End Caps Color Match - Plasti Dip Primers
Discussion in 'General Tundra Discussion' started by polishfc, Jul 9, 2020.
  1. Jul 9, 2020 at 7:29 AM
    polishfc
    polishfc [OP] New Member
    Phil
    2017 Silver Sky Metallic Tundra
    Carven Exhaust
    I remember seeing a post a while back where someone used plasti dip as a primer when color matching the chrome bumper caps.
    Up to that point I was leaning towards the idea of wrapping but given the true color matched wrap was ridiculously expensive thought I consider this option. (Want something reversible) Plasti Dip and color matched paint seemed a lot more economical.
    I wondering if anything tried this out and can chime in on the pros cons, specifically longevity of using the plasti dip as a primer?
    tia
  2. Jul 9, 2020 at 7:40 AM
    tennisfreak
    tennisfreak New Member
    As a primer? What are you going to put on top of it?
    I use plasti dip on my grille and hood bulge. Just cleaned the chrome and directly applied it no sanding.
    4 good thick coats and it is holding up like a champ. Did it on my last truck as well.
    Hood bulge and grille took 2 cans for 4 coats. So for less than $10 you cant beat that!!!
    Black Wolf likes this.
