Synthetic oil
Discussion in '1st Gen Tundras (2000-2006)' started by Anthonyz85, Apr 1, 2020.
Should I switch to full synthetic oil? I run Castrol blend now.
  1. Yes
    16 vote(s)
    72.7%
  2. No
    6 vote(s)
    27.3%
Multiple votes are allowed.
  1. Apr 1, 2020 at 1:32 PM
    Anthonyz85
    Anthonyz85 [OP] New Member
    Anthony
    2002 tundra TRD
    Would it hurt my engine?
  2. Apr 1, 2020 at 1:36 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    No it won't hurt your engine and is not necessary unless you're going for extended oil change intervals or operating in extremely cold conditions.
  3. Apr 1, 2020 at 1:45 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    It'll help even more than a blend, cleans out carbon slowly over time...will come out Black as can be first few times....
  4. Apr 1, 2020 at 1:52 PM
    Professional Hand Model
    Fred
    Hand Protectors
    If you do switch, try Mobil 1 Synthetic ‘High Mileage’ 5w-30. Right now there is a $12 rebate for 5qt. jugs.
    You can buy the Spec’d Toy Filter YZZD-3 in bulk packs online for around $6 each.
    Its recommended to do 2-3 quick changes at 3k miles per interval because the Full Synthetic is highly detergent and will really clean out any sludge.
    mcharfauros and FrenchToasty like this.
  5. Apr 3, 2020 at 7:46 AM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    I've run full synthetic in all of my vehicles for as long as I can remember. Had a 92 BMW 525 that got synthetic starting around 122k miles. It went to 455k and ran like a top when I sold it. Zero issues. Run full synthetic in my Tundra since I've owned it for the last 155k miles (at 255k now). When I replaced the valve cover gaskets, everything you could see inside the motor looked brand new. Zero sludge or buildup. Synthetic is very different from conventional dino oil. Do some research online from reputable sources and the science is there. It doesn't breakdown like conventional oil making it last longer, but still gets dirty. I run an oversized Mobil 1 filter (M1-301) on my 4.7L and can get 7 qts of synthetic at full in the motor. Will run 10k miles or 1 year between oil changes. Don't drive it as much these days with my work schedule. Buy the synthetic at Walmart in the 5 qt jugs for $4-5 a qt. I just picked up Mobil 1 high mileage at Walmart for $14 a 5 qt jug yesterday. Some kind of clearance.
    abcinv likes this.
  6. Apr 9, 2020 at 6:07 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I started running Amazon Basic Full Synthetic with zero issues. I only use Toyota oil filter (90915-YZZD3). You can get the filters really cheap on ebay. I bought a case of 10 for $59.99 and bought some new oil drain plug washer gasket (90430-12031) I currently have 165k on the truck and it runs like a dream. Here's a couple of videos of reviews.
    https://www.youtube.com/watch?v=a9DWGtXpYUc
    https://www.youtube.com/watch?v=Ye-5EyrwkOQ&t=319s
    https://www.amazon.com/gp/product/B07C5X1ZHP/ref=ox_sc_act_title_3?smid=ATVPDKIKX0DER&psc=1
  7. Apr 9, 2020 at 6:41 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Synthetic is best if you start using it early in the engines life, not so much if you switch over to it on a higher mileage engine (100k +).
  8. Apr 9, 2020 at 10:15 AM
    You can start using synthetic oil whenever you like. I've started using it at 122k in a BMW that never developed any leaks or issues. I started using it in my truck at 100k with no leaks or issues. and Project Farm on youtube did a cool video on testing synthetic in an old tractor.
    https://youtu.be/Pa4RwsiZUmI
    YardBird and speedtre like this.
  9. Apr 9, 2020 at 11:45 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I just started running full synthetic (only ran 100% dino oil prior to this) at 260,000 miles in the 1997 T-100 with the 3.4L V6. Have put about 3,000 miles on it so far. Engine runs a notch smoother according to my seat-of-the-pants analysis tool.
    If full synthetic nukes my T-100, well, then, I guess I'll have to fall back and drive my Tundra full time.
  10. Apr 9, 2020 at 11:57 AM
    Johnsonman
    Austin
    Sequoia
    One of the Very best engines Toyota ever made. synth oil isn't going to take it down, lack of maintenance rarely does either....
  11. Apr 9, 2020 at 12:46 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Yup. And a non-interference engine at that!!!!!
