Changed four quick struts in Venza now what’s up?
Discussion in 'Other Toyota Vehicles' started by Dabutcher, Apr 18, 2020.
  1. Apr 18, 2020 at 6:12 PM
    Dabutcher
    Dabutcher [OP] New Member
    D
    Twin Cities
    2008 Nautical Blue Tundra SR5 CM 4x4 Beauty
    Toytec Boss coilover, Ray10’s ,Ridge Grapplers,Bilstein 5100,BAM 8”,TRD sway,
    Toyota Venza with 130K and the suspension was sucking so I bought four KYB quick struts and replaced all of them and the little rods that you cannot get off because of rust. You need to cut them off. Now I hear a noise. Threw out old struts a month ago. I removed all wheels today to check my work. Everything looks correct and tight. Seems like noise is coming from top of strut?
    I was just wondering if the top three nuts need washers? There are two grey washers out of three nuts? I was just wondering if the third one got moved and is what is making the noise? I hope one of my new struts is not defective? I bought the brand Toyota used. Thanks for any help. D0F7494EE-B527-4840-BFFB-B93CA1C330E0.jpg0A324477-810D-4120-AADE-06D628B533F3.jpg
  2. Apr 29, 2020 at 1:21 PM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Is that a strut tower support brace under 2 of them, going over to the other side? Then I can see why those would have a washer. But usually strut top nuts don't use washers, they just go right onto the tower.
    What kind of noise is it? Like a creak?
  3. Apr 30, 2020 at 3:01 AM
    Dabutcher
    D
    Twin Cities
    Yes. Like a creaking noise. Thanks
  4. Apr 30, 2020 at 7:59 AM
    crikeymike
    Hmmmm. Maybe they didn't get the top bushings and washers lined up properly when they assembled them. Creaking is usually metal on metal contact in my experience, so it could be the shaft of the strut contacting the top mount. That would eventually look like these photos attached.
    But since they were factory assembled, I can't see why they would do it wrong.
  5. May 5, 2020 at 4:41 PM
    Dabutcher
    D
    Twin Cities
    Thanks for the help. I just ordered two front new ones and will swap them out . Hopefully that fixes problem. Then I will return defective ones for refund to Rock Auto. Peace. D
    crikeymike likes this.
  6. May 11, 2020 at 6:09 PM
    Dabutcher
    D
    Twin Cities
    Swapped out both front quick struts. Same freakin noise? What a PITA. Peace. D
  7. May 11, 2020 at 6:25 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I've seen @empty_lord commenting on some peoples other Toyota vehicle problems lately. Seems to know his stuff. Maybe he can help, I think he's a Toyota Master Tech?
  8. May 11, 2020 at 7:08 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Maybe spray lube the heck out of everything rubber on the vehicle?
  9. May 11, 2020 at 9:23 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Did you replace the strut mounts? They’re wonderful for making noise if not
    EDIT: I’m blind and missed the quick strut part. Most likely a bad upper mount. Warranty it and go from there
  10. May 16, 2020 at 5:18 AM
    Dabutcher
    D
    Twin Cities
    Installed the to new strut-plus and same noise. Messed with everything for five more days and said screw it. Took car to my local go to guys little shop. The little control arms I replaced were both not on tight enough. $45.00 and I am a happy camper. Thanks for all the help.
    Love yours. D
