2015 tundra brake controller harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1G3-TRD, Feb 11, 2015.
  1. Jun 30, 2016 at 7:57 AM
    #91
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    You can not use the controller in a 14. It is not compatible. The panel is but not the controller. We use the factory panel with a custom plate to integrate the Prodigy P3 controller into the dash. I have had several people order our panel for use in the 16's as they can not stand the factory controller. You can go to our website at www.esptruck.com for more info
  2. Dec 11, 2016 at 9:03 AM
    #92
    mike303
    mike303 New Member
    2023 Platinum hybrid
    2” lift Switch-pro accessory controller Trd skid plate Baja design A-pillar mounted lights Toyota swing out boxes
    I know this is an older thread, but thought I would post how I did my brake controller. I got the dash molding for the 2016 and had it cleaned up...
  3. Dec 11, 2016 at 9:21 AM
    #93
    gosolo
    Ray
    NW Oregon
    Nice looking job!
  4. Dec 11, 2016 at 7:16 PM
    #94
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    That looks GREAT ! Is that the P3 you installed ? Do you have a part # on the dash piece you bought and how you modded it ? Thanks in advance.....
  5. Feb 21, 2017 at 3:25 PM
    #95
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    Roman[QUOTED] likes this.
  6. Feb 21, 2017 at 3:52 PM
    #96
    CM-LENNY
    San Diego, CA
    Hey Ron, take a look at the controller that Mike303 has. If that is the P3, which I have, looks like he bought the panel that Roman listed and modded it to hold the P3. Your thoughts ?
  7. Feb 21, 2017 at 4:06 PM
    #97
    CM-LENNY
    San Diego, CA
    Yes ESP that makes the under seat storage offers one, but this one above is a more molded factory look. Thanks Ron........
    NewImprovedRon likes this.
  8. Feb 21, 2017 at 4:11 PM
    #98
    Flobrandx
    Brandon
    2015 TRD PRO
    Well....was doing some more reading as suggested. I'm torn as I like factory parts and the clean install but brakes and safety are much more important. Not sure wether to try it out as there is some success with them or go to the P3 and ESP panel.
    SouthBoundSteve likes this.
  9. Feb 21, 2017 at 4:19 PM
    #99
    Flobrandx
    Brandon
    2015 TRD PRO
    Thanks for the heads up Ron. I better check the return policy... Did you go with the OEM controller as well or P3 or something else?
  10. Feb 21, 2017 at 7:52 PM
    #100
    Flobrandx
    Brandon
    2015 TRD PRO
    Out of curiosity, what's your experience and review of the OEM unit?
  11. Feb 21, 2017 at 10:43 PM
    #101
    Steve Tundra
    Steve Tundra New Member
    Steven
    2022 4x4 platinum
    Ordered my PS3 and ESP cover. Can't wait to install it. Picking up a 10000 pound dump trailer tomorrow and want to see it in action.
    havasubud likes this.
  12. Feb 22, 2017 at 4:16 PM
    #102
    havasubud
    Earl
    Corona, California
    It's on its way! Thanks!
  13. Feb 22, 2017 at 7:59 PM
    #103
    Steve Tundra
    Steven
    2022 4x4 platinum
    I will post some pics with the trailer. Excited to see how it handles
  14. Feb 25, 2017 at 3:12 AM
    #104
    Steve Tundra
    Steven
    2022 4x4 platinum
    Just drove with my trailer. Honestly it pulls so easily when empty that you forget you have a trailer.
  15. Feb 25, 2017 at 5:10 AM
    #105
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I have, not very impressed. At low (like under 10mph) speeds the controller works, almost too jerky even at low settings. At higher speeds, its like it does nothing. Towing my parents tractor (about 8K with trailer) back and forth to my lot while building it got a little hairy sometimes. If Toyota doesn't do something about it soon, I'll be putting in a P3 and buying the plate from Havasubud.
    A lot of different opinions on the factory brake controller but this is my experience with it and I will be replacing it. Just haven't spent the money yet on a new one. Hopefully I'll have some free money soon.
  16. Jan 4, 2018 at 1:49 PM
    #106
    jrmorris
    jrmorris New Member
    jamie
    2015 Toyota Tundra trd crew max
    4 in lift, dual exhaust, fender flares, new rims and tires
    is there any more word on the oem controller i like the clean look of the oem. Just torn on if the issues with them are worth getting or the P3. Any feedback would be nice on both of them with people that have them thanks. It would be for towing my travel trailer about 4600 pounds so not too crazy.
  17. Jan 4, 2018 at 2:22 PM
    #107
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2024 Tundra Limited 4X4 Nightshade Blueprint
    BAK MX4, window tint, TRD skid plate
    Some have reported that the update (Trailer Brake Controller - Braking Feel, T-SB-0231-17, released June 27, 2017) makes it better. However the IBC is a different type of controller and may not feel the same as the P2/3 which have a more definite brake feel when activated. This is an update for years 2016-2017 Tundra and is VIN dependent and 3UR Engine (depends upon previous version of Trailer Brake Control ECU software installed).
    "Some 2016 - 2017 model year Tundra vehicle customers have expressed dissatisfaction with the braking feel of the integrated brake controller. Revised software...has been developed to provide an alternative trailer brake feel..."
    It is covered under the 36 month or 36,000 miles warranty. I just told my dealer that I didn't like the feel of the brake controller and to check if there was an update available. The tech confirmed that my truck was eligible and installed the update - I have not used a trailer with brakes yet to confirm that it helps.
  18. Jan 4, 2018 at 4:47 PM
    #108
    Flobrandx
    Brandon
    2015 TRD PRO
    Figured I’d post my experience with the OEM controller. I pulled my 37’ 8000lb (empty) trailer all last year with no issues. I have the gain set @ 7.5 (if I remember correctly) and can feel it kick in and have had the trailer lock up on an emergency braking incident. At times it is tough to tell if it’s actually working but after having my truck serviced at the end of the year by Toyota there was no weird or extreme brake pad wear noted so that makes me believe it’s working as intended. But without having a comparison to another unit I couldn’t say what’s better.
  19. Mar 14, 2018 at 7:55 PM
    #109
    Carlos
    Carlos New Member
    Carlos
    2014 Toyota Tundra SR5
    none
    I would like to install the factory trailer brake controller on my 2014 toyota tundra SR5 , help please
  20. Mar 15, 2018 at 7:06 AM
    #110
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    No can do. It only works on 2015+ models. You'll have to go with an aftermarket controller.
  21. Jul 17, 2020 at 10:58 AM
    #111
    Pan
    Pan New Member
    Did anybody ever find out where to get the modified mounting panel like this? I've been looking online, but haven't seen anything like it. It doesn't look like the one made by ESP.
    Any information would be appreciated, trying to figure out the best way to get a brake controller mounted on my 2015 Tundra.
    Upgrayedd likes this.
  22. Jul 17, 2020 at 11:28 AM
    #112
    mike303
    mike303 New Member
    I had the work custom done. It was done by car toys since I’mnot that great at fiberglass molding.
  23. Jul 17, 2020 at 11:33 AM
    #113
    Pan
    Pan New Member
    Ah, got it. I appreciate the info. I guess I'll get some pricing done at local shops.
  24. Jul 17, 2020 at 11:58 AM
    #114
    TTund16
    TTund16 New Member
    Is that for Prodigy or P3 from Car Toys? How much they charge you for the plastic molding?
  25. Jul 17, 2020 at 12:01 PM
    #115
    mike303
    mike303 New Member
    It’s a p3, but I got that on my own. I just had cars toys do the install. It’s been a few years, but I think it was an hour or two of labor.
    TTund16[QUOTED] likes this.
  26. Jul 17, 2020 at 12:10 PM
    #116
    TTund16
    TTund16 New Member
    Did you ditch your Toyota controller? Curious if you had a factory IBC like us that didn't work.
  27. Jul 17, 2020 at 12:23 PM
    #117
    mike303
    mike303 New Member
    I have a 2015, didn’t come with a factory one. I do like the p3 though.
  28. Jul 17, 2020 at 12:25 PM
    #118
    Pan
    Pan New Member
    I'm looking at this one, any reason not to save $100?
    https://www.amazon.com/gp/slredirect/picassoRedirect.html/ref=sspa_dk_detail_2?ie=UTF8&adId=A01604301SNZRX4V2CG3T&qualifier=1594916362&id=401549122022094&widgetName=sp_detail&url=%2Fdp%2FB017NAH5WK%2Fref%3Dsspa_dk_detail_2%3Fpsc%3D1&pd_rd_i=B017NAH5WK&pd_rd_w=BIYZT&pf_rd_p=48d372c1-f7e1-4b8b-9d02-4bd86f5158c5&pd_rd_wg=yBogA&pf_rd_r=KZ83FQZKAD97Y5956CPA&pd_rd_r=3558d754-b8c0-44f8-a296-dbd30e2cddb8
    Edit - the P3 price is about $140, the Reese price is about $40, and the Reese has pretty good reviews from what I see. Am I missing something? I've never used a trailer brake controller before, so I'd hate to make a stupid error right out the gate.
  29. Jul 17, 2020 at 12:54 PM
    #119
    mike303
    mike303 New Member
    for me I like having the saved setting for different things I am towing. It is purely a convenience but is nice. Also with my custom install I knew I needed the buttons in the front. That was the deal breaker for me on most other ones.
  30. Jul 17, 2020 at 1:12 PM
    #120
    Pan
    Pan New Member
    Mike303, I was looking at the picture you posted. Are you able to use the manual braking knob on the bottom of the P3? I can't tell for sure, but the picture kind of looks like it's covered up. Am I just seeing things?
