painting the platinum grill
Discussion in 'General Tundra Discussion' started by Motor71, Feb 10, 2017.
  1. Feb 10, 2017 at 2:38 AM
    Motor71
    Motor71 [OP] teufel hunden
    Rob
    New Jersey
    2016 tundra platinum
    TRD sway bar, matching mirror cover, 20% tint, esp aluminum box, Line-X premium, Undercover Flex tonneau cover, led interior lights, winjet smoked tail lights. Road armor rear bumper w/ road armor shackles, go rhino front bumper.
    anyone painted the insert of a platinum grill? if you did, did you sand it down first or just went with a cleaned insert? and what paint did you use? I'm deciding between the linex or a color match from duplicolor
  2. Feb 10, 2017 at 6:34 AM
    DPlatinum
    DPlatinum New Member
    DFW
    2017 Quicksand SR5 Doublecab 4x4
    Undercover Flex bed cover, Pro grille,2018 led headlights, bed step, console safe, Toytec/Eibach 3” front leveling shocks OEM painted to match fender flares, tow mirrors
    I just cleaned mine well, rubbed with alcohol and sprayed it with plastidip. I sprayed 4 coats of black and then 2 coats of metalizer. It came out really nice and has held up for about 1.5 years with no issues.
    Les7311 and Motor71[OP] like this.
  3. Feb 10, 2017 at 6:58 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Could you post some pictures?
  4. Feb 10, 2017 at 7:46 AM
    DPlatinum
    DFW
  5. Feb 10, 2017 at 8:18 AM
    Motor71
    Rob
    New Jersey
    thx, but i don't know if i wanna plastidip it....Plastipped other things before and it didn't turn out as good as i had hope for.
  6. Feb 10, 2017 at 8:27 AM
    Tun14dra
    Tun14dra New Member
    Carl
    How difficult was it to get the back side of the horizontal slats painted evenly? I've plasti-dipped wheels and emblems before but never a grill. I was debating on doing my Platinum as well.
  7. Feb 10, 2017 at 8:29 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  8. Feb 10, 2017 at 8:30 AM
    DPlatinum
    DFW
    Not difficult at all. I took the grill off where I could clean and prep it well.
  9. Feb 10, 2017 at 8:31 AM
    Tun14dra
    Tun14dra New Member
    Carl
    I guess that might be another project for the weekend then. Swapping the chrome handles and mirrors out tomorrow.
  10. Feb 10, 2017 at 11:26 AM
    hdfanatic
    hdfanatic New Member
    Kevin
    Pearland, TX
    2017 Barcelona Red Platinum Crewmax 4x4
    TRD Pro wheels, Nfab
    Plastidipped mine as well. I still go back and forth on whether or not I like the Pro grill or this more.
  11. Feb 10, 2017 at 11:29 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  12. Feb 13, 2017 at 1:03 PM
    Newm
    Newm New Member
    KC
    Just painted my Limited (same grille) insert this past weekend. Haven't installed it yet but it turned out way better than I expected.
    Lightly sanded it down then used SEM Trim Black prep and paint in satin. https://www.semproducts.com/manage/html/public/content/techsheets/NGTB_TrimBlack_0616_WEB.pdf
    Ended up doing 7 or so light coats but it turned out dang near perfect....and I am pretty OCD about stuff like that.
    Edit... pics aren't showing up, I'll get the fished product up tomorrow.
    Motor71[OP] and dandailey like this.
  13. Feb 17, 2017 at 8:00 AM
    Newm
    Newm New Member
    KC
    Here is my finished grille all painted....
    Sunnier, TNTundra08, HUTCHJ and 8 others like this.
  14. Feb 17, 2017 at 8:06 AM
    kicnit
    kicnit New Member
    14 Tundra TRD DC
    De-badged
    Looks great:headbang:
    Wish I had the limited/platinum insert instead of the SR5 one
    Kyle
    Newm likes this.
  15. Feb 17, 2017 at 11:33 AM
    dandailey
    Dan D
    Newport News Va.
    I was going to paint mine but the silver is kind of looking good to me.. was it hard removing the insert?
    Newm likes this.
  16. Feb 17, 2017 at 11:34 AM
    bobbilly
    bobbilly New Member
    Following!
    Newm likes this.
  17. Feb 17, 2017 at 12:23 PM
    Newm
    Newm New Member
    KC
    It isn't hard but it's a little tedious to get started. All you really need is a flat blade screwdriver (after removing the couple philips that you will see on the back of the insert that screws to the surround) and pry the little tabs free.
    Best advice I can give is lay it face down on a blanket so you don't scratch it and start prying loose the tabs in a upper corner of the grille. You will have to pry a couple and push/pull at the same time. Once you get the first couple the rest are a breeze as you will kind of know what you are trying to accomplish.
    dandailey[QUOTED] likes this.
  18. Feb 17, 2017 at 1:59 PM
    Motor71
    Rob
    New Jersey
    it was difficult for me, after a few broken tabs i just gave up.
  19. Jun 3, 2017 at 11:54 AM
    Tun14dra
    Tun14dra New Member
    Carl
    I taped mine off with painters tape and newspaper before I plasti-dipped mine.I attempted to remove the inner grill but decided it wasn't worth it.
    gasquetmike likes this.
  20. Jun 3, 2017 at 5:07 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    Why? Can make the sr5 one look good!
    AKJ78 and gasquetmike like this.
  21. Jun 4, 2017 at 9:38 AM
    Sporto
    Sporto New Member
    2014 Radiant Red Tundra Limited CM TRD
    Here's mine.
  22. Dec 7, 2019 at 12:03 AM
    Leetomnsx
    Leetomnsx New Member
    2016 Toyota Tundra Platinum
    Air lift, black out emblems, wheels, tonneau cover, tires, led lighting, hidden step rail, remote start.
    Can you post a pic of grill? What color truck?
