Welcome to the Official SoCal BS/ Shenanigans, Tundras and What’s Happening Thread
Discussion in 'California' started by Sunnier, Dec 21, 2017.
  1. Jun 23, 2020 at 5:36 PM
    #8161
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    At first I thought that was the problem so I did this. I took my dremel and notched it so the wire clears it and that didn’t work. Worse case I’ll just put it in the sunglasses holder and hide it in there. Really didn’t wanna do that but I’m running out of solutions lol
  2. Jun 23, 2020 at 6:29 PM
    #8162
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Take out these 2 and see if it fits flush.
  3. Jun 23, 2020 at 6:30 PM
    #8163
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    It looks like the panel fits pretty good without the Switch-Pros installed. This makes me think the clearance issue is related to the harness or the mounting hardware. Without seeing it in person I’m just taking an educated guess.
  4. Jun 23, 2020 at 6:57 PM
    #8164
    fisherman951
    Tony
    2017 crewmax 4x4
    so I decided to take off the switch pro and Try again. came to the conclusion that it’s A problem with the mount. It’s still not snapping in place. Gave it more then a couple “love taps” and nothing
  5. Jun 23, 2020 at 7:04 PM
    #8165
    Porschetech29
    Francis
    Looks good in this pic
    Flyinryank and fisherman951 like this.
  6. Jun 23, 2020 at 7:06 PM
    #8166
    fisherman951
    Tony
    2017 crewmax 4x4
    That’s a different mount that I have a file for. Only problem is that it got 3D printed with PLA material and will warp in the heat. So really can’t use it as it gets hot in the summer time with the windows closed.
  7. Jun 23, 2020 at 11:56 PM
    #8167
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
    Haven’t seen one mounted there in person. Would be nice looking though! :thumbsup: Good luck Tony @fisherman, keep us posted on the results
  8. Jun 24, 2020 at 1:05 AM
    #8168
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    I’m just curious what is a diff
    Drop? I never heard that before
    831Tun[QUOTED] likes this.
  9. Jun 24, 2020 at 7:10 AM
    #8169
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's a spacer, 2 spacers actually, that change the angle of the front differential.
    BestGen likes this.
  10. Jun 25, 2020 at 8:54 PM
    #8170
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    I'm curious, has anyone here replaced the thin-walled aluminum rear driveshaft with a custom built steel unit?
    831Tun likes this.
  11. Jun 26, 2020 at 6:02 AM
    #8171
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    @Bo-Hunter had a custom length driveshaft made. I think it’s steel but I’m not sure. He said he’s very happy with it. Maybe he’ll chime in.
    831Tun and Sunnier[OP] like this.
  12. Jun 26, 2020 at 11:07 AM
    #8172
    fisherman951
    Tony
    2017 crewmax 4x4
    @Icon_Adrian is holding an event. Incase any one is interested
  13. Jun 26, 2020 at 11:19 AM
    #8173
    Sunnier
    Sunnier [OP] Pity the warrior that slays all his foes
    Sunny
    San Diego, CA
    Dude. You’re the guy I tag when I see this stuff. :boink:
  14. Jun 26, 2020 at 9:17 PM
    #8174
    Dirtfiend
    Dirtfiend New Member
    So.OC
    2019 SSM 5.7 Crew Max 4x4
    Bilstein 6112 front (2.5")/5160 rear Total Chaos UCAs Toytec Shackles 1" Method Roost 18x9 Falken Wildpeaks 295/70 R18 Carven Cat Back Exhaust Baja Designs Squadron Fogs (Amber) Stubby Antennae Blackout Badges/ Tailgate Insert Front Tint (20%) K&N Air Filter Gate King adjustable lift gate Color matched grille/bulge
    Cruised around in the Alabama Hills on the way up to Mammoth today. So many little trails to explore.
  15. Jun 29, 2020 at 1:09 PM
    #8175
    dittothat
    dittothat New Member
    SD
    2016 MGM Platinum
    Anyone in SoCal have a Bridgeport at their house?
  16. Jun 29, 2020 at 2:07 PM
    #8176
    Sunnier
    Sunny
    San Diego, CA
    Bridgeport what?
  17. Jun 29, 2020 at 2:13 PM
    #8177
    dittothat
    SD
    2016 MGM Platinum
    A Bridgeport mill or any mill for that matter. Had 4 pieces of plastic I need to mill out for a custom rack im building
  18. Jun 29, 2020 at 2:17 PM
    #8178
    Sunnier
    Sunny
    San Diego, CA
    Okay, thanks. I hope you get an offer!
  19. Jun 29, 2020 at 2:23 PM
    #8179
    dittothat
    SD
    2016 MGM Platinum
    Yeah, I’m hoping so too:fingerscrossed: Just looking to use it for an hour or so. Right now my options are: 1) find someone nice enough to let me use their mill, 2) buy a 3D printer and print the pieces or 3) get a membership to urban workshop and use their mill. 2 and 3 a pretty pricey for the little amount of work that needs to be done
  20. Jul 4, 2020 at 8:21 PM
    #8180
    Porschetech29
    Francis
    My tundra got a new parking spot today. Back to the IE for me.
  21. Jul 4, 2020 at 8:51 PM
    #8181
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Congratulations @Porschetech29
  22. Jul 4, 2020 at 9:09 PM
    #8182
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Congrats Francis. Your daughter's kinda stealing the spot light though.:)
  23. Jul 4, 2020 at 9:53 PM
    #8183
    fisherman951
    Tony
    2017 crewmax 4x4
    Congrats Francis!
  24. Jul 4, 2020 at 9:58 PM
    #8184
    Porschetech29
    Francis
    She is a cutie
  25. Jul 4, 2020 at 10:12 PM
    #8185
    Marty McFly
    Morty McBoonJug
    Beautiful house Francis :bowdown:
    The value of homes in the IE just went up now that the OG is back :benchpress:
    eccracer104, Pinay, 831Tun and 2 others like this.
  26. Jul 4, 2020 at 10:18 PM
    #8186
    Porschetech29
    Francis
    Haha you’re too funny. I’m not too far from you, we’re neighbors again.
  27. Jul 4, 2020 at 10:23 PM
    #8187
    Marty McFly
    Morty McBoonJug
    oh damn! You came back to your old stomping grounds :yay:
    congrats to you and the fam. I’ll be over there to borrow some sugar :laughing:
  28. Jul 4, 2020 at 11:24 PM
    #8188
    Sunnier
    Sunny
    San Diego, CA
    Good for you! :fistbump:
    Dang! Nice place. I maybe need to move up that way. Good neighbors and all....
    eccracer104 and Marty McFly like this.
  29. Jul 5, 2020 at 12:55 AM
    #8189
    Marty McFly
    Morty McBoonJug
    us poe folk can only dream of living the SD life :pout:
    But you can come join our humble little community :drunk:
    @nishibot @Mrs. Nishibot we are going to have to throw a welcome party for Francis and sunny lol
  30. Jul 5, 2020 at 7:23 AM
    #8190
    nishibot
    Perris, CA.
