Best battery terminal protection combination
Discussion in 'General Tundra Discussion' started by csuviper, Jan 10, 2017.
  1. Jan 10, 2017 at 8:39 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What is the best combination to protect the battery terminals from corroding?
    Black Wolf and Patriot like this.
  2. Jan 10, 2017 at 8:41 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    Fluid film also works great
    Luckydog and NewImprovedRon like this.
  3. Jan 10, 2017 at 8:41 PM
    scurdyness
    scurdyness One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    worked for my dad and his dad
    Luckydog, Law323, AnonVet and 2 others like this.
  4. Jan 10, 2017 at 8:45 PM
    TheBeast
    TheBeast The Beach
    I use both the green/red pads and the red spray from CRC. No corrosion at all in the past 3 years.
    I re-spray once every 6 months the connectors
    15whtrd and csuviper[OP] like this.
  5. Jan 10, 2017 at 8:52 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You did say you're Scottish? lol My Grandfather was a Scott (Mc Laren) and a machinist for Rolls Royce. He used Vaseline on battery terminals.
    I like these:[​IMG]
    Law323 and 15whtrd like this.
  6. Jan 10, 2017 at 8:54 PM
    csuviper
    Broomfield, CO
    I purchased some of this not long ago. Might go this route then.
  7. Jan 11, 2017 at 7:38 AM
    I use pads and that yellow spray can protectant
    15whtrd likes this.
  8. Jan 11, 2017 at 10:45 AM
    LML 3500HD
    Bingo!!!
    NewImprovedRon likes this.
  9. Jan 11, 2017 at 10:47 AM
    LML 3500HD
    Once your battery is venting off through the service caps, it is a never ending fight.
  10. Jan 11, 2017 at 10:48 AM
    csuviper
    Broomfield, CO
    So your saying i don't need this stuff on the NorthStar i bought?
  11. Jan 11, 2017 at 10:51 AM
    LML 3500HD
    Yes, it is a sealed battery.
    Make sure your leads are clean of corrosion and you are good to go.
  12. Jan 11, 2017 at 11:40 AM
    csuviper
    Broomfield, CO
    Sweet. So i am just going to replace the terminals then so there is absolutely no corrosion and be done.
    So what to replace with?
  13. Jan 11, 2017 at 11:46 AM
    csuviper
    Broomfield, CO
    marine or military style battery terminals?
    Led, aluminum, zinc, brass, copper ?
  14. Jan 11, 2017 at 12:43 PM
    LML 3500HD
    Lead has always worked for me. You can get some pretty nice ones now days with fuses in them.
    Trooper2 likes this.
  15. Jan 11, 2017 at 2:26 PM
    csuviper
    Broomfield, CO
    I emailed NorthStar and this was their response:
    "The posts on the NSB-AGM27F are brass. I would personally go with Brass terminals but Stainless Steel would also be great."
    Patriot and ColoradoTJ like this.
  16. Jan 11, 2017 at 2:26 PM
    csuviper
    Broomfield, CO
    Dont think they make stainless steel ones.....
  17. Jan 11, 2017 at 3:46 PM
    LML 3500HD
    It was smart for you to just contact the manufacturer. No guesswork and get the right parts for the job.
    Trooper2, Law323 and NewImprovedRon like this.
  18. Jan 11, 2017 at 3:58 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    agree
  19. Jan 11, 2017 at 4:13 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    Always used lithium grease but am trying fluid film on current vehicle.
  20. Jan 11, 2017 at 4:46 PM
    tts-355
    tts-355 New Member
    Tyler
    2012 Tacoma DCLB TRD Sport 4x4
    Can't go wrong with Yamaha products, although it's fairly expensive along with most of their products. They tend to make really good stuff in my opinion though.
  21. Jan 11, 2017 at 6:02 PM
    csuviper
    Broomfield, CO
    Little more info from NorthStar:
    "Brian, being that the NorthStar batteries have a 3 stage sealed terminal design (usually a weak spot where leakage can occur) it is not a big concern for corrosion as there is no risk of anything leaking at the terminal. As far a galvanic corrosion goes, the brass is much more resistant to this than lead would be. That is why we typically dont have a standard recommended terminal material. "
    Trooper2 and ColoradoTJ[QUOTED] like this.
  22. Jan 11, 2017 at 6:44 PM
    LML 3500HD
    Yep. Two dissimilar metals will corrode. I see this a lot with older beadlock wheels. Never can I stress enough, anti-seize works wonders.
  23. Apr 12, 2017 at 12:09 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Tundra%20battery%20corrosion_zpsrfv6xwbu_d3b2f358f108745fc5ac04c0905258bb32c907b0.jpg
    Piggybacking onto this thread I just noticed this. So...disconnect leads, clean leads and posts with a wire brush, add pads and spray? Anything else to do/watch for? @csuviper or anyone else, any final recommendations for anti corrosion spray?
  24. Apr 12, 2017 at 12:14 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Yowza.
    Clean with a wire brush and some baking soda/water solution and then keep it covered with Vaseline/fluid film/grease/etc. I am currently using fluid film because it is on my garage shelf but I've used WD-40 and chain lube before and both have worked fine. Just check on it whenever you fill up your fuel tank and are checking your oil and reapply as needed
    Cat3ILS[QUOTED] likes this.
  25. Apr 12, 2017 at 12:16 PM
    Cat3ILS
    Thanks. Is it all caused by the battery off gassing?
  26. Apr 12, 2017 at 12:19 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    I'm not exactly sure the reason why. Sorry. :notsure:
    Cat3ILS likes this.
  27. Apr 12, 2017 at 1:42 PM
    csuviper
    Broomfield, CO
    Its all a downhill battle from here on out until you replace. Your frequency of cleaning and acid neutralization will keep increasing to the point where you batter starts having problems or dies.
    RitcheyRch and Cat3ILS[QUOTED] like this.
  28. Apr 13, 2017 at 6:07 AM
    10forty2
    10forty2 New Member
    Doug
    NC
    2017 Tundra TRD-4x4 XSP-X
    Another tip to prevent corrosion is to NEVER connect any wires except the battery leads directly to the battery terminals. Again, dissimilar metals instigate corrosion. Oh, and Vaseline Petroleum Jelly has been working for many, many years..... no need to get the expensive, fancy sprays and pads and other gadgets unless you just really want to spend more money on it.
    Cat3ILS likes this.
  29. Jun 7, 2019 at 9:06 PM
    johnsmsith6073
    johnsmsith6073 New Member
    2015 Limited
    In my experience battery connectors are tin coated and the wire brushing will expose the underlaying metal, in my case a copper colored battery terminal which may comolicate matters. This can be mitigated by a grease/protectant coating prior to assembly, proper assembly will squeeze the grease out where metal to metal contact occurs and it will remain to protect dissimilar metals where its not forced out. Previously I applied protectant after assembly and it never reached many areas.
    Vaseline will work in a pinch but its designed to liquify at roughly body temperature and that temp is regulary exceeded under hood, obviously. Silicone grease is probably better and good for much higher temps. I am a fan of NOCO NCP2 which is oil based and stays where you put it. Looks ugly as hell, used motor oil comes to mind, but works great. More difficult to remove than grease but wipes away with a rag and some elbow grease.
    Sorry to bump an old thread but I just switched to an X2 (err, well found out it was the wrong size when I put it in and returned it, waiting for the 27f now) and it was fresh in mind.
  30. Jun 7, 2019 at 9:20 PM
    Aurora CO
    Doesn't hurt to revive an old thread with new input considering how important battery PM is!
