gear indicator lamp
Discussion in '1st Gen Tundras (2000-2006)' started by chunk, Mar 31, 2017.
  1. May 13, 2019 at 4:17 AM
    #61
    Professional Hand Model
    Fred
    Hand Protectors
    The panel light dome/sleeve, which the light bulb slips into, is green except for reverse which is yellow. No way to change the colors.
    TX-TRD1stGEN[QUOTED] likes this.
  2. May 13, 2019 at 9:57 AM
    #62
    FirstGenVol Brake Czar
    2002 AC
    Others have shown pictures of a bright blue cluster so it is possible to get blue. I think it was @Jerry311SD
  3. May 13, 2019 at 10:56 AM
    #63
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    The cluster backlighting is easy to do 00-04, it's the PRNDL lights that have the permanent "filters" I'll call them.
    You may be able to disassemble the cluster and sand off the color for them but I didn't look that closely at them
  4. May 13, 2019 at 11:20 AM
    #64
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
  5. Jul 9, 2020 at 7:59 AM
    #65
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    Maybe me and getting to old.
    But find I am just confused after reading the post. Some say led are to bright, different colors that might bleed other colors, some need modifications, etc...
    So I just want to play it safe and not take a chance.
    My D light is out. But would like to replace all the cluster bulbs once I have it out.
    Does anyone have the oem part numbers I would need. And how many of what type.
    And also only remove the cluster once. And make sure I have some bulbs I know will work like oem.
    So dont have to be LED's. And dont mind the oem price to make sure they are the right bulbs that fit.
    2003 Tundra SR5
    Thanks
  6. Jul 9, 2020 at 8:09 AM
    #66
    Fred
    Hand Protectors
    Check out the ‘1st Gen Info Dump’ pages. Believe there is a good write up there.
  7. Jul 9, 2020 at 10:46 AM
    #67
    CelticNomad
    CelticNomad New Member
    2000 SR5 Thunder Grey Tundra. Stock.
    Go with the superbrightleds NEO4-NWHP. I put them in my 2000 Tundra two years ago with positive results. https://www.superbrightleds.com/mor...ulb-high-power-instrument-panel-led/221/7737/
  8. Jul 9, 2020 at 5:20 PM
    #68
    RR60
    RR60 New Member
  9. Jul 9, 2020 at 6:30 PM
    #69
    CelticNomad
    I did not.
  10. Jul 10, 2020 at 11:58 AM
    #70
    Truper
    Truper New Member
    2002 Green Tundra TRD
    New headlamps.
    I replaced my Drive Indicator light several years ago (2002 Tundra). Ordered the new bulb from Amazon. Regular incandescent light, came with a removable green sleeve over the lamp. Part #90011-11032. I hope this helps.
    The link to the part in Amazon:
    https://www.amazon.com/s?k=Part+#90011-11032&ref=nb_sb_noss
    Also, I replaced my Cruise Control indicator lamp. That was part #83120-60020
    Bulb #TSD 74
    I also ordered them through Amazon, but I think you can get the TSD 74 bulbs pretty-much anywhere.
    The link to this part in Amazon:
    https://www.amazon.com/Toyota-83120...words=Part+#83120-60020&qid=1594407828&sr=8-1
  11. Oct 2, 2020 at 8:59 AM
    #71
    LuckyCharms
    LuckyCharms New Member
    You can solder new LED's on the board if you know how to solder.
  12. Oct 3, 2020 at 11:27 PM
    #72
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    So if I reading this thread right, the PRNDL, cruise, ABS, CEL, etc are #74 bulbs? Or are they neo4 style? My D light is going in/out and only turns on after I tap the top of the cluster. I have extra 194, T5 and 74 bulbs laying around.
  13. Oct 3, 2020 at 11:36 PM
    #73
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    On my 2002 the PRNDL and the OD are neowedge. I think it was a Neowedge 4 from superbrightleds.com. let me check, and I'll edit in 100% correct info from my receipts.
    Cruise, ABS, CEL are 74s.
    Check engine light (CEL,) battery light, low fuel light and the seat belt light have to be incandescent. I pulled my dash apart 3 times to correct all my mistakes. Please learn from mine.
    SouthPaw[QUOTED] likes this.
  14. Oct 3, 2020 at 11:44 PM
    #74
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @SouthPaw
    Here is a link to what I did with all my indicator lights.
    Too long, and didn't read. I used JB weld to cover the top diode on the 74s so they wouldn't be too bright. I drove for a week with my turn signals, and high beam light indicators BLINDING me at night.
    Here is what I used on the PRNDL with the Neo4.
    I also used a Neo3 on the foglight button.
    SouthPaw likes this.
  15. Oct 4, 2020 at 6:15 AM
    #75
    Fred
    Hand Protectors
    I don’t remember exactly the type of bulbs I replaced in the P and D sockets. I do know they are a special shape that fits up into the ‘bulbed’ portion of the cluster glass. With this being said, I ordered the OEM Bulbs ($10ish each) a couple years ago. They work perfect without adaptations.
    N84434 and SouthPaw[QUOTED] like this.
  16. Oct 7, 2020 at 5:25 PM
    #76
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Hmm...bought my 1st gen Tundra access cab used and the D light was out then, no telling how long it's been that way. Lot's of info here, should be a big help to those who can't stand having one little light out...I can count to 3 so I'm not gonna bother with it.
  17. Jan 22, 2022 at 11:38 AM
    #77
    Pudnhd
    Pudnhd New Member
    Tom
    2000 Tundra SR5
    Changing mine to blue as well. What size are the shift indicator lights?I must have missed it.
  18. Jan 22, 2022 at 11:10 PM
    #78
    dinosaur
    dinosaur New Member
    Dave
    2004 DC Tundra 4x4
    Better check again...it's in there! Where's that Raising the Dead meme @bmf4069? That cracks me up every time!:rofl:
    bmf4069 likes this.
  19. Jan 23, 2022 at 8:17 PM
    #79
    bmf4069 Yup, that's car parts in a dishwasher
    dinosaur[QUOTED] likes this.
  20. Dec 20, 2023 at 1:42 PM
    #80
    I agree. I looked through the info dump and stickies and didn't find anything on this topic. @ColoradoTJ can we get this stickied please?
    ColoradoTJ likes this.
  21. Dec 20, 2023 at 3:05 PM
    #81
    LML 3500HD
    :thumbsup:
    bmf4069[QUOTED] likes this.
  22. Dec 20, 2023 at 3:28 PM
    #82
    The Black Mamba
    The Black Mamba Black Sneks Matter
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Could have just asked @shifty` to add the part numbers to the mega thread or added a post about it in the info dump. But I guess a sticky works too. BTW a search lead me right to this thread in about 15 seconds
    bmf4069[QUOTED] and shifty` like this.
  23. Dec 20, 2023 at 5:11 PM
    #83
    I'm lazy.
  24. Dec 20, 2023 at 5:56 PM
    #84
    The Black Mamba
    DFW
    Imma keep it stock
    artsr2002 likes this.
