2008 Expedition Crewmax
Discussion in '2nd Gen Builds (2007-2013)' started by Swatdude1, Jan 16, 2020.
  1. Mar 2, 2020 at 4:43 PM
    #61
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thank you, that was exactly what i was thinking, glad to have someone who used it recently confirm!
  2. Mar 2, 2020 at 4:43 PM
    #62
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    This is gonna be an awesome build. Can’t wait to see more
  3. Mar 2, 2020 at 4:51 PM
    #63
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    See what you have time for now that you are not trying to keep that black paint perfect looking. Cool project!
    Swatdude1[OP] likes this.
  4. Mar 18, 2020 at 8:01 PM
    #64
    Swatdude1
    Swatdude1 [OP] New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
    Last weekend I pulled the bumper in anticipation of the NFAB coming back from the powder coater.
  5. Mar 18, 2020 at 8:07 PM
    #65
    Swatdude1
    Phoenix, AZ
    I also got the Propex heater mounted and the gas line run. There is a gap between the box and the frame where the duct will through and up inside the fender to feed the truck bed/Vagabond Nomad. I will run the duct this weekend and add the intake and exhaust. It sits up nice and high still allowing me to ford almost to the top of the 35's. I had propane guy mount the quick connect (bottom rear passenger side of the cab)and run/test the propane line. I thought about using soft copper but in the end decided on the rubber hose because I thought it would take more bumps and jars without issue.
    vhstejskal likes this.
  6. Mar 23, 2020 at 3:55 PM
    #66
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    nice, man! 08 original owner refreshing mine also for probably similar reasons.
  7. Mar 26, 2020 at 4:55 PM
    #67
    thatonedave_
    thatonedave_ New Member
    Dave
    Centennial, CO
    2008 White Tundra DC
    Wow! Turning out awesome so far!
  8. Apr 14, 2020 at 6:30 PM
    #68
    Swatdude1
    Phoenix, AZ
    Finally got back to work on the Tundra this weekend. My job has been crazy with this Covid thing. Camo'd the power tanks propane tank and mounted it on the tailgate. Also shot the bumper cover and front fenders. I'm kind of dreading doing all four doors. Decided to take the windows out and replace all the window molding.
    Billybob9, TheBeast, drobb and 4 others like this.
  9. Apr 14, 2020 at 8:28 PM
    #69
    JJcksn12
    JJcksn12 New Member
    2021 Silver Sky Platinum 4x4
    you have a large set of brass balls.......
    this looks fucking amazing !
    Billybob9 and ZappBrannigan like this.
  10. Apr 15, 2020 at 3:27 PM
    #70
    Swatdude1
    Phoenix, AZ
    Thanks. :)
  11. Apr 15, 2020 at 3:36 PM
    #71
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i'm really digging that. what's the durability? maintenance? care? just wash and go or does it still need waxed/sealed?
  12. Apr 15, 2020 at 4:33 PM
    #72
    Swatdude1
    Phoenix, AZ
    No waxing or sealing. Wait and see on how durable it will be but a guy on another forum painted his truck in Cerakote and has no scratches after some hardcore AZ pinstriping. You can clean it with Acetone!
  13. May 6, 2020 at 10:06 PM
    #73
    Koconnor04
    Koconnor04 New Member
    Kaeden
    2008 Ltd DC Super White
    2.5”/0” level
    Any updates? :boink:
    TheBeast likes this.
  14. May 7, 2020 at 9:40 AM
    #74
    Swatdude1
    Phoenix, AZ
    N-Fab Bumper is on with holes drilled for parking sensors. Propex duct holes are drilled. RCI skid plate is installed. Base coat is applied to the passenger side doors. 100aH deep cycle battery is in. Waiting on a Rigid bracket for Rough Country light bar install in the bumper. I will post up some pics this weekend. :)
  15. May 7, 2020 at 9:43 AM
    #75
    Swatdude1
    Phoenix, AZ
    In the meantime here is a mock up my sweet wife helped me with so I could get the shapes right...
  16. May 7, 2020 at 9:50 AM
    #76
    JEFFTHEROBOT
    JEFFTHEROBOT New Member
    Jeff
    Lakewood, CO
    2017 Crewmax Barcelona Red
    TRD Pro grill & bulge Method 305NV 18x9 (x5) Eibach PRO LIFT SYSTEM (Stage 1) ICON 1.5″ REAR ADD A LEAF UpTop Overland mid-height truss Area BFE Black series Aluminum hard shell rooftop tent (Large) TRD Pro Shift knob Total Chaos bed stiffeners AJT blackout interior OEM blackout badge overlays Diode dynamics SS3 fog lights Diode dynamics 42" stealth light bar Rigd mega ultraswing spare tire carrier Compustar Pro R3 remote start EBC brakes & rotors
    WHOAH, this thread Kicks A$$. NICE
    Billybob9 and Swatdude1[OP] like this.
  17. May 18, 2020 at 9:43 AM
    #77
    Swatdude1
    Phoenix, AZ
    Wound up tweaking the camo pattern a bit. Need to figure out how to fix the gap on the Sequoia TRD Grille.
  18. May 18, 2020 at 9:48 AM
    #78
    Swatdude1
    Phoenix, AZ
    Wound up replacing the Window Glass Runs, Belt Moldings and Door Gasket since I had parked this thing in the AZ sun for 4 years. Also got my 304 stainless tailgate kitchen work surface and installed the parking sensors in the N-Fab covers...
  19. May 18, 2020 at 9:53 AM
    #79
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
  20. May 18, 2020 at 9:56 AM
    #80
    smslavin
    Hudson Valley
    Some stuff
    looking good. saving the roof and door jambs for last? how much time have you put in to get to this point?
  21. May 18, 2020 at 10:00 AM
    #81
    Swatdude1
    Phoenix, AZ
    Just have the roof, jamb and driver's side doors left. Instead of piece-milling what's left I am doing it all at once. If we need a second car during it we will just have to Uber. It's getting hot and I have to get it done!
    Just guessing based on Saturdays and Sunday work... 160 hours?
    smslavin[QUOTED] likes this.
  22. May 18, 2020 at 12:01 PM
    #82
    ckkone
    ckkone New Member
    SLC, UT
    Looks great.
  23. May 18, 2020 at 12:11 PM
    #83
    TheBeast
    TheBeast The Beach
    sick ! are you planning on wrapping the roof or camo as well ?
  24. May 18, 2020 at 2:42 PM
    #84
    Swatdude1
    Phoenix, AZ
    Camo on the roof for sure... in case I need to hide from Apache's... the helicopter that is. :rofl:
  25. May 18, 2020 at 3:56 PM
    #85
    TheBeast
    TheBeast The Beach
    I like your plan. don't forget those dang heat-seekers... :D
    Kiddnapped Tundra likes this.
  26. May 30, 2020 at 4:09 PM
    #86
    Redcon41318
    Redcon41318 New Member
    Love the rear view, propane tank looks like a m67 frag. Sweet
    Swatdude1[OP] and TheBeast like this.
  27. May 30, 2020 at 5:56 PM
    #87
    Redcon41318
    I feel you need a matching camper shell!
  28. May 31, 2020 at 12:31 AM
    #88
    Swatdude1
    Phoenix, AZ
    It's coming! Ordered a Vagabond Nomad which is in line for December build.
    Worked on the truck all day in the heat. Should have final painting done Monday morning early. I will post pics when it is put back together.
  29. May 31, 2020 at 5:27 AM
    #89
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I wish I had something sarcastic to say, but this is wonderful, that is all! Carry on!
  30. Aug 26, 2020 at 11:12 AM
    #90
    Swatdude1
    Phoenix, AZ
    Been trying to get my wife to take some better pictures with her good camera but not sure when that will happen. It got to hot here so I will have to wait to paint the fender flares but other than that and the Vagabond Camper when it gets here, the exterior paint is basically done. The first picture is more true of the colors, at least on my monitor.
