Stop Pulling Me to the Left
Discussion in 'Suspension' started by Les7311, Feb 17, 2017.
  1. Feb 17, 2017 at 3:10 PM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    so the shop Installed the 6 inch lift kit, wearing 20 x 35 rims / grappler tires. Second alignment shows true, yet truck pulls to the left and the distance of a football field.
    Shop says links and joints are all good. What am I missing? Stabilizer shocks???
  2. Feb 17, 2017 at 6:33 PM
    LML 3500HD
    Is this when braking or just driving down the road?
  3. Feb 17, 2017 at 6:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Take it somewhere else to get the alignment and see.
    Jsena, ColoradoTJ and 040Tundra like this.
  4. Feb 17, 2017 at 6:41 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Jsena and Bear like this.
  5. Feb 17, 2017 at 7:04 PM
    Les7311
    Truck pulls to the left under normal driving, even when am in the far right lane.
    Alignment shop blamed the aggressive tire threads.
  6. Feb 17, 2017 at 7:15 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    If the alignment values look good it is possible that you have a radial pull. Try rotating the wheels/tires from left to right and see if the pull changes. Post up the alignment sheet and I'll be happy to look at the numbers.
  7. Feb 17, 2017 at 7:21 PM
    LML 3500HD
    This^^^^^
  8. Feb 17, 2017 at 7:35 PM
    Les7311
    The shop suggested the same to switch the fronts due to a radial pull. If pull changes does that means the tire is defective?
    . I don't have the print out or I certainly would at this moment. Wil get from shop
  9. Feb 17, 2017 at 7:45 PM
    Sunkist
    Sunkist New Member
    Siler City, NC
    2014 Tundra Crewmax SR5
    ESP rear seat storage Rough Country Susp lift 20" Fuel wheels 35" Toyo open country MT Weathertech front/rear floor liners ICI Magnum steps with led's
    Ugh, I'm in the same boat with my 6" lift and 35s except mine pulls to the right. 3 alignments, 2 different shops. Numbers look good, nothing bent. Rotating tires did not help. You aren't running toyo mt's by chance?
  10. Feb 17, 2017 at 7:54 PM
    LML 3500HD
    I sure would like to see some printouts of the alignment sheets.
  11. Feb 17, 2017 at 8:02 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Which type of Grappler tires are you running? Mud terrains or A/Ts?
  12. Feb 17, 2017 at 8:02 PM
    Porschetech29
    Francis
    It does not necessarily mean that the tire is bad. Another option is to find a shop with a tire balancer that can perform straight track. This process measures the radial pull for each wheel/tire then on the balancer you can simulate different mounting positions for each wheel/tire to determine the best mounting location on the vehicle. Try to get the alignment sheet. As far as the alignment goes just because the numbers are green does not mean the vehicle will track straight. It all depends on cross camber and cross caster. I typically set up vehicles biased slightly left to counter road crown.
    ColoradoTJ likes this.
  13. Feb 18, 2017 at 3:26 AM
    Les7311
    I will have to get the shop print out on Monday.
    The initial balance was crap. The driver seat and steering wobbled hard at 40 mph. Went back and they rebalanced that made it worse. Shop had to call somewhere to get advice on how to balance - they flipped tires on the rim. Third go felt a lot better on balancing.
  14. Feb 18, 2017 at 3:31 AM
    Les7311
  15. Feb 18, 2017 at 3:45 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    What is your left and right caster?
    Do you have a more positive camber and more negative caster on the left?
    Can you post your alignment spec sheet?
  16. Feb 18, 2017 at 3:49 AM
    Les7311
    If I see another post to post up the alignment sheet, am going to drive my happy a$$ down the shop and bust open that front door (sorry they closed on weekends).......hahahah - no ofense
    But seriously, I will get printout on Monday. Sorry folks
    ColoradoTJ and 1UPPER like this.
  17. Feb 18, 2017 at 12:02 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    :worthless:
    Sorry man, I couldn't resist...
  18. Feb 18, 2017 at 4:28 PM
    Backslider
    Tooele, UT
    Ah, sorry man I hadn't read every post.
  19. Apr 28, 2017 at 9:08 AM
    Les7311
  20. Apr 28, 2017 at 5:24 PM
    Les7311
    Ok here is my dilemma.
    The truck is pulling to the left and I have the \ / after the last alignment done at Southern.
    The alignment at Wiygul (before Southern) had the truck driving pitch straight, but I had the ghastly \ / in tires looking from front about 15 ft off.
    Also truck feels floaty when doing about 60 and rocking steering wheel back and forth. IMG_1204.jpgIMG_1205.jpg
    Where is the hiccups? Don't want to burn up tires less than 500!miles new. The pill is to the left and will cross two lanes the length of a basket ball court.
    Southern says the aluhment is correct and I prob have radial pull
    Help!!!!!
  21. May 1, 2017 at 9:50 AM
    Les7311
    Any help on this alignment issue?
  22. May 1, 2017 at 10:04 AM
    csuviper
    Broomfield, CO
  23. May 1, 2017 at 10:04 AM
    csuviper
    Broomfield, CO
  24. May 1, 2017 at 11:14 AM
    Les7311
    I appreciate any advice.
    The last alignment was done a week ago and scheduled for a recheck at the Southern shop. Want be be correct when I drive up
  25. May 1, 2017 at 11:17 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    there is an alignment thread and discussion over on tundratalk.net:
    http://www.tundratalk.net/forums/tu...spec-thread-w-links-shop-recommendations.html
    in this post, the recommended alignment is:
    STOCK TRUCKS:
    Camber: +.1 degree camber on both sides.
    Caster: As much as possible without sacrificing +.1 degree camber or causing a cross caster pull.
    Toe: +.12 degrees per side for a total toe of +.24 degrees. (some guys have had to drop toe to +.04 to +.5 per side/+.08 to +.10 total toe)
    LIFTED TRUCKS:
    Same As Above ... BUT if you have wheels that have more negative offset than factory wheels, increase the camber to +.2 degrees. (or even +.3 degrees if they just can't get there with the amount of adjustment allowed by the eccentrics) Adjustable upper control arms are available for cases where there just isn't enough adjustment left in the eccentrics to get a decent alignment. Although they are expensive, most guys with lifts have a lot of $$$ invested in tires so you need to make a judgment call.
    i recently had 5100's installed at 1.57" using 20x9 +50mm offset wheels and nitto ridge grapplers and the truck drives and steers perfectly:
  26. May 1, 2017 at 11:24 AM
    Les7311
    So based on the alignment by Southern, and the tundratalk, am I in specs?
    The Wiygul alignment was running straight, but the \ / was killing me.
    Any feedback appreciated
  27. May 1, 2017 at 11:27 AM
    Netmonkey
    Georgetown, TX
    according to that thread, you do not have a proper alignment. your camber is way off and you should have more caster on the right side to compensate for road crown.
    Les7311[QUOTED][OP] likes this.
  28. May 1, 2017 at 11:34 AM
    Netmonkey
    Georgetown, TX
    i am not sure about 6 inch lifts, but with 3 inch lifts, you usually need aftermarket UCA's to get a proper alignment. maybe someone can chime in about needing UCA's for 6 inch lifts...
    Jsena and Les7311[OP] like this.
  29. May 1, 2017 at 11:50 AM
    Les7311
    I heard of the adjustable UCA before and started looking for one.... uncertain if actually needed for my 6inch lift
    Is it a must buy????
    Jsena likes this.
  30. May 1, 2017 at 1:40 PM
    Porschetech29
    Francis
    After your first alignment the vehicle drove straight but the right caster, should have cause a right pull. In theory caster will pull to the least positive. The second alignment was set up almost even left to right and now the hard left pull is occurring. This tells me you have a radial pull problem. You need to perform a tire rotation left to right to see if there is improvement. When I perform an alignment I like to set up camber as even as possible left to right and in spec. I like to set up caster with more on the right to compensate for road crown. The reason I compensate with caster and not camber is because camber can wear tires and caster typically will not.
