285s set up help
Discussion in 'Wheels & Tires' started by Quicksand20, Mar 13, 2020.
  1. Mar 13, 2020 at 5:40 PM
    Quicksand20
    Quicksand20 [OP] New Member
    2019 Quicksand Tundra SR5 TRD Off Road
    Hey guys, I have read completely through the 6112 thread and read a few 5100 threads and still am not sure what to do. It seems every tundra is different just by enough to make everyone have different experiences. I have a 2019 SR5 with the TRD off road package. I am wanting to run 285/75/18 tire on my stock Trd off road wheels. I don’t want to run wheel spacers. I would like to just run 5100s as I don’t do any serious off reading to require the 6112s and the 5100s price is much better. Would I be able to clear the 285/75/18s on stock Trd off road wheels with just 5100s at middle setting? I still want the truck to have alittle rake as well. Thanks for the help in advance guys. Sorry for another “can I run a “ thread.
  2. Mar 13, 2020 at 5:59 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    You will have rake at the middle setting and the tires will fit without spacers. Might need to take the mud flaps off and either trim the front inner fender liner or heat up and bend out of the way. Simple fix and from my experience a good tire shop usually does it for you. Mine does anyway. If not super easy to do your self
  3. Mar 13, 2020 at 6:08 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I have a little over 2” front lift and 1” in rear. Running 285/75r18 in stock TRD pro wheels in a 2019. I had to hammer the front skid outta the way and take off the little front mud flaps. I also trimmed a little off my rear mud flaps. I do rub on my front sway bar at full lock. It has rubbed off the paint and a bit of metal. B03F9467-FEEC-4B07-803E-83C97F30F65E.jpg
  4. Mar 13, 2020 at 6:11 PM
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I am gonna go aftermarket rims next go around just to get the stance and look I want, but for now I’m satisfied.
    Know I’ll have to do some more mods to make that work too. I tried 1.25” spacers and there was gonna be a lot more trimming necessary, but probably wouldn’t rub on the sway bar that way.
  5. Mar 13, 2020 at 6:21 PM
    1FSTREX
    1FSTREX New Member
    Will
    Northern California
    2019 Tundra TRD Sport
    Good info, I have been interested in the same.
  6. Mar 14, 2020 at 3:46 AM
    Quicksand20
    Awesome thanks so much guys
  7. Apr 30, 2021 at 12:32 PM
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    I’ll be doing this as well. Except I’ll have my 5100s on middle setting with a CB shim on each side.
