Cooling issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Duratund71, Jul 7, 2020.
  1. Jul 7, 2020 at 2:52 PM
    Duratund71
    Duratund71 [OP] New Member
    henry Bnaman
    Tundra 2016 SR5
    non
    My 2016 Tundra suddenly stop cooling . if I turn on the switch it is running perfect there is no leak but I don't yet cooling in the cab.
    can somebody help me with that? thanks.
  2. Jul 21, 2020 at 9:38 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check the condenser for damage a rock, bolt, nut or debris may have damaged it... Your system may be fine with no leaks, but if there is even a crack in the condenser you wont have freon in the system which equates to no cooling.
