit according this thread, anyone want to reassure me :)
    completely stock 2017 2wd Crewmax
    20x9.5 +30mm wheel
    Sunnier likes this.
  6. Mar 18, 2017 at 1:10 PM
    Conspiro-Agnew
    Conspiro-Agnew New Member
    JBER, AK
    2017 Quicksand SR5 TRD Off Road Tundra
    Thanks for this post, OP and everybody else contributing. Again, this place is perfect for answering all my newbie Tundra questions before I even ask them, and a horrible place for my wallet. Cheers!
    kodyquist21 and Sunnier like this.
  7. Apr 2, 2017 at 4:35 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    a 295 55 20 tire (8/10" taller and 8/10" wider than a 275 55 20) on a 20x9 +50mm offset wheel will fit:
    • on a 3rd gen with no lift (minor trimming, remove little front mud flaps)
    • on a 3rd gen with 1.57" lift (no trimming, remove little front mud flaps)
  8. Aug 4, 2017 at 4:18 PM
    Toyota10s
    Toyota10s New Member
    Chace
    West Coast
    2017 Toyota Crewmax limited Tundra
    Bone stock.
    I'll chime in.... :)
    I'm a "stock" vehicle enthusiast (insert the boooos and hisses here) and I'm still trying to find and figure out what TRD wheel options are available for 3rd Gen Tundra, specific to me, the 2017 Tundra.
    After looking at the millions of pics of aftermarket wheel and tire options, the stock wheels look too small, even on the TRD Pro. I think I'll have to get the 20" since that's the only other stock option.
    So assuming for the 20" TRD wheels, what's the biggest "summer tire" size I can put on it.? Remember, I like stock so I'm not looking for the loudest mud terrain tires available. If racing tires were legal, I'd get those :thumbsup:
  9. Aug 4, 2017 at 4:26 PM
    Toyota10s
    Chace
    West Coast
    Bone stock.
    Ok, maybe this answers my question above about stock tires on 3rd Gen?
    In case it makes a difference, mine is 4x4 but not looking for mudders or similar, just summer or all season, if they're still called that. Maybe tires sizes don't matter if there are 4x4 or not, but I would have to think with all that extra grippy rubber v. a summer tire, there is a difference since mud or winter tires are bigger and could hit the wheel wells.
    Thanks.
    Sunnier likes this.
  10. Aug 11, 2017 at 9:54 AM
    bpreece
    bpreece New Member
    BroManDudeDog
    2017 Tundra Crew Max TRD
    Bilstein 5100
    Which mods? Mud flaps? or CMC?
  11. Aug 12, 2017 at 8:01 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Brett, back when I posted that I had the 285/75-18's. Currently have 37's on same 2-1/4" lift. No CMC, but front bumper mods etc. Key is the OEM wheel offset that makes that large tire work on a small lift. Check my build thread in my signature below. Good luck with all.
  12. Aug 15, 2017 at 8:02 PM
    Lo1dakota
    Lo1dakota Ermagherd
    Brandon
    Washington
    2017 Inferno CM TRD Off-Road
    18" TRD Wheels - BFG 35" Tires - OME Lift - N Fab Steps - TRD Sway Bar
    Ok. Answer me this. I have an OME 3/1 I believe (dealer added) TRD 18" wheels. 35-12.50 BGG tires. I have no rubbing. I'll attach photos for someone to tell me if the front has been modified to accommodate these tires. IMG_2314.jpg IMG_2315.jpg IMG_2316.jpg
    PermaFrostTRD, Sunnier and bpreece like this.
  13. Aug 15, 2017 at 8:05 PM
    bpreece
    bpreece New Member
    BroManDudeDog
    Bilstein 5100
    Would you post more pics? Side view from front and back?
    Lo1dakota[QUOTED] likes this.
  14. Aug 15, 2017 at 8:09 PM
    Lo1dakota
    Lo1dakota Ermagherd
    Brandon
    Washington
    Like that?
  15. Aug 15, 2017 at 8:29 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I figured this might be a useful addition to this thread... maybe not. We will see.
    Neo, Yoda-Tundra and Sunnier like this.
  16. Sep 12, 2017 at 11:57 PM
    Sunnier
    Sunny
    San Diego, CA
    THIS IS WHAT we need, all of us new wanna-be modders. Oh, and pics for each!
    So... maybe I'm missing it. Looking for a thread that has wheel/ tire combos actually installed, *without lifting or cutting*, with size info, and pics. I thought this thread was going to be that, but only a couple (good) examples so far. If there's another such thread, can someone direct me?
    Theonlyway likes this.
  17. Sep 14, 2017 at 1:37 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I have a 17 CM TRD OR with no lift. I was thinking 275/70r18 on my factory wheels, will that be a good combo and not have any rubbing? What about a 285/70r18? I'm guessing it will rub. I'd like to go as tall as I can but don't want to do any trimming. I may get a ~2" front lift down the road (5100 or 6112) and would like the tires to still look good once I do decide to level. Thanks. Oh and thinking Ridge Grapplers.
    LS3 likes this.
  18. Sep 19, 2017 at 4:57 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    I have a 03 tundra with a 6 inch lift. I have it on 35x12.5 with 17 inch rims with 4 inch back spacing. I had to remove the front mud flaps and do a little bit of trimming on the front bumper but now they fit grate. No trimming necessary for the rear.
  19. Oct 10, 2017 at 5:41 PM
    BlickM
    BlickM New Member
    Las Vegas
    2015 Tundra, Attitude Black, Platinum Crew Max
    2015 Stock Platinum CM. 285/65/r20 on stock rim/ offset. minor trim on skid plate (1"x2"), removal of front mudflap
    SHAKA U F4KA, Big J, 'fro and 3 others like this.
  20. Oct 11, 2017 at 5:47 AM
    #50
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Are you running any wheel spacers? Do you rub on the UCA at all?
  21. Oct 11, 2017 at 7:30 AM
    #51
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Stock cab mount, no chop has been completed there.
  22. Oct 12, 2017 at 3:28 AM
    #52
    Lo1dakota
    Lo1dakota Ermagherd
    Brandon
    Washington
    Nope none
    PermaFrostTRD[QUOTED] likes this.
  23. Oct 12, 2017 at 5:48 AM
    #53
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    285/65R20 is close to a 35" tire. Tire calculator puts it at 34.6"x11.2". You're really fitting that stock?
    BullyKnuckled and Sunnier like this.
  24. Oct 12, 2017 at 3:15 PM
    #54
    PermaFrostTRD
    Northern NY
    Thanks!
  25. Nov 19, 2017 at 4:01 PM
    #55
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    This is a very helpful post and I hope I'm not speaking out of line here, but it would be helpful if the first post listed the factory rim diameters and especially the width and offset for each Generation and trim. It would also be helpful as a starting reference to list the factory tire specs. For instance the TRD Offroad factory 75/65 r18 is 32.1" tall 10.8" wide and has a 7" sidewall.
  26. Nov 19, 2017 at 4:12 PM
    #56
    PermaFrostTRD
    Northern NY
    This information is widely available on this forum with a quick search.
    zcarpenter92 and SouthBoundSteve like this.
  27. Nov 19, 2017 at 4:29 PM
    #57
    ScottsBad
    Scott
    2018 TRD Limited
    Excuse me but isn't that the purpose of a catch all thread? To have all the data in one place? Otherwise, threads like this are meaningless.
  28. Nov 19, 2017 at 4:49 PM
    #58
    PermaFrostTRD
    Northern NY
    ScottsBad[QUOTED] likes this.
  29. Dec 14, 2017 at 2:16 PM
    #59
    mrblah
    mrblah New Member
    Only 1 thing confuses me.
    The second gen Tundra seem to have come (some editions) with 17" wheels but there is no mention of this here?
    Sunnier and Toyota10s like this.
  30. Dec 31, 2017 at 7:06 AM
    #60
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
    So...I want to put Toyo AT2's on my stock 20 Limited rims to replace the Dunlop OEM tires, 275/55/20 but I don't see where they make them in a "LT". Toyo has one on their website but has no LT or P rating for it. The Toyo shows 117 load rating and a "T" speed rating. Looking at the specks for my current tire on the Dunlop site the OEM tire has a load rating of 111, which they say is 2400 lbs, and a speed rating of "H" (130mph). Will these Toyo's work? Are they at least as stout as the OEM Dunlops?
    Thanks and let me know if there is another tread I should post this on....or start a new one:hattip:
