Strange exhaust noise
Discussion in 'Performance and Tuning' started by Spoony1, Nov 8, 2016.
  1. Nov 8, 2016 at 3:53 PM
    Spoony1
    Spoony1 [OP] New Member
    2016 tundra platinum crewmax
    Trd pro grill color match door handles and mirror. 4 1/2 bds lift
    I have a 2016 platinum had the Trd exhaust added at the dealer. Was wondering if any of you guys experienced this problem. I am not sure how to describe it other than to say it is like the sound you get when you have one of your windows cracked open.
  2. Nov 8, 2016 at 4:00 PM
    Can you record it? Is there a tapping? (Leak)
  3. Nov 8, 2016 at 4:07 PM
    Royalpeeps
    Royalpeeps Awesome!!!
    Chad
    2017 Blazing Blue Pear Tundra SR5 TRD Package
    20" Fuel Vapor wheels 35" Toyo A/T II Tires 3 inch Toytec Boss kit with SPC UCA NFAB Wheel to Wheel Black Textured Nurf Bars OCD Center Storage Organizer and tray
    Hey don't want to hijack your thread but then don't want to post another one about noises. But speaking of noises. I walked out into my garage the other day and the truck wasn't on. Keys in my pocket and there was a noise coming from back where the spare tire is. Like something was running. Electrically. Like a humming noise. I got in and started the truck and turned it off and it stopped. Any ideas?
  4. Nov 8, 2016 at 4:10 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    That's your evap system. Completely normal... freaked me out too first time I heard it.
    PermaFrostTRD likes this.
  5. Nov 8, 2016 at 4:11 PM
    Royalpeeps
    Chad
    So it just turns on?
  6. Nov 8, 2016 at 4:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    yup, in the middle of the night for no apparent reason
    T-Rex266 and Royalpeeps like this.
  7. Nov 8, 2016 at 4:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    was it a whistling sound? Did they add a CAI?
  8. Nov 8, 2016 at 4:23 PM
    Spoony1
    I'll try and record it tommorow. But def isn't whistling almost sounds like the engine is missing but it runs fine and not throwing and codes. It only has 1400 miles on it going to call the dealer this week.
  9. Nov 8, 2016 at 5:56 PM
    Yep.
    TXRailRoadBandit73 likes this.
  10. Nov 8, 2016 at 7:24 PM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    Makes me want to stay up all night just so I can say I heard it!
    MatthewPTguy and joonbug[QUOTED] like this.
  11. Jan 30, 2017 at 5:00 AM
    NickyF25
    NickyF25 New Member
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    I'm seriously considering the TRD Dual Exhaust. Did you ever figure out what the strange noise was, or did it just need further breaking in?
  12. Jan 30, 2017 at 5:16 AM
    Spoony1
    I had it back to the dealer they said they didn't find anything but the noise has stopped. I don't think you will be disappointed with the Trd exhaust. If I had to make a guess I would say there was something loose on mine and they just tell me but I don't really care sounds great now.
  13. Jan 30, 2017 at 10:11 AM
    15whtrd
    15whtrd Mr. Blonde
    The TRD exhaust is known to make that chopper sound. And H pipe would cure it. It's because it is a true dual system and no crossover pipe. So at certain RPMs that sound is going to happen. I don't have a TRD exhaust but I hear it on every tundra that has one .
  14. Jan 30, 2017 at 4:19 PM
    Peck1631
    Peck1631 New Member
    Terry
    2017 crew max
    Trd dual exhaust, cold air intake
    I heard it on mine too. I swear at certain rpm's it sounds like an engine missing a cylinder.
  15. Jun 17, 2017 at 6:20 PM
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    Where would you install the H pipe? Between the pipes coming from the exhaust manifold? Between the pipes right before the mufflers? Between the pipes after the mufflers? Does it matter?
  16. Jun 17, 2017 at 7:38 PM
    15whtrd
    15whtrd Mr. Blonde
    I don't think it really matters but it seems like I've seen them mostly before the mufflers. I'm sure wherever you can fit it, it would help.
    Check out the set ups on dirtydeeds site.
    http://dirtydeedsindustries.com/product-category/toyota-tundra/
    walter93[QUOTED] likes this.
  17. Jul 14, 2017 at 9:12 PM
    Borgs
    Borgs New Member
    PA
    2017 Limited Crew TRD Off-Road
    Pro Grill and Bulge TRD sway BAK MX4 Tonneau
    Mine too. Just got mine installed this week. Sounds like it is missing. Did yours ever stop?
  18. Jul 14, 2017 at 9:13 PM
    Borgs
    Borgs New Member
    PA
    Is yours still sounding good?
  19. Jul 15, 2017 at 6:31 AM
    I have yet to hear this as well
