Best Gen-ECGS bushing tool
Discussion in '1st Gen Tundras (2000-2006)' started by FrenchToasty, Jan 4, 2020.
  1. Jan 24, 2020 at 2:55 PM
    FrenchToasty [OP] The Desert rat, 6 lug enthusiast
    The SoAz
    None
    It’s a rather simple process. The reason I didn’t do any kind of write up is;
    I’m not very articulate with words or being able to describe things sometimes, I didn’t have any confusion on what to do because there is already a well done video that explains in detail every single process from start to finish. I didn’t feel the need to beat a dead horse, especially if that horse was already put down in such a great video; way better than I could ever try and type it up. I also usually work alone and am under somewhat of a time restraint, so I’m just trying to get the job done, not a picture shoot. if there were a local member that needed this done/help, shoot yeah I would take better pictures and try to do a step by step. I just found it easier to press pause and play on TTM video.
    Tundra2, 02goes, speedtre and 5 others like this.
  2. Jan 27, 2020 at 12:20 PM
    FirstGenVol Brake Czar
    2002 AC
    Did you figure this out yet? If not, I found this in the manual if it helps.
  3. Jan 27, 2020 at 12:33 PM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Yeah the bushing is far enough I think, getting the new seal seated to the right depth is a bit of a challenge.
  4. Jan 27, 2020 at 12:36 PM
    Whothefat
    Clark
    Las Vegas
    This part of my CV axle is slightly bent, probably from when I was trying to get it out the first time. Could this cause the leaking? I assumed it was coming from inside where the shaft meets the seal.
  5. Jan 27, 2020 at 12:38 PM
    The SoAz
    None
    I doubt that would cause the leak, it might have been that the seal wasn’t in far enough
  6. Jan 27, 2020 at 12:41 PM
    Whothefat
    Clark
    Las Vegas
    i just pulled the seal now, it seemed like it was flush with the lip of the diff, but Maybe it wasn’t 100% square or all the way seated. Going for it again now.
  7. Jan 27, 2020 at 3:34 PM
    bmf4069 Yup, that's car parts in a dishwasher
    Did you put a tiny coat of lube on it before installation? Don't wanna go in dry!
    Jack McCarthy and Darkness like this.
  8. Jan 27, 2020 at 3:39 PM
    The SoAz
    None
    Good tip........
    Haha
    I think I went dry, but I know I played with the passenger seal to much and messed it up, I will remember to do that next time!!!
    Whothefat likes this.
  9. Jan 27, 2020 at 6:36 PM
    Whothefat
    Clark
    Las Vegas
    I did grease it both times. I have the seal in now and the axle, it’s not leaking the fluid that was left in there yet. I haven’t put the knuckle back on yet as I ran into some issues with my press while doing the wheel bearing!
    You just use a little all purpose grease or something special?
  10. Jan 27, 2020 at 7:40 PM
    With seals I use whatever they're going in or assy lube. So axle seals get diff juice, cam seals get oil, etc.
    Tundra2, chrisb, tvpierce and 2 others like this.
  11. Jan 27, 2020 at 9:25 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    I had a similar issue, cv diff seal was pressed in too far, or not evenly pressed in. The axle dust seal that u have bent may also be an issue. When axle is installed all the way in the dust seal mates with the axle seal in the groove to prevent any leaks(seals). If the diff seal pressed too far in a gap may be present and leaks, if dust seal is significantly bent it may cause a gap to occur and wont properly seal the two surfaces.
  12. Jan 28, 2020 at 6:13 PM
    Whothefat
    Clark
    Las Vegas
    Well I got it back together, minus the brakes because I was following the A1 Auto video doing my wheel bearing and broke my rotor! Waiting for my new rotors and pads to come in so I can button it all back up and hope for no leaks and no more WAWAWA from the wheel bearing.
  13. Feb 18, 2020 at 2:49 PM
    The SoAz
    None
    Tool is back from its last journey, and ready for the next one. PM me your info and I’ll get it in the mail.
  14. Mar 12, 2020 at 4:39 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    For those that had a bad needle bearing, could you describe the symptoms? Lately something in my front end is creaking and popping sometimes when I brake or turn. It started at an off road park 2 weeks ago and a day or two after swapping the passenger CV. Sometimes the truck would pop out of 4hi off road that weekend.
    I also didn't top off the fluid after because my buddy that did the CV swap said I didn't lose much and it would be fine.
    I've lubed my ubjs and can't seem to find a way to lube my lbjs. I'm just trying to rule out some things. My driver CV has a torn boot and I have a replacement as well as ECGS bushing waiting to install. Any advice?
  15. Mar 12, 2020 at 5:57 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    the #1 tell tale way to see if the needle bearing is bad is while driving throw it in 4hi and the vibration noise should stop almost immediately...then (still while driving) take it out of 4hi and the noise should come back within a few seconds.
    If yours keeps popping out of 4hi I think you have other issues.
    bmf4069 and FrenchToasty[OP] like this.
  16. Mar 12, 2020 at 6:03 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I'm still deciding if I wanna tackle it myself or see if a local shop cares to do it for me for a decent price. I typically go to check out prices, get floored at their astronomical prices for simple jobs, and then do them myself and save a bazillion dollars.
    I'd have to buy a few things to do this one and I really don't care to have a leaky seal after it's all said and done so I keep shying away from the job. Wish someone was local to me that I could feed beer to through a sippystraw while they do the job for me. :D
    FrenchToasty[OP] likes this.
  17. May 10, 2020 at 6:43 PM
    2002 AC
    French,
    What's the current status of this tool? Is this one just for removal? Looks like they sell both.
    Thanks
  18. May 10, 2020 at 6:49 PM
    The SoAz
    None
    I have the removal, the insertion tool, and a seal drive as well
  19. May 11, 2020 at 6:33 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    You can grease anything with a boot with one of these. Sometimes you get a tie rod end or a ball joint that doesn't have a zerk fitting. This just pokes into the boot and makes a very small self closing slit, not a hole. You can then fill the boot with grease. It's basically a hypodermic needle for a grease gun.
  20. May 14, 2020 at 7:38 AM
    #50
    2002 AC
    I've got the ECGS bushing ordered. Man, they get you on shipping! I'll hit you up when I'm ready to make the repair @FrenchToasty Once again, really nice of you to offer this.
    FrenchToasty[OP], bmf4069 and CodyP like this.
  21. May 14, 2020 at 7:57 AM
    #51
    The SoAz
    None
    Any time. Your at the top of the list and no one below, your good to go
    bmf4069 likes this.
  22. May 14, 2020 at 9:03 AM
    #52
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I’ve been sitting on this bushing for months and really don’t wanna tackle it. Probably will need to replace my half axle at the same time but don’t wanna spend the money.
  23. May 14, 2020 at 10:56 AM
    #53
    So if one were to replace both cv axles, this is a recommended preventative maintenance?
  24. May 14, 2020 at 11:46 AM
    #54
    The SoAz
    None
    Would you be doing the install or a shop? It’s only an extra hour or so on top of changing out axels. So not much more in labor costs if done at a shop. If your doing it yourself and don’t mind doing the work, it’s still probably better to do it while your already in that deep
    go under and feel how much slop is in the driver side. There will be some regardless, but how sloppy is she?
    bmf4069[QUOTED] likes this.
  25. May 18, 2020 at 9:33 PM
    #55
    Yeah, it'd be me doing it. I haven't checked, but I bet it's nice and sloppy.
  26. Jun 1, 2020 at 8:58 AM
    #56
    2002 AC
    Did you ever figure out why your seal started leaking? I drove in the seal as far as I could. Hopefully I didn't go too far. I didn't replace the seal on the passenger side but now it looks like it might be leaking so I may have to re-do it.
    Honestly, replacing the needle bearing was a lot easier than I was expecting. I didn't even use a magnet to seat the tool like they recommend in the videos. It was a little challenging to drive in the new ECGS bushing at first. I eventually realized I wasn't smacking it hard enough. Once I got it going it was fairly easy.
    The part I struggled with the most was getting both axles back into the diff. I finally figured out my technique was wrong and got it figured out.
    bmf4069 and CodyP[QUOTED] like this.
  27. Jun 5, 2020 at 4:20 PM
    #57
    The SoAz
    None
    Tool is back home, thanks @FirstGenVol for the return goodies! Everything was in one piece! Is that a local brewery? I like the fish on the logo, pretty pretty pretty cool!
  28. Jun 5, 2020 at 6:10 PM
    #58
    2002 AC
    It's a long story but Bells is actually out of Michigan. They have great beer.
  29. Jul 20, 2020 at 10:19 PM
    #59
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Argh. I just need to do this so I can stop looking at the ECGS bushing sitting on my shelf. I think I need to order an axle seal though right?
  30. Jul 21, 2020 at 5:22 AM
    #60
    The SoAz
    None
    Yeah it’s reccomended to replace the seal, there isn’t a nice way to take it out or save it when you remove the needle bearing
