Bad response
Discussion in 'General Tundra Discussion' started by TundraTank, Feb 23, 2020.
  1. Feb 23, 2020 at 4:43 AM
    TundraTank
    TundraTank [OP] New Member
    Donald
    2015 XSP Tundra
    leveled cold air intake
    I installed K&N cold air intake now have hesitation under hard throttle, any advice?
    It is 2015 XSP Tundra.
  2. Feb 23, 2020 at 5:02 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Possibly oil on the air flow sensor? Can happen if you apply too much
  3. Feb 23, 2020 at 5:12 AM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
    Did you disconnect battery during install? This is important for the ECM to learn new fuel/air setup.
    Tundyfundy, 1UPPER, Buildn and 2 others like this.
  4. Feb 23, 2020 at 5:16 AM
    TundraTank
    Donald
    2015 XSP Tundra
    Yes I did the battery disconnect during install.
  5. Feb 23, 2020 at 5:20 AM
    Rockanock
    Rockanock 21 Chevy 2500
    I installed a K&N air filter on my last truck. It ended up clogging my ECM sensor. I think it is because of all the oil that was on the filter. I replaced with a wix air filter and cleaned my sensor and never had an issue after that. Since then I have strayed away from K&N filters.
    Hbjeff likes this.
  6. Feb 23, 2020 at 5:23 AM
    TundraTank
    Donald
    2015 XSP Tundra
    Thank you, will check when I get off of work.
  7. Feb 23, 2020 at 5:27 AM
    Rockanock
    No problem. If your sensor is clogged you can buy the ECM sensor cleaner at the auto parts store. It comes In an aerosol can.
  8. Feb 23, 2020 at 5:36 AM
    Triton19X2
    Triton19X2 New Member
    2021 Silver 1794 Crewmax 4X4
  9. Feb 23, 2020 at 6:22 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed one of these dry filters after installing my BAMuffler, no issues and the throttle response is improved. It's better than OEM.
  10. Feb 23, 2020 at 6:26 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    OEM air filter is better, better, did I say better?
    Hbjeff and YardBird like this.
  11. Feb 23, 2020 at 6:28 AM
    Aurora CO
    A K&N drop in or complete cai kit? If the kit, make sure no leaks. I've used K&Ns since the 70's with zero issues. It's possible to over oil but they come properly oiled new. Re-oiling isn't rocket science. MAFs are easy to check. My 07 had a K&N on for 5 years and my MAF was clean as a whistle. Posted a pic of it on my build thread. An improper seal will cause the hesitation you described.
    Tundyfundy likes this.
  12. Feb 23, 2020 at 7:15 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    :confused: What's an ECM sensor? You mean the MAF sensor?
  13. Nov 1, 2020 at 3:13 AM
    1tuffhombre
    1tuffhombre New Member
    Westminster, CO
    2013 Rock Warrior
    K&N Air Filter. Pedal Commander
    Bought my Tundra with a K&N filter installed, so I don’t know if the battery was disconnected. Can you just disconnect it to rectify?
  14. Nov 1, 2020 at 4:58 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    That’s what I use. I never really understood the whole concept of an “oiled filter”. Sure they catch particles and trap it in the oil but I’m not sure how much more efficient it is than a dry filter. For k&n to make all these horsepower and torque claims, the filter element must be thinner which allows for more airflow. I guess that’s why it’s oiled to help compensate for the thinner element.
    https://youtu.be/sJ3L-E-ufYo
  15. Nov 1, 2020 at 5:27 AM
    Rex Kramer
    Georgia
    The same as OEM only better than OEM because it can be cleaned and it doesn't let dust in.
  16. Nov 1, 2020 at 5:51 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    resetting the ecu should be standard fare when doing intake stuff. It's way too sensitive to changes. When I put on the TRD air flow accelerator and removed the charcoal filter I thought it would be fine because I still had the OEM air filter in there. Well the first time I went WOT the motor stalled. Oops. Drove home and unplugged the battery for ten minutes and let it re-learn. Ran great ever since.
