Jacks for Off-Road Tire Changing
Discussion in 'Recovery & Gear' started by equin, May 15, 2020.
  1. May 24, 2020 at 10:19 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Struggled with getting the 2 ton big wheel vs the 3 ton because the difference in price was only $60 or so but what I have will def do the job and its easier to transport and store
    equin[QUOTED][OP] likes this.
  2. May 24, 2020 at 10:27 PM
    GravityGear
    Aurora, CO
    I've seen some Eaz-Lift RV jacks out at KoH. I've seen some racers use them. Haven't tried one myself though. They come in 30", so they should be able to get some big tires with big travel off the ground.
    Pro Eagle is probably the primo jack solution right now.
    ES Motorsports also has a steroid scissor jack if you're the overkill type.
    equin[OP] and texasrho83 like this.
  3. Jun 11, 2020 at 6:20 AM
    msikk
    msikk New Member
    I'm currently debating between the Safe Jack or Pro Eagle. Quite a bit of a price difference, and it looks like either will work great. Decisions, decisions.
    equin[OP] and Rica25 like this.
  4. Jun 11, 2020 at 8:54 AM
    ExpeditionPhoenix
    ExpeditionPhoenix New Member
    Utah
    2019 TRD Pro
    I debated between the Safe Jack and Pro Eagle for a bit. The Safe Jack was cheaper and lighter while the Pro Eagle was substantially more expensive and heavier. I ultimately went with the Pro Eagle 2 Ton Beast mainly because of its durability and ease of use with fewer parts to put together when all you want is to raise your truck wheel quickly and efficiently. The Pro Eagle does fit into the Decked drawer system, but you have to use the plastic stopper it ships with to keep the jack attachment down/level and then load it in the Decked drawer upside down because the wheels wheel ride on the raised part of the bottom of the drawer if you don't making it a few centimeters too high to close the drawer.
    equin[OP] likes this.
  5. Jun 11, 2020 at 4:19 PM
    TXTundra2722
    2015 Black Tundra
    Anyone know which extension will work on regular jacks? Like the extension that comes on the pro eagle? I've seen pics of a few months ago but haven't heard anyone talk about it.
  6. Jun 11, 2020 at 4:27 PM
    GravityGear
    Aurora, CO
  7. Jun 11, 2020 at 6:49 PM
    msikk
    msikk New Member
    Thanks for the info. I am very interested in the Pro Eagle and the Decked system. After reading your post, seems like a good combo!
  8. Jun 4, 2022 at 1:12 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Sorry to revive an old thread, but is that the pro eagle extension? If so what did you use to bolt it on (looks like a different head)?
  9. Jun 4, 2022 at 1:17 PM
    737fixer
    737fixer New Member
    I use something crazy. The original jack that already sits in your truck and an $8 2x6 piece of lumber from Home Depot that can be cut into as many pieces you need.
  10. Jun 4, 2022 at 2:19 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
  11. Jun 6, 2022 at 4:30 PM
    Paladin
    Paladin New Member
    Andy
    Arizona
    06 Tundra DC & 13 4Runner Trail
    Safejack has an off-road kit I was looking at. Has some risers/spacers included
