New Tires/Wheels - 285/70R18
Discussion in '2.5 Gen Tundras (2014-2021)' started by harrisdoggy, Nov 2, 2016.
  1. Feb 23, 2017 at 8:24 AM
    #61
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    You're rubbing the front liner
  2. Feb 23, 2017 at 8:24 AM
    #62
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I'd rather have a rub than the trac situation. Hard to tell from the pics, but looks like you might have to do some trimming. Maybe pull your coilovers and adjust to the top setting. Or add couchbuilder shims. Two on each side would get you close to 3 inches. Your on the second to the top setting. I have shims for mine, but haven't put them in yet. It looks like you can just drop the lower control arms, drop the coilovers down enough to slip the shims in and bolt it back up. You will of course have to get another alignment. Then you shouldn't have to trim your bumper.
    harrisdoggy[OP] likes this.
  3. Feb 23, 2017 at 8:46 AM
    #63
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Maybe my stock wheels are the issue with mine. Perhaps with the higher center of gravity, pushing the wheels out to widen the footprint helps keep the truck planted. I might try spacers to see, not to keen on running spacers. But, I did have them on my 1st gen without having any problems. In your case, I think more lift would be the solution. If you add a couple shims it shouldn't change the ride as you won't be putting more preload to the springs. And you won't have to completely tear everything down again.
  4. Feb 23, 2017 at 8:47 AM
    #64
    harrisdoggy
    harrisdoggy [OP] New Member
    Josh
    2016 Toyota Tundra CrewMax SR5
    Yeah - when I put them on in the shop everything barely cleared, but it seems like the rubbing has started to get a little worse. Any thoughts on why it would be only on the driver's side? Wondering what the best solution is.......
  5. Feb 23, 2017 at 8:54 AM
    #65
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    No expert here but folks who modify their suspension often remark about the "Toyota drivers side lean" where the drivers side sags a little bit lower than the right. Maybe this is contributing.
  6. Feb 23, 2017 at 8:55 AM
    #66
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Because of the fact that our trucks sit lower on the drivers side. Couchbuilder recommends two shims on the drivers and one on the passenger side to level things out. But now I'm not sure, after talking with lotsoftoys. He says that can cause other issues, because your putting more preload on one side. But it's not really preload as the shims go on top of the coilover assembly. If yours doesn't have to much lean, just put in one or two on each side. Keep in mind though that at 3" lift you may have to get ucas as well.
  7. Feb 23, 2017 at 9:02 AM
    #67
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Like these guys said, it could be the lean. You can measure from your fender to the middle of your wheels to see if the driver's side is lower. If that's the case, you can add a shim to raise driver's side. But that's still not a guarantee to fix it. Or you can just do what most of us with larger tires have done. Push the liner forward and redrill and if that's not enough, trim a little where it's rubbing. It sounds like your rubbing may be very minor, so this would probably do it.
  8. Feb 23, 2017 at 9:39 AM
    #68
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    Here are my KO2's in 285/65 R18....2.5" lift up front/ approx 1.5 lift rear via AAL. I LOVE these tires. They are the best I've had so far. I have No traction control issues.
  9. Feb 23, 2017 at 9:53 AM
    #69
    The Juice
    COLORADO NATIVE
    ALSO.... One of the lesser known Newer tire offerings on the market that are BAD ASS are the Falken Wildpeak A/T3W's. My best friend just put them on his truck about a month ago. I would have never given Falken any serious consideration, but my buddy swore up and down that all the reviews by various 4wheel and truck magazines and online publications of the tires where praising them. They WILL be my next tires having driven his truck and being BLOWN AWAY at how good they are. They are also rated for M/S without feeling overly soft to the touch. He's driven them on snow and ice and won't stop talking about how great they handle. IMO they are the best 4 season truck tire on the market. Here is a link to a great article on them and some photos. I think they have the competitions tires beat in SPADES in this category.
    http://www.off-road.com/trucks-4x4/review/falken-wildpeak-at3w-allterrain-tire-review-54401.html
    tires.jpg tires2.jpg tires3.jpg tires4.jpg ca5303faa529b1f835dcc240f0dffbc9.jpg
  10. Feb 23, 2017 at 10:02 AM
    #70
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Your 285/65/18's are about a 33, the 285/70's are about 34. That added inch probably makes a big difference. I am thinking about getting a set of wildpeaks for my wife's jeep. Had a guy at big o tell me they're junk, probably because he would make more money selling us big o Branded. Nice to hear that they are a good option.
  11. Feb 23, 2017 at 10:10 AM
    #71
    The Juice
    COLORADO NATIVE
    That extra inch makes a HUGE difference. I rolled the tires I bought up next to my wheel wells at Discount tire as well as the 285/70's and the 70's were just to big. I didn't/ don't want to start cutting crap. Huge tires belong on Jeep Wranglers in my opinion which are much more capable for 4 wheeling and beating on in general! LOL:crapstorm: As for that guys opinion, he has no clue and obviously hasn't actually used the tires himself. I was a Falken hater as well.....then I drove on them and.....damn!!!:headbang:
  12. Feb 23, 2017 at 6:37 PM
    #72
    harrisdoggy
    Josh
    Truck looks great! Why did you opt for the 285/665 versus the 275/70? I almost did the 275/70, but opted for slightly larger - now I have the issues to work through with the bumper.
  13. Feb 23, 2017 at 6:45 PM
    #73
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I wish I'd gone with either the 275/70 or the 285/65's. Would have been a lot less money and issues! Truck sure looks good with the 285/70 though.
  14. Feb 23, 2017 at 6:55 PM
    #74
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I checked my tire pressure today when totally cold, snowing out. I had them at 35psi hot and figured that was about 32, well they were actually at 29psi and obviously to low to wear right. I'll adjust them up to 32 Sat cold, when it's not freezing out, then see how it does. Tire pressure definitely changes the way the trac reacts. I've just got to try and find the sweet spot, where the trac doesn't go crazy and tire wear won't be a problem. I still might try spacers. Bora makes 1", that'll push the wheels out a little without increasing the scrub radius to much.
  15. Feb 23, 2017 at 7:05 PM
    #75
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Amado, don't recall you mentioning it, but you got the zero point calibration done, right?
  16. Feb 23, 2017 at 7:12 PM
    #76
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Sure did Joon, unfortunately it didn't do anything for the trac situation. If I'm understanding it right the zpc doesn't do anything to adjust the wheel speed sensors. My local tech is going to talk to a couple of his buddies that work at dealerships to find out if there is a way to get into the programming to adjust for bigger tires. He's not aware of any.
  17. Feb 23, 2017 at 7:17 PM
    #77
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I think @GNTundra fixed his with bullydog or one of those tuners. Gino!!!
    GNTundra likes this.
  18. Feb 23, 2017 at 7:23 PM
    #78
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I thought I read that the tuners didn't have the capability to do that. I'll have to look into it.
  19. Feb 23, 2017 at 9:11 PM
    #79
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Thanks for the info Gino, does the hypertech Speedo calibrater help settle down the trac by itself? It seems like it should since the ecu is getting an accurate wheel speed reading. In turn, the signal to the trac should be correct, right?
  20. Feb 23, 2017 at 9:21 PM
    #80
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Sounds like the next thing I'll be doing. It's going to have to wait till work picks up. My wife is going to kill me if I try to spend another dime on the other woman right now.:ballchain::burnrubber:
    harrisdoggy[OP], joonbug and GNTundra like this.
  21. Feb 23, 2017 at 9:24 PM
    #81
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I like that you can buy just the Speedo calibrater from hypertech, then upgrade it to the full programmer later.
  22. Feb 23, 2017 at 9:44 PM
    #82
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    She acts like I'm breaking out the checkbook every time I get on the site. But honey, I'm only spending in my head doesn't work.:crapstorm:
    The Juice likes this.
  23. Feb 24, 2017 at 10:35 AM
    #83
    The Juice
    COLORADO NATIVE
    The 285 width looks better to me than the 275 width and if I had gone any taller, greater than the 65, I would have had to deal with trimming issues. I'm not a fan of cutting and moving things around. Just my preference though! I also see a lot of guys on here going with taller tires and keeping the width the same which results in a truck that still looks stock to me, it's just a higher truck. I don't know why someone would want to spend all the money to raise their Tundra and pay for expensive tires when the end result is a stock looking truck. Again, just my opinion! As long as it's a Tundra it's all good with me!:cheers:
  24. Feb 24, 2017 at 4:09 PM
    #84
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    You're right, I've been noticing that mine does kind of look like a stock truck with the bigger tires filling out the wheel wells after the lift. Its got a nice balanced look, just bigger and badder!20170102_152138.jpg
    equin and harrisdoggy[OP] like this.
  25. Feb 24, 2017 at 5:44 PM
    #85
    FiveOhh
    FiveOhh New Member
    Josh
    Charlotte, NC
    2015 Black Tundra
    Joeshaker....what is tire size/lift? I have a black beauty also and I like your look
  26. Feb 24, 2017 at 6:40 PM
    #86
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Thanks Josh, I like the way it sits to, not to extreme. I'm running 285/70/18's with 2.5" front, 1" shackles and bags in the back. Bags add .5" at 5 psi minimum inflation.
  27. Mar 3, 2017 at 11:06 AM
    #87
    harrisdoggy
    Josh
    What PSI do you run? I just stopped by Discount for a check and they asked what I wanted them at. I said I had no idea, just whatever is good. Anyway, dude looked at me like I should know. I think he set them at 37 PSI.
  28. Mar 3, 2017 at 5:24 PM
    #88
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hey Josh, 35 to 37 is probably about right. Discount had mine at 40 which felt alright, maybe a little stiff and not great on snow. I've been experimenting with the pressure to get the trac to settle down. At 30 the trac was less sensitive but obviously to low. Put them back up to 33, which still looks and feels a little low.
  29. Mar 3, 2017 at 5:35 PM
    #89
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    I went with 285x75x18 Terra Grappler G2s on MotoMetal 18x9 +18 rims. I love the look and the way they fill the fender wells...
    bowtieman55 and equin like this.
  30. Mar 3, 2017 at 6:37 PM
    #90
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Your truck looks great sixpack! What lift do you have, had any issues with the trac going off when your turned in at a certain angle? Mine does it pretty bad with the 34 inch tires on stock wheels.
