Who has mounted a lightbar behind your grille?
Discussion in 'Lighting' started by ToyotaTundraMike, Aug 11, 2016.
  1. Dec 27, 2016 at 9:54 AM
    TXRailRoadBandit73 YOTAS,RAILROADER,RÖKnRÖLLN',BEER,MAX/GEMMA
    42" bar i bought off Craigslist didn't come with wire harness took bout an hour had a buddy make a wire harness switch is in a blank on left by headlight adjuster ther a flat bar u can put light bar brackets on to
    zcarpenter92 likes this.
  2. Dec 27, 2016 at 7:25 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Nah, not of install. Pretty easy tho. Take the bumper cover mount the bar using clamps temporarily. Put The bumper back on and see of it fits in the grill opening adjust accordingly
    mctommymac[QUOTED] likes this.
  3. Dec 27, 2016 at 7:49 PM
    Nick1716
    Nick1716 New Member
    Has anyone put a curved led bar behind their grille?
  4. Dec 28, 2016 at 8:35 AM
    mctommymac
    mctommymac New Member
    Tommy
    2005 Toyota Tundra
    none yet
  5. Dec 28, 2016 at 3:25 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    How are you guys wiring through the firewall to the switch for these auxiliary lights?
  6. Dec 28, 2016 at 3:50 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    A sharp knife!! I then used a straightened coat hanger and passed that through from the cab to the eng bay. I then made a very small hook on the hanger, set the end of the wires accordingly and electric taped it on German Tight (that's gutenteit), making it kind of aerodynamic...then pull em on through!!
  7. Dec 28, 2016 at 3:52 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Are you running it through the boot for all the wiring from the engine to the cab on the driver side? The same one that has the hole for the hood release? Is there a smaller one somewhere?
  8. Dec 28, 2016 at 6:47 PM
    Bear
    Bear
    Custer, SD
    Indeed. Just be careful with that knife
  9. Dec 28, 2016 at 7:42 PM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Cut out the bottom section of grill and put mine in. 40 inch rigid
  10. Dec 29, 2016 at 7:47 AM
    Bear
    Bear
    Custer, SD
    Well...there's that!! Haha. Wish I'd known
    NewImprovedRon likes this.
  11. Dec 30, 2016 at 5:35 AM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Yep, works great as long as the other end of your wire doesn't have any type of plug on it, like most wire kits do...
    Patriot likes this.
  12. Dec 30, 2016 at 5:39 AM
    davesnothere
    Dave
    Down South, Texas
    Goin thru the rubber boot is easy, 1: drill small pilot hole 2: insert coat hanger thru said hole 3: electric tape the wire to end of hanger and you can make a little loop on hanger to hold wire even better 4: pull thru
    I make ‍✈️ hole smaller than wire so it will suck up around it
    Had a pilot emoji and it switched to plane emoji when posted, you get it tho
    Sixpack likes this.
  13. Dec 30, 2016 at 5:42 AM
    Sixpack
    Sixpack New Member
    Central Florida
    I heated up the angle cut end of a metal coat hanger and it pushed right through the rubber boot, no problem...
    14burrito likes this.
  14. Dec 30, 2016 at 5:44 AM
    davesnothere
    Dave
    Down South, Texas
    That is a good one, I had some angle probs with drill due to tight space, will remember that
    Sixpack[QUOTED] likes this.
  15. Jan 7, 2017 at 10:27 AM
    HornetOne3
    HornetOne3 New Member
    Columbus ,Ohio
    2016 Barcelona red Crewmax SR5
    38in on the lower, Osram 180w flood/spot combo
    46in upper ,Creed 1in slim ,5d 260w spot beam for long distance
    When both are on , they lit up night like day
    Wires are very simple to installed. I just connet the + and - right out of the battery ,the switch ran thru the rubber in the firewall
    But i recommended to fabricate your own brackets as most factory ones wont fit into our trucks easy
    I went and bought some 3/8in aluminum bracket at Lowes and used the visegrip to bent them with what ever angle to fit into behind the grille
    (no paint needed for aluminum and easier to bent than steel but still has a rigid mounts better than factory's )
    Sixpack likes this.
  16. Jan 15, 2017 at 4:12 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    2 40s in the grill
    1 in the lower.
    With how much they're covered separately they don't produce as much light
    ec4480e9-dc2a-4419-91c3-7c73b570e7fe_zps_7f84f7f4b0393aa35e80052490fd398cc80ca0a9.jpgSnapchat-2101417579_zps8vbhrbbo_cfb7087088446bb53914eb1e3133b2e521cc932f.jpg
  17. Jan 15, 2017 at 4:52 PM
    Sixpack
    Sixpack New Member
    Central Florida
    I have a 32" in my lower bumper cover...
  18. Jan 21, 2017 at 9:20 AM
    tonybeam
    tonybeam New Member
    Tony
    Spokane, WA
    '15 Silver Sky Tundra CM LTD 5.7L TRD
    Hey @SuperSilverTundra did you use the kit from Headlight Revolution? Or did you DIY it? My TRD Grille comes this week and I want to install a light bar while I got the thing apart.
  19. Jan 21, 2017 at 9:39 AM
    tonybeam
    tonybeam New Member
    Tony
    Spokane, WA
    @Sixpack How did you mount this? And what LED bar/brackets did you use?
  20. Jan 22, 2017 at 8:52 AM
    #50
    Sixpack
    Sixpack New Member
    Central Florida
    The light bar is made by Phillips 5D LED, 32" I used the short brackets from another light a drilled the hard bumper behind the lower bumper cover...
  21. Jan 24, 2017 at 5:37 AM
    #51
    Sixpack
    Sixpack New Member
    Central Florida
    @oil brother what size tires are on your truck? Thanks...
  22. Feb 25, 2017 at 6:11 AM
    #52
    McReef
    McReef '17 Tundra TRD Pro Crewmax
    Eastern MA
    Jeepers! You guys aren't kidding, those Rigid light bars are spendy.
    I almost made my own shackles, but CoachBuilder puts those out at a price point that makes it more cost effective to just buy them. Those light bars though, I may have to take that project on myself...
  23. Feb 25, 2017 at 7:11 AM
    #53
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
  24. Feb 25, 2017 at 8:24 AM
    #54
    Bear
    Bear
    Custer, SD
    Patriot likes this.
  25. Feb 25, 2017 at 9:05 AM
    #55
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    Hey John. Is it the auxbeam curved 32" 5d 180W Phillips?
  26. Feb 27, 2017 at 11:13 AM
    #56
    Sixpack
    Sixpack New Member
    Central Florida
    No, it's not a curved light bar...
  27. Feb 27, 2017 at 1:49 PM
    #57
    PermaFrostTRD
    Northern NY
  28. Mar 14, 2017 at 4:21 AM
    #58
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    This is eventually the seamless light bar/winch or winch delete plate install I am after. This will allow me to clean the light bar lens without having to remove my grill. It also puts the light closer to the road aligned with the fog/driving lights where I want the light projected. Negates any reduction of direct airflow into the cooling system.
  29. Mar 14, 2017 at 7:35 AM
    #59
    Adarcy
    Adarcy New Member
    Andy
    2015 Tundra LTD CM 4x4
    Bilstein 5100's (middle), ESP Storage + Trailer Brake Mount, CB +2 Shackles, BFG AT KO2 275/65r20
    @Patriot What front bumper is that?
  30. Mar 14, 2017 at 1:18 PM
    #60
    Patriot
    Patriot Member
    Here is a link....still very knew and I have not seen any owner reviews yet. Going to wait and see what kind of reviews this bumper gets by Tundra owners before placing an order. So far no reviews on their website, surely because it's new.
    It's a lot of change to lay out if you do a few options plus Warn winch, light bar.
    One of the nicest I have seen so far. FWIW...
    https://www.tundras.com/threads/southern-style-offroad-tundra-slimline-hybrid-bumper.9994/
    dcsleeper408 likes this.
