What Jack Stands are you using?
Discussion in 'General Tundra Discussion' started by Johnders2586, Feb 1, 2020.
  1. Feb 1, 2020 at 1:50 PM
    Johnders2586
    Johnders2586 [OP] New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Hey Guys,
    Ordered up my suspension an will be doing the install myself . I am wondering for the DIY folks what Jack stands are you using with your truck? I have several already but I feel like they dont get high enough for a truck alot of the time.. I suppose some wood under them could boost that up.. Just wondering if anyone had a particular brand or model they found works good for truck applications..
  2. Feb 1, 2020 at 1:59 PM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
  3. Feb 1, 2020 at 2:31 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    ARMYGREEN likes this.
  4. Feb 1, 2020 at 2:47 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I have the HF Pittsburgh 6 ton stands. They have smaller and bigger.
  5. Feb 1, 2020 at 3:16 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    Bucktail likes this.
  6. Feb 1, 2020 at 3:22 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I thought the same thing! That’s a lot of dough, no matter what’s in the bank or credit line.
    Any time off-roading there is the high likelihood of breaking down and needing the truck lifted or on stands.
    First “real” serious trip on dirt and my ProEagle and jack stands helped get my friend’s steering rack switched out in Mojave.
    Worth every penny knowing I helped.
    https://www.tundras.com/threads/2019-sgu-bastrds-turkey-run-the-after-action-report.57414/
  7. Feb 1, 2020 at 5:50 PM
    Johnders2586
    Thank you for the suggestions
  8. Feb 1, 2020 at 6:01 PM
    TheBeast
    TheBeast The Beach
    old school Craftsman Pro jack stands.
    RoniusMaximus and 7.62Tundra like this.
  9. Feb 1, 2020 at 6:16 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
  10. Feb 1, 2020 at 6:24 PM
    Southdesertprerunner
    Southdesertprerunner New Member
    08 tundra
    Camburg lt kit, king coilovers, bypasses, and bumps, deaver i96 in rear, fab work by solo motorsports, super charger, rigid light bars, bfg 37s total chaos bed stiffners, gorrila whips, dasaita head unit polk audio subs and amps.
    I use these they fold up for storage and will lift the rear of my truck with i96 deavers off the ground with out a jack. I have also used them to support the front of truck when lifted off the ground with a jack
  11. Feb 1, 2020 at 6:26 PM
    Voyagermike
    Voyagermike New Member
    California
    I bet the UPS guy just loves you now. o_O
    I'd love to have a set of those as well.
    ProjecTundra2009 likes this.
  12. Feb 2, 2020 at 4:55 AM
    Johnders2586
    Those are sweeeet
  13. Feb 21, 2021 at 12:14 PM
    Jack McCarthy Truck repair enthusiast; Rust Aficionado
    Craftsman 4 ton jack stands.
  14. Feb 21, 2021 at 8:40 PM
    TundraRV
    TundraRV New Member
    2021 SR5 SX Double Cab
    Quickjack.
  15. Feb 25, 2021 at 6:51 PM
    Voyagermike
    California
    I'm looking into purchasing the quick jack. How are you liking it so far? What section of the frame are you able to lift at? In front of the cross member or behind? Are you using the truck adapter kit? Sorry for so many questions. I'm trying to decide between the slx and ext. I'd like to use it on our rav 4 as well. Any insight would be greatly appreciated.
  16. Feb 25, 2021 at 6:54 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    This reminds me that I returned my jack stands to HF under that recall and now I'm out of big jack stands :/
    BravoDeltaRomeo likes this.
  17. Feb 25, 2021 at 7:12 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    I like them their ok a bit heavy to move around but once they are set up their nice I put them on the frame rails side to side I use the truck spacers to get a bit higher lift. I have used them on my Honda Odyssey my pilot and my accord as well. What I like the most is that they fit between my wall joist so they are not in the way in my garage
  18. Feb 25, 2021 at 7:21 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I like the safe Jack Jack stands. Pricey, but they work in gravel/sand. Picked up a 6 ton bottle Jack to use the same attachments. [​IMG]
  19. Feb 25, 2021 at 7:24 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    But that’s not the only thing I have to lift the truck or cars in my garage I normally use a 3 ton jack from Costco and 2 Ton jack stands from Harbor Freight
    Voyagermike likes this.
  20. Feb 25, 2021 at 7:28 PM
    Voyagermike
    California
    I think I'm going to pull the trigger on them. Home depot has a sale on them right now. I just hope they are able to lift my truck high enough off the ground. I am running a larger tire.
  21. Feb 25, 2021 at 7:57 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    Also have a couple HF 12 tons (for the height, I don't care about the capacity) and then some 6 tons for smaller things.
