2007-2013 Toyota Tundra XB LED Headlights
Discussion in 'Lighting' started by Headlight Revolution, Sep 19, 2019.
  1. Aug 11, 2020 at 11:15 AM
    #901
    Headlight Revolution [OP] New Member Vendor
    Atlanta, GA
    Caleb is here!
    Addressing some of these moisture issues I'm now seeing, not to worry! This was a batch issue, we've relayed info to Morimoto about this and they have reviewed their productions to ensure this is no longer an issue moving forward. Anyone who has condensation issues who ordered from the original batch, please email us and we will see to it that you're sent out a replacement without any issues at all. :)
    Thank You everyone!
    Sales@HeadlightRevolution.com
    Jfuggint and cssnms like this.
  2. Aug 11, 2020 at 10:26 PM
    #902
    JustSomeGuy
    JustSomeGuy New Member
    Okanagan Valley, BC, Canada
    2009 Tundra SR5 TRD Off Road CrewMax in Slate Blue
    Diamondback HD tonneau cover, Cooper S/T MAXX tires, Rock Warrior grille, debadged, dechromed, Compustar alarm/remote start, Kenwood touchscreen with navigation, Cobra 75 WX ST CB, dual exhaust, limo tint on rear windows, Firestone Winterforce LT studded tires.
    On one hand, that's good to hear. But, on the other hand, it's a real PITA if you're not mechanically inclined, you paid someone to apply a protective vinyl covering on the headlights, then to install your headlights. Then if you are one of the unfortunate people who got headlights with condensation issues, you have to pay someone to remove the leaky headlights and reinstall the replacements (or possibly the stock headlights while waiting for the replacements to arrive). That mechanic or tech will not work for free, so I have to pay to remove and reinstall one extra time, plus it's a hassle and expense for me to drive over an hour into the nearest major city to have this done each time. And probably pay customs and duty again when the replacements are shipped to me in Canada. Then once again pay someone to apply the protective vinyl to the replacement headlights before installing the replacement Morimoto headlights.
    Of course, if my headlights are not part of the bad batch, this won't be an issue. I sure hope they are not. Is there a marking or anything on the headlights to indicate a batch number? I sure hope mine are not part of this. I suppose quality control issues and recalls can happen to the best of companies, but when you pay top dollar for what is touted as the best aftermarket and nearly comparable to OE parts, this is not what you want to deal with. I'm kind of wishing I had just paid more and got genuine Toyota Sequoia LED headlights now.
    TheBeast likes this.
  3. Aug 11, 2020 at 10:36 PM
    #903
    Karask88
    Karask88 New Member
    2011 Toyota trunda sr5 double cab
    Here is my problem The high beams have not been working I have tested the fuses and they all work today all of a sudden if I have the lights off I'm able to Flash the high beams but I am not able to Turn them on. If I have the lights on I am not able to Flash or turn on the high beams I have checked the connectors all the cables are connectedcorrectly
  4. Aug 11, 2020 at 10:37 PM
    #904
    Karask88
    Karask88 New Member
    The High Beam was working perfectly fine on the stock head headlights
  5. Aug 14, 2020 at 5:54 PM
    #905
    cssnms
    cssnms New Member
    2013 Tundra Platinum
    Call HR's customer support
  6. Aug 17, 2020 at 8:36 AM
    #906
    Atlanta, GA
    Shoot us an email, we'll get it taken care of!
  7. Aug 17, 2020 at 9:22 AM
    #907
    TheBeast
    TheBeast The Beach
    @Headlight Revolution
  8. Aug 17, 2020 at 9:29 AM
    #908
    Atlanta, GA
    There is a way to source which batch your housings came out of, this would be done Via Serial Number. If you're curious, you can email us and we'll take a look for you to determine what batch they sourced from!
  9. Aug 17, 2020 at 9:31 AM
    #909
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    I understand not being mechanically inclined, but if you have to drive two hours round trip then it may be worth your time to learn to undo the four bolts to swap the headlight.
  10. Aug 17, 2020 at 10:14 AM
    #910
    JustSomeGuy
    There's more to this than meets the eye. I also have a physical disability (disabled parking permit to prove it), I also noticed some of the problems people are having with high beams not working and I tend to screw up the simplest things and then it costs even more to have someone else fix it. Since the Moriomoto headlights have the headlight leveling motors, I ordered the headlight leveling switch kit off eBay but I am not up to speed on installing new wiring and switches (I'm sure it's easy for some of you). I also have the XB fog lights (low to the ground, I can't crawl around to install those), and I am getting all of the lights - headlights and fog lights - covered in protective vinyl. As simple as it looks, it seems those are a real PITA to install and many people ruin the vinyl so it will be cheaper and easier to get a pro from a car wrapping place to so it for me.
    So if you must know, THAT's why I'm driving two hours round trip instead of learning how to undo four bolts to swap the headlight. Before making assumptions, remember what they say about assuming. And there's always more to the story. I just didn't feel it was necessary to tell it all, but maybe it it for inquiring minds. Everyone is good at something. I'm sure there are many things you are good at that I'm not. And I'm sure there are a few things I'm good at that you're not. Everyone has their own strengths and weaknesses.
    snivilous[QUOTED] likes this.
  11. Aug 20, 2020 at 9:41 AM
    #911
    Kurt1011
    Kurt1011 New Member
    Kurt
    2013 rock warrior
    any labor day sales from HR or Lightwerkz? looking to upgrade the headlights to the XB and fogs to the diode dynamics.
    Thanks for all the help here...great thread.
  12. Aug 20, 2020 at 9:55 AM
    #912
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    Virginia Beach
    2021 CrewMax TRD OffRoad
    Stock for now
    Just for an additional datapoint. I got my lights during the May sale. This month has been extremely wet around here, including one Tropical Storm. So everything is still dry as a bone in the lights.
  13. Aug 20, 2020 at 9:58 AM
    #913
    Atlanta, GA
    I'm unsure on a Labor day sale, we aren't informed on sales until the date is closer. I'll be sure to update if we do run a sale! :)
  14. Aug 20, 2020 at 9:58 AM
    #914
    Atlanta, GA
    Awesome to hear, Thank You for the feedback!
  15. Sep 5, 2020 at 5:18 AM
    #915
    Any of you guys have a link for the harness to add leveling option to a truck that didn't come with the switch? Thanks
  16. Sep 5, 2020 at 6:58 AM
    #916
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
  17. Sep 5, 2020 at 10:25 PM
    #917
    driven1
    driven1 New Member
    Hope Morimoto comes out with a Gen2 for these headlights with LED projectors. This is the only Morimoto model in the whole line that I've seen doesn't come with projectors. The new 2018-2020 F150 Gen2 lights are impressive
  18. Sep 6, 2020 at 9:44 AM
    #918
    TheBeast
    TheBeast The Beach
    that would be nice but probably not the same price point. the F150 ones are $1800 ish ?
  19. Sep 6, 2020 at 9:48 AM
    #919
    Mine are in the marketplace if you guys know anyone interested.
  20. Sep 10, 2020 at 4:10 PM
    #920
    NFARIDI
    NFARIDI New Member
    I just received my set that I ordered Monday but I don’t see the revised housing to work with the 2nd gen sequoia headlight washers.
    As per this post, you had said in a month or so in June, being September I figured they had been revised by now.
    Did I receive one from an old batch?
  21. Sep 10, 2020 at 4:34 PM
    #921
    cssnms
    cssnms New Member
    Now my newish Morimoto LED fog light is out. :annoyed:
  22. Sep 26, 2020 at 5:13 AM
    #922
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    I have a set of decent enough spyder headlight on my 08, put some led bulbs in them and they are ok, but I feel like the OEM halogens let me see better at night. So Ive been look at these XB’s. Couple questions if you dont mind, I have skimmed through every page here.
    - does it appear that the leaking or condensation issues are random or fixed?
    - How is the night time lighting compared to OEM?
    - I dont have auto leveling on my truck is this an issue with manual adjustment once I install them?
    Thank you
  23. Sep 26, 2020 at 10:07 AM
    #923
    cssnms
    cssnms New Member
    As someone that had leaking lights, both were promptly replaced and so far no further issues, granted it's only been a few weeks.
    The light output is very good. I'd go so far as to say my perception is it is just as good if not better to my eye than my stock halogens. A very OEM-like light output. However they are not as bright as the OEM LEDs on my Lexus LX570, which are super bright.
    The lights can be adjusted manually, you simply wont have a plug to insert into the leveling socket.
    Other than the initial water infiltration issue, I am very happy with the performance and look of the headlights esp the daytime halo ring and turn signal light articulation. The only complaint I have is, I'd wish the daytime halo light would dim when the headlights are turned on, it is very bright during the day and even more so at night. These lights were a huge step up from my stock morimoto HID conversations.
    obgod3[QUOTED] likes this.
  24. Sep 26, 2020 at 10:28 AM
    #924
    The daytime running light does dim when you turn the headlights on. I don't know why yours aren't.
  25. Sep 26, 2020 at 10:38 AM
    #925
    cssnms
    cssnms New Member
    I will have to look again, but if they do, they are still very bright.
  26. Sep 26, 2020 at 10:41 AM
    #926
    cssnms
    cssnms New Member
    At 6:50 in this video, the halo rings do not appear to dim when the headlights are turned on.
    https://youtu.be/kcxQssGld1o
  27. Sep 26, 2020 at 10:45 AM
    #927
    They do dim....they have to by law. Its hard to tell in the video. I am on my 2nd set and they both works advertised.
  28. Sep 26, 2020 at 10:48 AM
    #928
    cssnms
    cssnms New Member
    Understand
    Now in this video they appear to dim. Perhaps the dimming is so dominus that it is difficult to notice when the headlights are activated.
    I'll try just turning on the parking lights.
    https://youtu.be/Y2-PczfsQws
  29. Sep 26, 2020 at 11:06 AM
    #929
    Yes they do dim with the parking and headlights.
  30. Sep 26, 2020 at 5:28 PM
    #930
    TheBeast
    TheBeast The Beach
    also depends if you in parking mode or not but yeah they dim.
