Airbag Spacer - Has anyone tried it before??
Discussion in 'Sequoia Builds' started by STEEV11, Apr 22, 2020.
  1. Apr 22, 2020 at 9:52 AM
    STEEV11
    STEEV11 [OP] New Member
    2011 Platinum - 55k Miles
    Rev Tech lift - Bilstein 5100 - N-Fab LED mounts
    I am looking at retaining the stock airbags in the rear on my platinum but I do not like the ride quality with them in the fully inflated position. I raised the sensor to level out the rig after installing the 2.5 inch lift on the front.
    The ride quality is horrible now and I am looking to install a 4 inch spacer and lower the sensor back to its stock position.
    Has anyone tried this before?
  2. Apr 22, 2020 at 4:09 PM
    STEEV11
    Here are some pictures to further explain what I am thinking about.
    The first picture shows the part that I am looking to install to achieve the lift without getting rid of the airbag system.
    Here is where I am thinking of installing these parts
    The bottom is held on by a single bolt as far as I can see. If anyone knows better please let me know.
    My thought process is that I can deflate the bag by removing the line from the compressor. Jack up the rig and let the suspension drop all the way and install the spacer plate. Simple Right...
  3. Apr 22, 2020 at 4:20 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    Not familiar with the suspension setup on a Sequoia- but what u say sounds right ??
    Hopefully someone with Sequoia knowledge will chime in and help u out bud
    GLWI
  4. Nov 22, 2020 at 6:26 AM
    mb6355
    mb6355 New Member
    2006 Tundra DoubleCab
    Do you have a link to that kit? is a generic or specific to the Sequoia? Just bought a Platinum and have the same questions about this.
  5. Apr 8, 2021 at 9:46 AM
    BobChrisCryptos777
    BobChrisCryptos777 New Member
    Bob
    '08 Sequoia Limited 4x4
    '14 Tundra front struts (+1.5"), Bilstein 5100's on all four, adjusted position brackets for rear air-ride(+1.5"ish)(*want to delete airbags*!), XD 18" with 275/70/18(want to go bigger! maybe on 17's?!)
    Did you give it a try? I'm very interested!
  6. Apr 14, 2021 at 6:09 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    Also interested.
  7. Apr 14, 2021 at 8:13 PM
    Karambit
    Karambit New Member
    2008 Toyota Sequoia Limited
  8. Apr 15, 2021 at 6:37 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
  9. Apr 15, 2021 at 6:46 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Yes.
    I’ve had them on my last two tundras.
    they work as intended.
    @Coachbuilder1 makes them as well.
  10. Apr 15, 2021 at 6:53 AM
    bflooks
    bflooks New Member
    Metrowest MA
    2019 Silver Sky Metallic Tundra Limited
    Nitro 5.29s Powertrax Grip Pro Bilstein 5100 middle setting CB shims (2 driver, 1 passenger) Bilstein 5160 rears Firestone Ride-Rite bags Daystar cradles Roadmaster Active Suspension (RAS) HD TRD rear sway bar 18" TRD wheels 275/70r18 Falken Wildpeak AT3W X2 Power Group 24 battery Power fold tow mirror (OEM) Genuine Cooling Systems Setrab kit Valhalla's Shields (front/rear) Dirty Deeds Bamf 12" Stainless
  11. Apr 21, 2021 at 8:10 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    I am in the same boat, months ago, and I am thinking of using the Daystar Airbag cradle with aluminum shims and installing a longer bolt to secure the bag. Hopefully I'll be able to start this part of the project this spring.
    https://www.daystarweb.com/product/air-bag-cradle-polyurethane-black
  12. Mar 30, 2022 at 1:17 PM
    truckeesequoia
    truckeesequoia New Member
    2012 Sequoia Platinum
    Has anyone on this thread installed airbag spacers?
    I have a 2012 sequoia platinum. My toyota indie mechanic says this will be no problem and they install these on pickups all the time. They haven't installed on a sequoia before, however (mechanic says that is purely due to there being so few sequoias that get lifted). Would be great to hear from anyone who has done this.
  13. Apr 2, 2022 at 3:41 AM
    SprinterAE86
    Ian
    Hopefully in the nest few weeks once the snow stops falling. I will be making my own spacer for mine. Right now, I just have the air pumped up by adjusting the level switch to the max. Rougher ride, but still solid.
  14. Apr 2, 2022 at 2:07 PM
    truckeesequoia
    thanks for the reply. Any reason you are making your own when a kit is only $84?
    Seems like no downside to installing airbag spacers (ie. easy to remove with no new holes) and may even extend the life of the airbags, so I’m just surprised there aren’t more posts about people installing these on platinum sequoias. There are plenty of posts about tundra owners adding airbags and spacers to their trucks, so seems like we are already 90% there with the airbags factory installed.
  15. Apr 4, 2022 at 6:14 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    I think their aren't more posts because all of the set's I've researched specifically say, "not compatible with rear air bags on Toyota Sequoia Platinum trim."
    Like you said, the kits aren't expensive and I'm not completely sure why every set isn't compatible with the Platinum. I've been researching this for quite a while and still haven't come across anything that states it's compatible.
    Would be extremely interested if you have a link of a kit you've found that is compatible.
  16. Apr 4, 2022 at 12:03 PM
    truckeesequoia
    Thanks that’s really helpful to know you’ve already researched this extensively. I’m going to see what my Toyota mechanic can find out. He owes me a favor after I trained him up on techstream.
  17. Apr 5, 2022 at 5:55 AM
    Adamdsgn
    Adamdsgn New Member
    2018 Toyota Sequoia
    Please report back with your findings. Not sure why the current kits on the market wouldn't work, but I'm not dropping $100 on something that may work and I can't return.
    I have friends with 3D printers who have offered to take measurements and print spacers, but just haven't gotten around to it.
  18. Sep 29, 2022 at 10:52 PM
    UtahBlues
    UtahBlues New Member
    Jon
    Park City, Utah
    2012 Sequoia SR5
    Contact Tandem Offroad. Jonathan has the bags figured out. I have coils but he let me drive his (bags) while they were working on mine.
    Driving his made me wish I had the bags.
    Tandemoffroad.com
  19. Dec 7, 2022 at 11:52 AM
    truckeesequoia
    @UtahBlues thanks for the update. I have been looking into the spacers and just ordered from Tandem. Have talked with two owners who have these spacers on their Platinums and they are fans. Plus really cool seeing Tandem running the spacers on their main offroad vehicle they use to test all of their Sequoia parts. Still need to decide on suspension (that can get so pricey). Planning to reach out to Jonathan on that.
    @Adamdsgn found this video detailing the install of the spacers. Really well-explained and makes me feel more confident in doing it myself without damaging the delicate clips or airbag tube: https://www.youtube.com/watch?v=g9jfJ9QoQTw
  20. Dec 12, 2022 at 2:35 PM
    EastTexas Overland Guy
    EastTexas Overland Guy New Member
    none yet
  21. Dec 12, 2022 at 4:03 PM
    truckeesequoia
  22. Dec 25, 2022 at 6:57 PM
    danagin
    danagin New Member
    I appreciate what Tandem is doing, but dang at some of those prices. I know it's a lot of R&D on their part as well as a supply and demand thing (there just aren't a ton of Seq's to begin with, much less Platinum's). $350 isn't much all in all, but it's a large hockey puck and some other simple components... I got a 2018 like Jonathan's. $2300 for a bumper supporting sensors, new gears, other suspension parts, wheels, tires. That doesn't include many other things I'll need for sleeping, storage, ect. I was hoping to stay around $10k... I foresee a great many marital issues in my future haha.
    @truckeesequoia Let us know how it goes.
  23. Dec 25, 2022 at 9:37 PM
    truckeesequoia
    Yea man I’m with you. Ain’t cheap. The tandem spacers I ordered exactly a month ago still haven’t shipped, so can’t report back yet. Figured I would have them by now.
  24. Jan 29, 2023 at 6:48 PM
    Bitzbp
    Bitzbp New Member
    Finally got my Tandem spacers and they look well made. I thought about making my own but the Tandem ones come with brackets for the sensors as well and people seemed to be pleased with them. Ill be installing them when I get a warm day along with my TRD Pro Fox suspension.
    J.Sif and hoof hearted like this.
  25. Mar 16, 2023 at 8:08 PM
    QueenCityNation
    QueenCityNation New Member
    Bitzbp give us a picture of the truck with lift! Interested in how it turned out!
