DIY: Rear Differential Breather Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, May 25, 2016.
  1. Mar 24, 2020 at 3:20 PM
    #211
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Just to kill the mis information rampant on this thread once and for all, here are pictures of the diff vent. A pic with the spring pressure and me pushing down on it.
  2. Mar 24, 2020 at 3:43 PM
    #212
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Can you dissect it so we can see the inner workings?
    Tundyfundy likes this.
  3. Mar 25, 2020 at 6:14 AM
    #213
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I have seen water damage created by these valves only on the rear end that ended up in expensive repairs. I could analyze the shit of of this or simply relocate it to a safer location and save all that thought for something more worthwhile. I choose the later
    Jeff_1974 and AZBoatHauler like this.
  4. Apr 5, 2020 at 3:08 PM
    #214
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I did the mod today and found the factory breather seized shut with corrosion.
  5. Apr 13, 2020 at 6:37 PM
    #215
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    3-1 level kit with add a leaf. 295/70/18r cooper max. Spider head light tail light and third brake light, tint, badges off, ladder racks, trd pro grill, color matched hood bulge, grab handle,coach builder +2, dv8 front bumper with winch, fender flares, bed cover....
    So use a hose and same factory breather?
  6. Apr 13, 2020 at 6:59 PM
    #216
    AZBoatHauler
    So.Arizona
    Jeff_1974 likes this.
  7. Apr 21, 2020 at 3:24 AM
    #217
    Emerald_coast_tundra
    Emerald_coast_tundra New Member
    Jc
    2013 Tundra SR5 CrewMax
    Ha! I did this mod in my old Titan, but for a different reason. The titans love to blow rear axle seals.
    First post for me, picking up my 2013 CM today!
  8. Apr 21, 2020 at 8:47 AM
    #218
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I ended up running an extension behind the taillight and an open ended filter. Then I got worried about condensation and another potential issue I can’t recall at the moment, so I added the oem breather to the assembly behind the taillight.
    AZBoatHauler likes this.
  9. Oct 23, 2020 at 11:23 PM
    #219
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    With breather filter
    Skew12, Ducarius, chugs and 1 other person like this.
  10. Oct 28, 2020 at 10:08 AM
    #220
    Dan_of_Earth
    Dan_of_Earth New Member
    2001 AC SR5 4x4
    JBA UCA, Billy 5100, OME springs, 4WP rear 3 leaf
    Just routed the breather to behind my taillight and noticed that my camper shell fills up with the smell of gear oil. No bueno. Gonna try to run it into my gas door.
  11. Nov 3, 2020 at 4:03 PM
    #221
    1794TX
    Steven
    N.TX
    '20 1794
    Also, for anyone doing this, the little hole at the arrow - - - is threaded. perfect place for a hose clamp.
    Skew12, Dan_of_Earth, YotaBro and 4 others like this.
  12. Dec 28, 2020 at 7:35 AM
    #222
    ZenkiS14
    ZenkiS14 New Member
    2012 Tundra TRD Rock Warrior
    Thanks guys Ordered my stuff today. I'll get it setup and do some creeking next weekend.
  13. Dec 29, 2020 at 8:48 PM
    #223
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Is it possible to do without touching spare at all?
    Haggis777 likes this.
  14. Dec 30, 2020 at 9:58 AM
    #224
    1794TX
    Steven
    N.TX
    '20 1794
    The re-route won't interfere with the spare tire at all, and you don't need to remove the spare to get the job done.
    Skew12 and Haggis777 like this.
  15. Dec 30, 2020 at 1:59 PM
    #225
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    Thanks
  16. Jan 11, 2021 at 12:29 PM
    #226
    Honz
    Honz New Member
    Black 2020 Pro CM
    Decked system Garmin Mini with Dongar Technologies adapter Nitto Exo Grappler 285/70R18 OEM Power Tailgate Lock OEM Black Door Sill Protector Center Console Organizer
    So Im going to do the rear diff breather mod and went ahead and ordered part number 90930-03136 (breather) and 90404-51319 (axel fitting) from my local dealer. After placing the order it got me thinking.
    Why are guys using part number 90930-03136 instead of just using the same part number that your truck uses for the front diff breather?
    I got a 2020 and I believe the front diff breather part number is 90930-03208.
    Would it not be a good idea to use the more up to date part number. Maybe Toyota improved it over the years.
    Has anyone done this?
  17. Jan 11, 2021 at 1:02 PM
    #227
    1794TX
    Steven
    N.TX
    '20 1794
    You don't need the breather 91930-03136 or 90930-03208 because you already have one (or the other). It's currently attached to your truck. Just the hose, the nipple 90404-51319, and some clamps and ties as you like them.
    It's a mechanically simple part, so I'm not sure any improvements could have been made; and in the long and short of it, anything that would keep dust out would work just fine.
  18. Jan 18, 2021 at 5:47 AM
    #228
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    Ok.?? Living in the midwest we get lots of salt on are streets an roads.Is there a zip tie brand that will hold up to salt? Or am I over thinking it??
  19. Jan 18, 2021 at 6:04 AM
    #229
    ZenkiS14
    ZenkiS14 New Member
    Stainless clamp, and any ziptie should be fine. Plastic doesnt rust ;)
  20. Jan 18, 2021 at 11:29 AM
    #230
    Sonicbluerider
    Dennis
    2019 Tundra
    ya just check at a store they have some good for -40 degrees
  21. Jan 21, 2021 at 2:01 PM
    #231
    Honz
    Honz New Member
    Black 2020 Pro CM
    Ok I had a little extra time on my hands and went ahead and ordered part # 90930-03208 (front diff breather 2020 Tundra). Below is a side-by-side comparison of the two parts.
    You can see that the hose end for 90930-03208 is narrower then 90930-03136. This would cause a hose fitment issue if using 90404-51319 (union).
    If the male hose end diameter was wider on 90930-03208 I would have preferred to use this part because it would allow for better airflow then 90930-03136.
    So to sum it up stick with the original part numbers mentioned at the start of thread and save yourself the time.
    Ducarius and NewImprovedRon like this.
  22. Apr 7, 2021 at 5:39 PM
    #232
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    Hey guys, I did the rear diff breather a while back and went to check up on it and saw that the fuel filter I used had some condensation in it. I don’t think that any water went inside of the rear diff (at least I’m hoping not) I’m headed to the parts store to get a different filter. Just curious if anyone else has ran into this issue. Maybe it was the filter that I used since it has an additional nipple on the top.
  23. Apr 10, 2021 at 7:03 PM
    #233
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    I haven't done the mod yet but I've got everything to do it, with a filter just like you have.
    Do you have the filter behind your brake light?
  24. Apr 11, 2021 at 11:39 AM
    #234
    YotaBro
    Calvin
    FL
    Yes, I swapped it out with a different filter should be fine
    NWPirate[QUOTED] likes this.
  25. Apr 13, 2021 at 7:54 PM
    #235
    YotaBro
    Calvin
    FL
    @NWPirate Here is the filter that I used and how I stowed it.
    Ducarius and NWPirate like this.
  26. Apr 13, 2021 at 8:24 PM
    #236
    NWPirate
    Zach
    WA
    Nice work, looks good.
    How much slack do you have coming off of the diff for travel?
  27. Apr 14, 2021 at 7:26 AM
    #237
    YotaBro
    Calvin
    FL
    A pretty good amount. Nothing where it’s hanging loose but it’s enough for flex
  28. May 26, 2021 at 3:13 PM
    #238
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    I see that some are using the OEM breather which will close when the differential gets cold such as a water crossing and others are using a filter which remains open.
    My understanding is that the OEM breather route does not solve the issue, since when the breather closes due to cold water on the differential, a vacuum could form and water can be drawn in through the axle seals. This is why some use the filter. The ARB breather relocation follows this methodology by using a open filtered breather block.
    Is there a reason that some are not using the filter method but are instead opting to stick with the OEM breather, just relocated?
  29. May 26, 2021 at 3:24 PM
    #239
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    I got the dorman 2 way breather, it passed the suck test, barely. I cut 3 V shaped groves on the lip of the plastic under the cap and now passes the suck test perfectly.
  30. May 26, 2021 at 5:53 PM
    #240
    3rdTundra
    Central Texas
    Do you have a link?
