SouthPaw’s 2000 Tundra Limited 4x4 Build
Discussion in '1st Gen Builds (2000-2006)' started by SouthPaw, Sep 21, 2019.
  1. Jan 5, 2020 at 6:38 PM
    SouthPaw
    SouthPaw [OP] The headlight guy
    2000 Limited 4x4 AC
    Projects like these keep me young. I had a lot of fun doing it. I’d absolutely love to do it again. Thought I’d even pick up a set on craigslist for cheap to do some other tests with them (demon eyes, switch backs, color changing halos, etc).
    KarmaKannon[QUOTED] likes this.
  2. Jan 18, 2020 at 10:20 AM
    SouthPaw
    2000 Limited 4x4 AC
    Passenger washer nozzle started clogging up on me so I started looking for a replacement. I hated that it squirts streams vs a fan/mist style. I found another guy that used a set off of a FJ cruiser so I bought some on eBay. Not my pics but for $30, this is definitely must upgrade.
    Mando, MS22 and KarmaKannon like this.
  3. Jan 19, 2020 at 8:01 PM
    Rudolph_05tundra
    Rudolph_05tundra New Member
    Seth
    Kentucky
    2005 Toyota Tundra DC SR5
    I'd be interested in a set if you ever decide to sell some budget retrofits. I would go the route you went with the halos, but probably in the smoked housings.
  4. Jan 19, 2020 at 8:28 PM
    SouthPaw
    2000 Limited 4x4 AC
    I’ll send you a pm!
  5. Jan 25, 2020 at 7:46 PM
    SouthPaw
    2000 Limited 4x4 AC
    Well it was time to replace the factory radiator last week. It started leaking at the driver side top corner at the mounting bolt. After further investigation, the previous owner replaced the bolt with one that was too long and rubbed/cracked it at the same spot. I threw some jb weld on it to get me by for a day and tossed in a lifetime warranty NAPA one for $150. 177k and some change, she’s back on the road.
    One of the biggest reasons I love this truck is how easy they are to work on. Had the old one out and the new in filled and truck running in about an hour.
    Rica25 and speedtre like this.
  6. Jan 27, 2020 at 8:29 PM
    SouthPaw
    2000 Limited 4x4 AC
    Finally got these guys in last week. I’ve had been working on them for a couple of weeks researching parts and tinkering with them after work. I bought a 12v bench supply and got to work. I’d say the final product was worth it. It was a bit of pain, especially the stripping, sanding, priming and painting part but I came out with a one of a kind set.
    Mini H1 w/halos
    Audi style DRL light strip with sequential/directional turn signals
    6K HIDs
    Matte black housing
    https://youtu.be/-zDyx9bsjas
    https://youtu.be/V2pbI0D0Ygk
    Pics of the cut off line and high beams
    Filthyphil, MS22, Y0TA PR0 and 4 others like this.
  7. Mar 1, 2020 at 8:37 PM
    SouthPaw
    2000 Limited 4x4 AC
    Decided to upgrade the radio. While the old one still worked great, I needed something that would have better call quality. The Amazon one had a built in speaker but it was junk.
    Did some research online and found out Best Buy will not only price match (including Crutchfield) but will also install for FREE. I didn’t believe it at first but it really was. I ended going with the Best Buy’s geek squad recommendation on the JVC-M750BT. I was hesitant at first because I had my mind set on a Sony but he assured me this was a better unit. The people that I have called says it sounds like an OEM Bluetooth call and the apple car play is an awesome feature. It’s a lot of bang for the buck at $269.
    One of my favorite features is completely adjustable Backup camera lines.
    Mando and speedtre like this.
  8. Mar 1, 2020 at 8:39 PM
    SouthPaw
    2000 Limited 4x4 AC
    Finally did the timing belt/water pump as well. Aisin kit, OEM thermostat, belts and hoses.
    Next will be a full suspension over haul, Bilstein 5100’s, new springs, UCA’s, lower ball joints and some 33”/35” tires.
    MS22, Rica25, KarmaKannon and 2 others like this.
  9. Mar 4, 2020 at 9:05 PM
    SouthPaw
    2000 Limited 4x4 AC
    Today was my lucky day (kind of)! A 2005 DC limited was posted for a part out. I was able to snag the center console and I’m completely in love with the outcome. It’s about an 80% swap. Not EVERYTHING bolts up 100% but you can get crafty and make it secure. I was even able to utilize the 12v power outlets (different style of connectors). I have a few more things to tiddy it up but it came out great. I feel it’s almost a ‘have to’ upgrade for $65. I’ll get some better pictures tomorrow of how it looks.
    empty_lord, FirstGenVol and Rica25 like this.
  10. Apr 2, 2020 at 9:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    hey, if you dont mind me asking, what exactly did you do to make that console work out... i have one in the truck and i cant make any combination of brackets come close to working.. i may just make custom brackets if i have to.. i have double cab brackets and access cab brackets
    I do not have all the holes the access cabs seem to have on the floor, but i can drill them out and the nuts are on the sheet metal below.. so if i knew what ones you used that would be a great help in of it self (all i have thats kind of close is the rear bracket.. and even its off by a bit
  11. Apr 2, 2020 at 9:17 PM
    SouthPaw
    2000 Limited 4x4 AC
    I was only able to utilize one bracket from the DC, the one closest to the rear seat. That bolted up fine and then I secured the front to the bottom the dash. I figured between those two mount points, it wasn’t going anywhere. I couldn’t get the middle bracket to line up.
  12. Apr 2, 2020 at 9:18 PM
    empty_lord
    05 rollover special
    hmm.. looks like i'll be making my own bracket (my issue is the damn thing is setup like yours but still isnt "secure"
  13. Apr 2, 2020 at 9:19 PM
    SouthPaw
    2000 Limited 4x4 AC
    Depends on how you define secure. Under normal use, a roll over or anything like that, it isn’t going to move. Now if somebody latched onto or drop kicked it, it might move lol.
    Rica25 likes this.
  14. Apr 2, 2020 at 9:21 PM
    empty_lord
    05 rollover special
    my truck has a history with rolling over :anonymous:
    na my issue is driving around town just hitting potholes it rattles around.
    Rica25 likes this.
  15. Apr 2, 2020 at 9:22 PM
    SouthPaw
    2000 Limited 4x4 AC
    Interesting. I haven’t noticed mine making any additional noise among the other noises it already makes lol.
    Tundra2 and Rica25 like this.
  16. Apr 2, 2020 at 10:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @SouthPaw
    Excellent write up! Fantastic progress!
    I look forward to more posts, and am watching this thread now!
    MS22 and SouthPaw[OP] like this.
  17. Apr 5, 2020 at 1:20 PM
    empty_lord
    05 rollover special
    did your transmission tunnel look anything like this? I’m still have a bear of a time getting even one bracket to line up...
  18. Apr 5, 2020 at 1:30 PM
    SouthPaw
    2000 Limited 4x4 AC
    It looks like it but I didn’t pull the carpet. Like I said, only one of the double cab brackets lined up.
    It took me over an hour to figure out how to line it up. Sounds dumb but it was a royal pain in the ass lol. It was the bracket closest to the bed that lined up if that helps. I think I bolted the bracket down first. Then fished the console around till I got it to fit. I’d also suggest getting the cigarette plug connectors to fit too. Once I got it all bolted up, I realized the damn pins were different and didn’t connect to the new fascia from the DC. I ended up snipping the DC connectors off and crimping on spade connectors that pushed into the connectors on my truck If that makes sense.
    If it helps, I might take it apart to put two bolts into the holes that are left open since I didn’t use that bracket. I could snap some pictures of it then and maybe that would help.
  19. Apr 5, 2020 at 1:31 PM
    empty_lord
    05 rollover special
    Yea that’s the only one that even bolts into my floor. Did you use the bracket that came with the console or one your truck already had?
  20. Apr 5, 2020 at 1:36 PM
    #50
    SouthPaw
    2000 Limited 4x4 AC
    I just updated my post. Honestly I could have. Reason being why I don’t know is because I did this at night with a flashlight. I took it all apart inside the cab and then realized I didn’t know which was the new brackets and which was the old. I just sold my old console yesterday with the brackets :confused:
    empty_lord[QUOTED] likes this.
  21. Apr 5, 2020 at 1:40 PM
    #51
    SouthPaw
    2000 Limited 4x4 AC
    I was only able to utilize one bracket. The rest didn’t line up.
  22. Apr 5, 2020 at 2:21 PM
    #52
    empty_lord
    05 rollover special
    I’m just drilling all the holes for the mounts.. the nuts are under the truck, but the holes are not drilled. So far I have the front mount setup. (Granted I’ll have to find an access cab console to work now.. the double cab one won’t line up with any of these.) or I’ll just make custom mounts.. we’ll have to wait and see.
  23. Apr 23, 2020 at 8:15 PM
    #53
    SouthPaw
    2000 Limited 4x4 AC
    When I bought this truck, my intentions were to restore it, not build it. Well... I think that has officially changed now.
    Since blacking out grill, I’ve wanted to replace the bumpers to get rid of the chrome. I saw another first gen that had the bumpers covered in bed liner and I wanted to do the same. After reading how much prep was involved, I opted to do plasti-dip. It’s on there pretty dang thick (8 or so coats worth). I cleaned it really well, sprayed a coat, waited 20 min and did another coat. Repeated that a bunch of times and it’s on there thick. I don’t think any rock chips will be getting through, at least for awhile.
    And lastly, her latest and biggest upgrade; a Leer 100R topper. Found this by accident and I got a smoking deal on it. I’m going to upgrading and painting a few things on it to bring it back to life and then will be building a sleeping platform for an air mattress.
    Filthyphil, MS22 and imDementeD like this.
  24. Apr 23, 2020 at 8:20 PM
    #54
    empty_lord
    05 rollover special
    I kinda like the storm tropper look going on here.
    youve also reminded me i want to put some reverse LEDs in my bumper.
    SouthPaw[QUOTED][OP] likes this.
  25. Apr 23, 2020 at 8:36 PM
    #55
    SouthPaw
    2000 Limited 4x4 AC
    I’m a big fan of two tone. Might have to get a ST decal for the topper back window now lol.
    Those are extremely handy, especially when someone is tail gating you.
  26. Apr 23, 2020 at 8:39 PM
    #56
    empty_lord
    05 rollover special
    im just going to make a T harness for the trailer brake and reverse lights. no hacking of my harnesses and it'll be a clean install for the cap and eventual reverse lights
  27. Apr 26, 2020 at 7:06 PM
    #57
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    I plasti-dipped my grill and bumpers years ago. Held up pretty well for 3-4 years and then started to peel at all the bug strike spots. after it got pretty ratty looking I stripped it down and wire wheeled the whole thing. Then used etching primer. Then used Rustoleum bedliner in the spray can to recoat it. Turned out great, is easy to touch up if you get a chip in it and looks darker black than the plasti-dip. My grill is still plasti-dipped, but is peeling in several spots. Will likely bedliner it also. Might buy a new all black grill for an SR5. Mine has a broken clip on it and rattles. I ended up using the bedliner on the mirror caps and side trim as well since the factory clearcoat was almost gone.
    SouthPaw[OP] likes this.
  28. May 2, 2020 at 3:12 PM
    #58
    SouthPaw
    2000 Limited 4x4 AC
    Beautiful cool day in Colorado so I decided to work on the shell. The previous owner was obviously into construction as the inside had paint all over it and glass. I got all the paint off the windows via a razor blade and removed all the chunks of paint off the fiberglass I could. Then ran it down to the car wash and washed it all out. Stopped by the auto parts store and picked four cans of Duplicolor TR250 truck bed coating. Got everything masked off and shot it. I’m really happy the way it came out and it dried really hard. The texture was exactly what I was looking for.
    Before
    A
    fter a solid coat:
    And the finished product. I’m sure once it dries completely, it will look more uniform.
    H
    ere is an example of the texture. A piece of tape came up and I didn’t catch it right away.
    MS22 and FirstGenVol like this.
  29. May 2, 2020 at 3:23 PM
    #59
    SouthPaw
    2000 Limited 4x4 AC
    I debated on what to coat it with. I called a topper place and he suggested just a roll on latex paint. I then thought bed liner, plasti dip and regular spray paint. I decided on bed liner because I wanted that texture and I felt it would ‘fill in’ the deeper spots better.
    Product used - Dupli-Color Truck Bed coating TR250. This stuff sprays fast, strong, wide and doesn’t clog. I had ZERO issues in the four cans I bought. Three cans would have done it so the fourth was just for added thickness.
    For anyone looking at bed liner in a can, DO NOT use their Bed Armor stuff. I had an extra can laying around and figured with this, plus the four I had I would be enough. I started with this and within 30-45 seconds of spraying it clogged up and ran down the the side of the can. I cleaned it and tried again but it kept happening. Halfway through the can and I pitched it.
    MS22 likes this.
  30. May 2, 2020 at 3:56 PM
    #60
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and nice truck :thumbsup:
