Any way to upgrade just the JBL subs?
Discussion in 'Audio & Video' started by 2015Crewmax, Aug 10, 2018.
  1. Feb 6, 2020 at 12:18 PM
    #121
    liquid_g
    liquid_g New Member
    Grantham, New Hampshire
    2018 Tundra Platinum
    Those that have done this tech12volt sub/box replacement.. You still have to deal with the OE system leveling off the bass at higher stereo volumes right?
  2. Feb 6, 2020 at 4:13 PM
    #122
    TXTundra2722
    2015 Black Tundra
    I switched out my factory HU before this upgrade so no issues with that for me.
  3. Feb 7, 2020 at 3:29 AM
    #123
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    how did you wire the dual Voice coil?
  4. Feb 13, 2020 at 7:24 AM
    #124
    primeiro
    primeiro New Member
    Henk
    Netherlands
    i just bought this one
    KICKER CWRT81-43
  5. Feb 13, 2020 at 8:17 AM
    #125
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Another option is this
    Pioneer TS-SW2002D2 8" 600W Shallow Subwoofer with Dual 2" Voice Coils
    it’s cheaper than the kicker
  6. Feb 13, 2020 at 9:36 AM
    #126
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    but can the OEM box handle that kind of Power? its just thin plastic. I bought a cheap sub off Amazon for now. 20$. I don't expect much from it. But the reviews were not bad. https://www.amazon.com/gp/product/B00CMC6O68/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 If it blows in a week ohh well. The depth should be ok. Its a single voice coil. I opened the box and it really feel like a quality sub. Ill keep you posted.
    Mountun Goat likes this.
  7. Feb 13, 2020 at 12:47 PM
    #127
    primeiro
    primeiro New Member
    Henk
    Netherlands
    well carman did it also , so i dint see why it should not work with me
  8. Feb 13, 2020 at 2:11 PM
    #128
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    I didn't say it would not work I just wonder what that box can handle.
    Guys the factory sub is single voice coil right ?
  9. Feb 17, 2020 at 12:43 PM
    #129
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Just installed the 12-Volt JBL sub replacement. Super easy, I did it even though I currently have one of the many respiratory plaques going around in about 30 mins. Huge difference with Tool? Nope. However, a huge difference with old school Dr. Dre! I'm not looking for a banging system....just something with some more punch and that's exactly what this does. Next will be the door and dash speakers. Also going to sound proof while everything is out. Eventually, it will also be the amp/DSP from 12-volts but I'll let someone else do that and run the power wire.
  10. Feb 18, 2020 at 3:21 AM
    #130
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Im going to get the Tech12Volts sub. After messing with my OEM enclosure its just not worth it to me. here is my setup. I went with a cheap 4ohm single voice coil sub off Amazon. It actually got good reviews from people. Most compared it to much more expensive speakers costing $$$. its something to consider. It dropped right in. I just had to seal the 6 holes and use some self tappers. The connectors on my Sub were Soldered on. There is plenty of slack so you can cut them close as you can at the speaker and use some Female Butt connectors and then crimp.
    I have 300 watts of clean power going to it and I can see the plastic box flexing making the bass sound muddy.
    https://www.tundras.com/threads/dsr...-1-amp-i-need-some-help-with-the-wires.62094/
    Mountun Goat and Rica25 like this.
  11. Jun 22, 2020 at 7:10 AM
    #131
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    Do you happen to have torque specs for the seat bolts you can share. Great write up and thanks.
  12. Jun 22, 2020 at 7:20 AM
    #132
    ak49
    ak49 New Member
    Alaska
    2020 White Tundra TRD Pro CrewMax
    Here are the specs...
  13. Jun 22, 2020 at 7:53 AM
    #133
    NuTundra18
    Jimmy
    Awesome, thank you for the quick reply.
  14. Jul 6, 2020 at 3:23 PM
    #134
    TundraG8tor
    TundraG8tor New Member
    SLC Utah
    2018 Crewmax limited
    +1 for another happy customer with James @ tech21volts.
    Just a simple swap from stock JBL sub to his JBL and enclosure
  15. Jun 13, 2021 at 10:10 AM
    #135
    SKMooseHunter
    SKMooseHunter New Member
    2016 1794 Tundra Black
    I put a cerwin vega in my 2016, the sub sounds way richer. Instead of deep notes coming from the front doors it now comes from the back. CV comes with an integrated ohms selector, so getting 1ohm was easy as a switch, I accidentally connected to 4ohms at first and this halves the wattage and makes no improvement to sound, when I put it to 1ohm it sounds like a different stereos.
    The sub was not shallow so I made a ring to shim it out an inch, mdf and a jigsaw… looks and sounds great
  16. Jun 13, 2021 at 11:27 AM
    #136
    Black
    2014 Tundra Limited CrewMax
    I did an 8” Alpine Type S with a 1” spacer ring. I have sound deadened the cab as well and it makes a nice difference.
    I would probably spend the $100 more and get the JBL and box from James.
    SKMooseHunter likes this.
  17. Jul 6, 2021 at 12:35 AM
    #137
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    no issues with clearing the rear seat with the sun sticking out that far?
  18. Jul 6, 2021 at 12:36 AM
    #138
    SpeshulED
    would elaborating on which setup you are referring to when you’re taking a out James? Where can I find this?
  19. Jul 6, 2021 at 4:44 AM
    #139
    Black
    SpeshulED[QUOTED] likes this.
  20. Jul 6, 2021 at 7:14 AM
    #140
    SKMooseHunter
    As luck would have it the seat has an indent of a couple inches right there, so there is no contact, this thing pounds the deep notes nicely, I fade the audio to the back a bit to get the cv to stand out more
  21. Jul 23, 2021 at 6:45 AM
    #141
    SouthWestGA
    Does anyone else that used a drop in sub “on the cheap” have any further input?
    I am debating between a generic drop in,and Tech12Volts sub box. The sub box would require modifications to the back trim panel so I’m not sure I want to go that route,as I prefer everything left intact
  22. Jul 23, 2021 at 6:54 AM
    #142
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  23. Jul 23, 2021 at 12:22 PM
    #143
    SouthWestGA
    I would like to avoid cutting up my interior if possible,hence why i was asking about a cheap sub-only alternative
    i guess the only way is to put something in and see!
  24. Feb 2, 2022 at 9:31 AM
    #144
    rattmobbins
    rattmobbins New Member
    2021 Platinum 4x4
    Anyone thrown one of James Taylor's subs in their 2021?
    He said the sound is hit and miss in the 2020 and 2021 (guess something changed from 2019 ¯\_(ツ)_/¯ ) and I don't want to spend $250 if it's not gonna be an improvement. Especially since I plan to do a full blown system upgrade once suspension and wheels and tires are finished up.
  25. Feb 2, 2022 at 9:38 AM
    #145
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    Tech12volts and James Randy Taylor recommended this RF sub and box to my 2021. It works with the existing amp and has made a huge difference in sound quality. I also believe the JBL system has a break in period. I’ve had my truck for almost a year and it sounds better than the day I got it.
    rattmobbins and Gunship Guy like this.
  26. Feb 2, 2022 at 10:26 AM
    #146
    rattmobbins
    2021 Platinum 4x4
    Interesting. He's been a little spotty on email responses and he didn't mention this to me. Just told me the one on the site is hit or miss with the 2021. I'm trying to throw the guy money but he doesn't seem all that interested in taking it. lol
  27. Jun 2, 2022 at 6:11 PM
    #147
    SKMooseHunter
    I have grown bored of my cerwin vega subwoofer upgrade and am now having a soundstage 400 watt mono 2 ohm compliant amplifier. I have learned that these high level/speaker wire hook up systems at the speaker end so it should not be impacted by or impact streaming of music from head unit to main amplifier. Visions electronics in Canada had this amp for $149CAD and around $600 installed. I quite frankly need way more bass that these premium tundras come with. Will update.
  28. Jun 3, 2022 at 4:30 PM
    #148
    SKMooseHunter
    The amplifier is all I need, sounds epic, doesn’t reverberate outside the cab and through the neighborhood but pounds perfectly
