2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Apr 8, 2020 at 2:40 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Nope, me too!:D
  2. Apr 8, 2020 at 5:36 AM
    55kcement
    55kcement New Member
    Troy
    Sonora ca
    2020 TRD Off Road limited Double cab
    Currently none
    Obviously , people don’t live on hills ! Lol
    Rica25 likes this.
  3. Apr 8, 2020 at 5:37 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    They had the Germans engineer it. It’s on the other side.:D
    Rica25 and Cpl_Punishment like this.
  4. Apr 8, 2020 at 5:38 AM
    Fiesta346
    Fiesta346 New Member
    PA
    2013 Rock Warrior
    the inside is awesome but wtf on the outside is that ridgeline
    Rica25 likes this.
  5. Apr 8, 2020 at 5:45 AM
    Kung
    KG, VA
    I'm the other guy. I live in the Ozarks and there are places where the hills are ridiculous enough that instead of up/downshifting every 10 seconds on a hill, I'd rather just keep it in 4th or so; I tend to believe that for those occasions revving a bit more than usual is better than 2 upshifts/downshifts every 10 seconds.
    Cpl_Punishment and CMB like this.
  6. Apr 8, 2020 at 5:55 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    As we've learned from the 3.5EB, a TT V6 will get good fuel economy unloaded but under load it's no better than any other engine and can actually be worse than some OHV engines. I'd actually be interested to see an OHV version of the 5.7, though I'm sure it will never happen.
  7. Apr 8, 2020 at 5:57 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I get that everyone is anxious to know what the new Tundra will look like, but these articles that have hypothetical renderings are silly. It's like that previous rendering of the red Tundra with the Highlander front end. I still come across people claiming "this is what the new Tundra looks like!" People assume it's all real.
  8. Apr 8, 2020 at 6:02 AM
    CMB
    CMB New Member
    Cecil County MD.
    Transmission Techs have told me the constant shifting up and down on a Torque Converter that doesn't have a chance to lock, is a great way to create "fluid-frying" heat. I've owned 2 Cummins powered trucks with Automatic Transmissions, so I've talked to quite a few Techs! Choosing a proper gear for speed,load and road conditions, is a foreign concept for the "do it for me" mentality of today though.:D
  9. Apr 8, 2020 at 7:43 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    That's the only thing I use it for.
  10. Apr 8, 2020 at 8:12 AM
    LlamaResistance
    LlamaResistance Member
    Concord, CA
    2017 White Crewmax SR5 TRD Offroad
    MLED Retrofitted Platinum Headlights, Ranch Hand bumper, Firestone airsprings, Leer 100XR Shell, Amp Research Steps
    Why do you want to go backwards in design? OHV cam in block has limitations that OHC do not. Packaging isn't an issue here with the size of the engine bay and head flow would be hurt by going to an OHV design without a complex rocker arm arrangement to maintain the 4 valve per cylinder design that allows for good flow.
    The interior shot looks directly out of the 2020 Highlander, look at the dash shape and cubbyholes below the radio and passenger airbag. In fact once you goto their page, it is a photo from a Highlander, just to illustrate the speculated headunit design they think would be used.
    Terndrerrr likes this.
  11. Apr 8, 2020 at 8:43 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    This is the frustrating thing for me about the 6 speed we have. I swear the only time the TC is locked is in 6th gear cruising.
    I've only had my truck for 4 months now, but I'd trade up for the manual if it was ever available. It'd probably be a lot smarter financially to get the OVTune...
  12. Apr 8, 2020 at 8:59 AM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    I thought the TC could only lock in 4th gear and below, which is why they recommend towing in S4.
  13. Apr 8, 2020 at 9:37 AM
    LlamaResistance
    Concord, CA
    You do know the the lockup torque converter wasn't a common thing till the early/mid 1980's right? The problem is insufficient cooling of the transmission fluid usually. Lockup helps with fuel economy removing the slippage between the impeller and turbine. Lockup can occur in 4th through 6th gear in the AB60E/F transmissions used behind the 3UR-FE (5.7l)
    Cpl_Punishment likes this.
  14. Apr 8, 2020 at 1:38 PM
    CMB
    CMB New Member
    Cecil County MD.
    Yes Sir. Just like Transmission Techs have told me, "slipping causes heat, heat burns fluid" Choosing the proper gear to prevent constant unlocked TC helps keep the fluid stay cooler. My Cummins trucks were '93 and '99 Dodges.
  15. Apr 8, 2020 at 1:41 PM
    Dank1296
    Dank1296 New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    Family Truckster You Think you hate it now wait till you drive it
    Tundyfundy and Cpl_Punishment like this.
  16. Apr 8, 2020 at 1:44 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Where’s the hood scoop to cool the ELECTRIC MOTOR!
  17. Apr 8, 2020 at 2:22 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I was thinking the same thing.
    TXMiamiFan[QUOTED] likes this.
  18. Apr 9, 2020 at 4:48 PM
    Tag520
    Tag520 New Member
    CT
    '20 Army Green Tundra Trd Pro
    Damn, go really excited about a manual...I'd buy that in a second, as long as the exterior didn't look like that.
    specter208 and Cpl_Punishment like this.
  19. Apr 9, 2020 at 7:33 PM
    55kcement
    Troy
    Sonora ca
    Currently none
    Well if dodge would have used an ALLISON instead of there Chrysler pos that would have not ever been an issue .
  20. Apr 10, 2020 at 9:06 AM
    #50
    LlamaResistance
    Concord, CA
    Speed differential between the impeller and turbine causes heat, this is why an automatic will downshift to help reduce the differential. Automatics were used for towing long before a lockup converter was used. The more torque being transmitted across the fluid coupling (torque converter) the greater the slip. The lockup clutch material in a torque converter is actually really small and is only suitable for low load situations like cruising at speed when there is a low torque requirement. Towing heavy weights or uphill travel will almost always unlock the torque converter and this is why proper cooling is essential.
    Chrysler transmissions are indeed trash after the three speed era. Automatics behind Cummins engines were notorious for being underbuilt just like automatics in the Caravan and Grand Caravan especially when paired with their larger V6 engines.
  21. Apr 10, 2020 at 9:15 AM
    #51
    CMB
    CMB New Member
    Cecil County MD.
    Great info Brian! I'm still using 'S' mode 100% of the time:D
  22. Apr 10, 2020 at 9:58 AM
    #52
    LlamaResistance
    Concord, CA
    Not going to tell you not to. Just wanted to clarify for you what torque converter lockup is for and what it won't do.
  23. Apr 10, 2020 at 11:00 AM
    #53
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Not forgotten, it’s full electric amigo. :stirthepot:
  24. Apr 10, 2020 at 11:36 AM
    #54
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    happy with my 2020 if this is anywhere near the styling they're going with.
    And I wonder how jam-packed they'll make it on tech, gadgets, wizardry, sorcery, etc.
  25. Apr 11, 2020 at 9:39 AM
    #55
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    wait, Ozarks is a real place like in the netflix show? does it have a high influx of tourist in the summer time? lol
    Kev0987 and TheBeast like this.
  26. Apr 11, 2020 at 11:20 AM
    #56
    timsp8
    NY
    Yes and yes, but the show was filmed in GA.
    TunaDr[QUOTED] and TheBeast like this.
  27. Apr 11, 2020 at 11:49 AM
    #57
    CMB
    CMB New Member
    Cecil County MD.
    I hear you won't have to start the truck, it'll 'know' who you are. It'll steer for you, change lanes, back-up and launch the boat. Owner's Manual, Hazard Flashers, Park Brake and Sequential Shifter; all deleted!:thumbsup:
  28. Apr 11, 2020 at 12:11 PM
    #58
    cowilcox95
    cowilcox95 New Member
    Lance
    2019 Quicksand Tundra Limited
    the clock is at 4:20 lol.
    Tundyfundy likes this.
  29. Apr 11, 2020 at 1:33 PM
    #59
    boloson
    boloson New Member
    so a Tacoma ridgeline?
    Wallygator and Rica25 like this.
  30. Jul 5, 2020 at 9:13 PM
    #60
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
Thread Status:
