Exhaust system questions
Discussion in 'Performance and Tuning' started by Nstundra, Feb 11, 2017.
  1. Feb 11, 2017 at 5:22 AM
    Nstundra
    Nstundra [OP] New Member
    2014 tundra sr5 crew max
    Trd 2.5 lift wheels and tires fender flares bull bumper
    I am looking at putting a cai and an exhaust system on my truck. My question is I use my Bluetooth a lot due to traveling for work and am curious if anyone is having problems with exhaust drowning out their Bluetooth systems? What is a good exhaust system to get a good note but not be overly loud? I am new to the forum. I'm sure this question has been asked but I couldn't find anything.
  2. Feb 11, 2017 at 5:29 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    TRD
    ColoradoTJ and Nstundra[OP] like this.
  3. Feb 11, 2017 at 5:32 AM
    Nstundra
    I like the note of trd but I also love single out I know that sounds crazy I just prefer single out. Do they make the trd with single out
  4. Feb 11, 2017 at 5:36 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    17' Tundra SR5, 12' Tacoma TRD offroad
    Look in to corsa, I heloped a buddy install that system on his truck and it sounded amazing. Once I pick up a 2017 that's what's going on mine as well.
    MotoTundra and Nstundra[OP] like this.
  5. Feb 11, 2017 at 5:39 AM
    Nstundra
    So my other question has anyone had a problem with aftermarket exhaust drowning out their factory Bluetooth
  6. Feb 11, 2017 at 6:12 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
  7. Feb 11, 2017 at 6:49 AM
    DocC22
    DocC22 New Member
    2017 1794 TRD
    I know you said you wanted single out. Anyone reading this thread that doesn't mind double out, I could not recommend the TRD more!! It is perfect. Loud when you want and quiet when you want. I'm so glad I got it.
    joem1cha3l likes this.
  8. Feb 11, 2017 at 6:50 AM
    Nstundra
    Does the tes bolt right up or do you have to weld new hangers or anything to go to duals with it
  9. Feb 11, 2017 at 6:51 AM
    joem1cha3l
    Albany, NY
    TRD is a direct bolt on application. Most guys have the install complete in 30-45 minutes.
    Nstundra[QUOTED][OP] likes this.
  10. Feb 11, 2017 at 7:29 AM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    I have a single out corsa on mine and it's like a factory when you want and sounds great when you want. No drone.
    Nstundra[OP] and NewImprovedRon like this.
  11. Feb 11, 2017 at 7:33 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    No. I have a Flowmaster with upgraded pipes and never even a glitch.
  12. Feb 11, 2017 at 7:58 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    When you call Keith at 1-760-877-4234,he'll explain why our Tundras' keep all their low-end "grunt", by staying with the stock tailpipe. After having Corsa'a Touring catback with their 3" tailpipe ,on my 2010,I could tell a difference in responce off the line. After buying and installing Keith's 10" system and keeping Toyota's stock tailpipe,my low-end at idle and light throttle, returned. If you're after a system just a 'whisper' over stock, (untill you open 'er up):D then Keith's 10 or 12" single system will be ideal.My 10" catback is just right for me,even while towing.Call him and be prepared to learn more than you thought possible, about our Trucks exhaust:thumbsup:
  13. Feb 11, 2017 at 11:20 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    Agree, love mine too. Got it installed a week ago at 2,700 miles. I haven't sensed any loss in low end power either. Not doubting there may be a little, but if so it's nothing noticeable to me.
  14. Feb 11, 2017 at 11:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nope, not at all.
  15. Feb 11, 2017 at 7:30 PM
    Nstundra
    Thank you so much guys!!! I really appreciate all the info
  16. Feb 12, 2017 at 4:09 AM
    David P
    David P New Member
    Alabama
    2016 Toyota Tundra 4x4 CM Platinum
    BDS 7" lift with Fox coil overs and 2.5s in the rear, CB shackles w/ poly bushings, CB steering kit, CB poly rack bushings, Dakar rear leaf pack w/ CB poly bushings, Bushwacker paint to match fender flares,, Fab Fours premium bumpers font + rear, Fab Fours modular roof rack with lights all around, ARE Z series shell, BDS Traction control bars, Fuel Nutz 2 piece 22x10 wheels, Toyo MT 37X13.5, Spod overhead lighting control unit, Kenwood/JL Audio, Dynamat sound deadening throughout the cab, Morimoto 40" LED light bar hood bulge, Viper remote start alarm, Bully Dog tuner, S+B CAI, Retro'd HID Headlights, Morimoto 2-Stroke LED Fogs, Undercover tool boxes.
    If "loud" is somehow an expectation, I'd recommend TRD. Although you will get feedback about it's restrictive characteristics, it is held to a strict decibel and is IMO, tuned very well to stay within that while some of these other exhaust options do not. I have had the BA 8" system and although, it was of great quality, Keith is a great guy it was however louder than I wanted. I had it on my truck for 2 weeks before removing it. I wanted mild not wild. Since then, I have made it simple and decided to go with the TRD after hearing it in person. This is not to say that the truck isn't wild, my sound preferences aren't when it comes to exhaust. Music, yes.
  17. Feb 12, 2017 at 4:45 AM
    CMB
    CMB New Member
    Cecil County MD.
    It was only a guess that the 8" system was going to be too loud for me. After much research and telling Keith about how I liked my Corsa Touring system's sound,(even while towing) he recommended his 10" single in Stainless.That was over 3 years ago. Pulling the same boat over the same roads with the same load,the difference in low-end grunt between Corsa's 3" tailpipe and Toyota's stock size pipe became evident.Running around with an empty truck,not as much, but I still needed more throttle pressure, to get truck rolling with the Corsa System.On a Dual System according to Keith,adding an X-Pipe will help with "Grunt-Loss".My Brother has Keith's Dual System with TRD Pipes and is pleased with it. He "needed" a Dual Exhaust System!:D
    Nstundra[OP] likes this.
  18. Feb 12, 2017 at 8:58 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    thanks for the mentions guys.
    if trd sound is what you're looking for, and the low end torque of single exhaust, then get our 10" system.
    if something that I build is too loud or too quiet, let me know and I'll send a new on rebuilt louder or quieter based on your feedback, free.
    we are the only exhaust company that warranties the sound.
    and we are the only exhaust company that has literally 100's of options for a tundra and will custom build the perfect system for you and your use of the truck. Your system won't cost an arm and a leg either:)
    Keith 760-877-4234www.dirtydeedsindustries.com
  19. Feb 12, 2017 at 9:06 AM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Knew you were a great guy Keith, but WOW ! Good luck finding another exhaust company to warranty the sound ! That's why Keith's name is so big in the exhaust industry. Keep up the great work my friend. :oldglory:
  20. Feb 12, 2017 at 2:59 PM
    Nstundra
    Keith give me a couple of weeks and I'll be contacting you. After reading your comment you have me won over I may call you torrow and get some pricing from ya so I know what I'm looking at
  21. Feb 12, 2017 at 7:12 PM
    PMG
    PMG New Member
    Makes me wish I jumped on the Thanksgiving deal he had on exhausts . Is it November yet?
    PMG
  22. Feb 12, 2017 at 9:32 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    As someone that buys a lot of aftermarket stuff for the various rides - that has to be the best guarantee and situation I've seen.....ever.
    Well done Sir...
    dirtydeeds[QUOTED] likes this.
  23. Feb 13, 2017 at 5:05 PM
    dirtydeeds
    Keith
    USA
    Give a call. I'll be here.
