Rear window deflector
Discussion in '2.5 Gen Tundras (2014-2021)' started by Alkare, Mar 26, 2020.
  1. Mar 26, 2020 at 12:33 PM
    Alkare
    Alkare [OP] New Member
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    I just ordered an AVS 93830 for my 2017. My plan is to remove the outside tape and clean up the edge. Get some new 3m tape and see if it will work as an in channel. Thoughts?
  2. Mar 26, 2020 at 3:12 PM
    biebs96
    PA
    Following.
  3. Mar 31, 2020 at 3:01 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
  4. Mar 31, 2020 at 3:50 PM
    biebs96
    PA
    I’m going to have to order this. Do you have a link?
  5. Mar 31, 2020 at 5:10 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
  6. Mar 31, 2020 at 5:35 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    What’d you end up doing for the install? I saw one before but it said it wasn’t compatible with rear sliding glass. Looks good!
  7. Mar 31, 2020 at 5:53 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    What you have to do is peel off the tape that it comes with and the put new 3M double back tape on the inside and install it as an in channel.
  8. Apr 1, 2020 at 6:14 AM
    field8909
    field8909 New Member
    Austin Texas
    2020 Voodoo Blue TRD Sport
    This isnt a bad idea!!
  9. Apr 1, 2020 at 6:17 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Is there a reason it would be a bad idea?
  10. Apr 1, 2020 at 6:43 PM
    biebs96
    PA
    Any problems with the rear window fully closing?
  11. Apr 2, 2020 at 6:04 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    No. It closes just as it did before I installed it. Not sure why AVS does not make this an in channel for the 3rd gen.
  12. Apr 2, 2020 at 6:19 AM
    Murphs
    Murphs New Member
    PM
    Tundra SR5
    Would this work if you have a sliding middle window?
  13. Apr 2, 2020 at 6:20 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    That's what mine is.
  14. Apr 2, 2020 at 6:22 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Just sent my info onto AVS. We'll see if they respond.
  15. Apr 2, 2020 at 8:02 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    They will look at this when things settle down.
  16. Apr 4, 2020 at 6:03 PM
    biebs96
    PA
    I’m glad you pulled the trigger on this. I’d had this idea and wasn’t sure how well it’d work...
    ardnutoz and Ely010606 like this.
  17. Apr 4, 2020 at 6:29 PM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    Did you use the 3M tape too and in channel the visor?Any issues? Do you notice any difference with air flow?
  18. Apr 4, 2020 at 6:46 PM
    biebs96
    PA
    Yup 3m tape and carefully placed in there then held it and had my wife close the window. Left it for the day.
    Window works perfectly still.
    Haven’t driven with it yet to notice wind noise, but I had one on my 05 and it wasn’t noisy at all and I LOVED being able to leave the window open 3” at work in the summer.
    NewImprovedRon and Ely010606 like this.
  19. Apr 5, 2020 at 6:12 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Can't believe AVS did not realize how simple this was. I emailed them and they will be looking into setting these up.
  20. Apr 5, 2020 at 6:14 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    When I saw how others were taping them onto their rubber I could see how this would fit into the channel so I had to try it. Glad it is working out!
  21. Apr 5, 2020 at 6:37 AM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    does the dust blown in from the bed of the truck or from behind the tailgate rear wheels??
  22. Apr 5, 2020 at 6:42 AM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Can't imagine it would be any different from not having it. Have not run with it open yet because of weather. We will see.
  23. Apr 5, 2020 at 11:55 AM
    BRP479
    BRP479 New Member
    Ricky
    Rogers,AR
    thanks for doing that! Making life better for all Tundra owners
  24. Apr 5, 2020 at 12:45 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    I got lucky and it worked.
  25. Apr 7, 2020 at 5:49 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Looks cool.
  26. Apr 8, 2020 at 4:01 AM
    biebs96
    PA
    So after a few days of it being installed I noticed a couple things...
    -Window works perfectly with this mounted in channel
    -It hangs down much farther then it appears on the outside and I was not a fan of the obstructed view.
    So I modified it to a much smaller size and it has a more contoured look as well matching my side visors much better.
  27. Apr 8, 2020 at 12:08 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    I saw no difference when driving with the window down in any position.
  28. Apr 8, 2020 at 12:09 PM
    TRDblvd
    TRDblvd New Member
    2019 Toyota Tundra TRD 4X4 Sport
    I'm going to steal this idea too! I've been hesitant to get one for the rear glass because of the unibrow look. But trimmed, it blends right in.
    DIYDad and biebs96 like this.
  29. Apr 8, 2020 at 1:56 PM
    biebs96
    PA
    Here is the view out the back... can barely notice it.
    KingsAustin and DIYDad like this.
  30. Apr 8, 2020 at 5:23 PM
    Alkare
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    What did you cut it with?
