Bf Goodrich mud terrain t/a km2
Discussion in 'Wheels & Tires' started by Beep88, Feb 12, 2017.
  1. Feb 12, 2017 at 7:48 PM
    Beep88
    Beep88 [OP] New Member
    I am thinking of buying a set bf Goodrich mud terrain t/a km2 in 285/70/18. Want to know if anyone has these and what they think of them? Do they take a lot of weight to balance up? Are they loud and how do they wear? I mainly drive on paved roads but occasionally get off road. There is not a whole lot of choices in 285/70/18! Thanks
  2. Feb 12, 2017 at 8:58 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    They will be loud and wear poorly. I had the KO2s for a while and after 10,000 miles they went from 15/32nds tread down to 5/32nds tread. They were smaller than advertised (LT265/70R-18) and chunked easily off-road. If you only occasionally go off-road an A/T would be a way better choice. I run the Nitto Exo Grapplers (LT285/70R18) and they've done great in everything except in thick mud. They're also rated for severe snow use. Falken makes another good A/T tire as does Toyo in the size that you desire.
  3. Feb 12, 2017 at 10:00 PM
    Beep88
    I am going to look into those nitto tires
