Hi lift jack
Discussion in 'Recovery & Gear' started by joonbug, Feb 19, 2017.
  1. Feb 20, 2017 at 9:39 AM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I went out to my truck last night and was thinking maybe mounting it on the bedside with the weight of the jack on the wheel well to take the load off the bedsides. How do you think that would work?
  2. Feb 20, 2017 at 9:48 AM
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    Anything to help with constant vibration or to lessen the weight of that jack would help. I also recommend buying that Jack rubber isolator for it. The metal clip for the handle is not worth chit.
    Plus it works good to keep from the handle rebounding back and smashing your hand while holding the jack upright while lowering your rig. I've had the jack hit my head, knock others on their ars, smash my fingers, hit my chin, gashed my hand, tossed me into a truck and piss me off on so many occasions that the Hi Lift is now my back up for a winch only. Not saying it works, cause it works well, if you want your rig 3 feet lifted from the ground, no problem.
    Sunnier and YotaDan like this.
  3. Feb 20, 2017 at 9:58 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I've got the isolator. And I do know how dangerous they are but I'm not going on a solo trip with my wife and kids without one. It'll only be pulled out when absolutely necessary meaning it's either the hi lift or sit there stuck in the middle of no where.
    AZBoatHauler likes this.
  4. Feb 20, 2017 at 9:58 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    http://www.hi-lift.com/accessories/index.html, Look through here Joon. It has both parts needed to do the job. I recommend having some stoppers along with the OBR (off-road base from Hi-Lift so the jack doesn't sink) for the front/rear of the vehicle so it doesn't roll forward while you lift from the back. I'd opt for a 2/3 ton floor shop jack but that thing would sink in the ground as im usually offroad and I don't want to rely on wood to support the truck.
  5. Feb 20, 2017 at 10:06 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
    We have the DayStar Poly Isolators available in both Black and Red. [​IMG]
    CJ21 and joonbug[OP] like this.
  6. Feb 20, 2017 at 11:43 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    I have mine mounted with some weight supported by my gun box. It is mounted to the front bed track using eye bolts. It has been back and forth across country, bounced around New Orleans streets and. Down a few dirt roads at high speed for almost 15K miles. Scroll down thru photos for picture.
    https://www.tundras.com/threads/over-the-line-2016-cm-4-x-4-build.5884/
    joonbug[QUOTED][OP] likes this.
  7. Feb 20, 2017 at 12:18 PM
    LML 3500HD
    Rivit nuts not used properly are weak. If used to secure a mounting system, and use enough to disperse the load, they are a great tool. I have most of my body panels on my Jeep hung by rivit nuts. I can guarantee my body panels get used in a more harsh environment.
    Mounting systems for a truck are very tough to design and not look out of place unless you have a bed rack. In a truck, realistically the foot of the jack should sit flat on the bed, in a cradle that is bolted to the bed, and supported up higher to minimize vibration. Jeeps are easy. Stand them up on the rear bumper and bolt it down.
    To be honest, I would carry a hydraulic bottle jack and a 6x6 chunk of wood. Like others have said, if you have on sliders, jack from there.
    I have two farmer jacks in my garage and only use them for trailer tire flats. If used properly, the danger factor goes down. I would use something different if it were me.
    http://www.ebay.com/itm/like/292022775976?lpid=82&chn=ps&ul_noapp=true
    rons23 and joonbug[OP] like this.
  8. Feb 20, 2017 at 12:29 PM
    LML 3500HD
    Another option is to mount the jack on the bed floor, so the weight of the jack is laying down on the bed. Of course this takes up bed space.
    I actually don't carry a jack. Tire plug kits and CO2 tank. The exhaust jack I like, and will most likely get one. Light, lift the vehicle with ease. Now that I think about it, it can also help lift my tire and wheel back up to the mount. Lifting 140-160 lbs in tire/wheel combo up over your waist onto a mount sucks. The weight isn't as much of an issue as balancing it while lifting.
  9. Feb 22, 2017 at 8:10 PM
    gosolo
    Ray
    NW Oregon
    Hi lift jacks have a place but there's plenty of other gear that is important too.
    I'm not sure but I believe most people probably don't use the jack and carry it for show.
    I wore out the pins on mine and bought replacement pins with new springs. Most of the use was pulling fence posts out of the ground when I built fence on ranches. I also used it to break the bead on tires when they needed patching. I ran split rims on a lot of the trucks I had so I could do repairs anywhere.
    I guess my point is that if you're not really familiar with it and not going to use it, don't bring it cause it's heavy and it wants to hurt you.
    Tundra805, Sunnier and ColoradoTJ like this.
  10. Feb 22, 2017 at 8:19 PM
    LML 3500HD
    Funny you mention the fence post trick. I just pulled out 8 of my own last month that way.
  11. Feb 22, 2017 at 8:25 PM
    gosolo
    Ray
    NW Oregon
    I used a piece of chain about 6' long with a grab hook on one end. You can swing it around the post, get about 3 turns.
  12. Feb 22, 2017 at 11:05 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  13. Feb 22, 2017 at 11:10 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Hi-Lift jacks are perfectly "safe" as long as you practice good use and jack it up right. The most common errors I've seen people make when jacking their truck up is not using a better base plate and/or positioning the foot of the jack a few inches inward of where you're jacking (because as you jack up it will move "forward").
    Here's me using mine 2 weeks ago as I needed to swap out a tire that lost its bead due to a puncture in the sidewall..
  14. Feb 22, 2017 at 11:27 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I think I'm going to bolt it to the floor.
    TRD15559, Hattori and ColoradoTJ like this.
  15. Feb 23, 2017 at 5:53 AM
    LML 3500HD
    Me likey.
  16. Feb 23, 2017 at 6:16 AM
    gosolo
    Ray
    NW Oregon
    If you haul firewood or rock, gravel, sand or manure you could get some stuff in the mechanism down on the floor of the bed.
    joonbug[OP] and ColoradoTJ like this.
  17. Feb 23, 2017 at 6:30 AM
    LML 3500HD
    I'm sure Joon would remove the jack before doing work like this.
    Right Joon?
    zcarpenter92, rons23, AnonVet and 2 others like this.
  18. Feb 23, 2017 at 7:46 AM
    gosolo
    Ray
    NW Oregon
    lol, no doubt! I'm just continually overlooking the obvious consequences of my actions that I saw something that might get overlooked and felt I should mention it.
  19. Feb 23, 2017 at 7:52 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yeah... no. I'll never haul rock, gravel, sand, and especially manure :D. I'm just going to drill 2 bolts on the floor and I'll be able to remove it anytime. The bolts will be right next to the wheel well so not really in the way. As long as I can load 2 dirt bikes I'll be ok.
    gosolo[QUOTED] and ColoradoTJ like this.
  20. Feb 23, 2017 at 9:58 AM
    #50
    Over the LINE
    New Orleans
    What about bolting to sidewall but placing foot on bed floor to take weight? Jack would angle over wheel well.
  21. Feb 23, 2017 at 10:08 AM
    #51
    Over the LINE
    New Orleans
    I have used mine twice in 155K miles for my truck. Once before I had a winch, in winch capacity, it worked but it is a pain. Once to get unstuck by lifting a wheel using the rim attachment. In both situations, nothing else would do. I wish I could hide mine under the rear seat like I did on my Titan.
    I have used it to position a skid style duck blind, level a water cistern and do other jobs but the best was to unstuck a 350Z buried to the floor pan in sand. That wheel hook attachment is cool. Just jacked it one wheel at a time and put boards under the wheels for him to drive back to the road he should have never left.
    You are right about lots for show.
  22. Feb 23, 2017 at 10:09 AM
    #52
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    that's nifty as hell @Hattori
  23. Feb 23, 2017 at 10:31 AM
    #53
    n2deep
    n2deep Pavement Princess
    Mounted mine on the inside bed. Been there thru plenty of off-road abuse and never fallen or come loose. You can use it on your hitch if you don't have sliders but no way to use it on the front if your stock.
  24. Feb 23, 2017 at 10:38 AM
    #54
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    @n2deep that's nice. I'm still considering this, but I'm pretty lazy.
    CJ21, ColoradoTJ and YotaDan like this.
  25. Feb 23, 2017 at 10:41 AM
    #55
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    very true in reference to the front bumper @n2deep
    ColoradoTJ likes this.
  26. Feb 23, 2017 at 10:41 AM
    #56
    n2deep
    Super easy to build- buy some stock flat a couple of bends 4 bolts. I did weld some studs to it but you could just run the bolt thru to hold it. Just wants to fall off when you unmount the jack.
    joonbug[OP] likes this.
  27. Feb 23, 2017 at 11:41 AM
    #57
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    I have the base, the isolator, and a wheel attachment somewhere stored away. When I sold my Grand Cherokee, I didn't have an offroad vehicle anymore so I lent my Hi lift to a friend. But I couldn't find the accessories at the time so he just took the jack. Then my friend moved away and that fucker took the Hi lift with him. I called him a couple weeks ago to give my damn jack back knowing he was too far to give it back. He bitched a little but the next thing you know, a brand new one showed up at my door. :) Anyways, I remember seeing the accessories in a box when I moved, I just need to find it now. And I already carry 2 chocks in my truck.
    Sunnier, ColoradoTJ and gosolo like this.
  28. Feb 23, 2017 at 11:51 AM
    #58
    gosolo
    Ray
    NW Oregon
    @joonbug yeah, I figured out I can't afford any more friends!
    NewImprovedRon and joonbug[OP] like this.
  29. Feb 23, 2017 at 12:02 PM
    #59
    joonbug
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Especially the dipshits that borrow stuff and don't return it til you ask for it back. :mad:
  30. Feb 23, 2017 at 12:42 PM
    #60
    gosolo
    Ray
    NW Oregon
    https://www.tundras.com/posts/126377/
    Don't know if you saw my post in "best knife under $100", but I have some special junk just to loan "that friend", like the 4' level I drove over.
