2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Jan 3, 2020 at 7:46 PM
    #1261
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
  2. Jan 3, 2020 at 7:48 PM
    #1262
    619Tundra
    What does the Motion Bypass Switch do?
  3. Jan 5, 2020 at 5:12 PM
    #1263
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  4. Jan 8, 2020 at 8:19 AM
    #1264
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    One question I have for the FRAC V3. Can an interface be added to allow operation of the front and rear camera using the steering wheel buttons? I saw there was a similar FRAC system for the Tacomas that used the steering wheel buttons to switch the front and rear cameras. I thought it looked cleaner and easier to control the cameras. It would also help higher trim Tundra without an open spot to install buttons.
  5. Jan 8, 2020 at 8:21 AM
    #1265
    619Tundra
    That would be cool.
    HulkSmurf14 likes this.
  6. Jan 9, 2020 at 5:46 AM
    #1266
    Jayroc
    Jayroc New Member
    2018 Tundra
    Did an answer ever come about for this.
    Cheers Justin
  7. Jan 12, 2020 at 6:54 PM
    #1267
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    I hesitated to post this since there seems to be a lack of love for chrome on this forum (jk) but there is surely someone who can benefit from a picture of my choice of camera placement.
    This camera (chrome NATIKA) is mounted quite a bit lower than most it seems at 24” above the ground on a stock suspension. It works really well for parking but is too low and the focus too short to double as a “dash” cam. The camera doesn’t stick out past the bumper at all.
    I wanted maximum viewing of the ground close to me.
    Beesta and jtwags like this.
  8. Jan 12, 2020 at 6:57 PM
    #1268
    Any pictures from the camera view?
  9. Jan 12, 2020 at 8:14 PM
    #1269
    okcowboy
    okcowboy New Member
    I need to retake them because they didn’t turn out as good as they looked on the screen but here is what I have for now.
    View at night from outside the truck. 4’ from garage door.
    Same view from screen showing night vision capability. Pretty grainy but usable.
    Same location viewing into garage.
    7” away from a box in front of truck parked in garage.
  10. Jan 12, 2020 at 8:16 PM
    #1270
    Thanks.
    Any idea why the pictures are grainy?
  11. Jan 12, 2020 at 8:32 PM
    #1271
    okcowboy
    okcowboy New Member
    I think it is a combination of the cheap fixed focus NATIKA camera lens, the darkness, and the refresh rate of the screen. Could be that the Google Pixel 4 XL’s camera isn’t as good as I think.
    I’ll try to remember to get some pictures during the day if you want them.
  12. Jan 12, 2020 at 8:36 PM
    #1272
    ThePee
    ThePee New Member
    These are beautiful may have to spring for this ...
    TundraTex[OP] likes this.
  13. Jan 12, 2020 at 8:36 PM
    #1273
    Those were good enough. I just wanted to see the angle from that height. I was thinking about putting mine down there.
    Thanks.
  14. Jan 12, 2020 at 9:25 PM
    #1274
    okcowboy
    okcowboy New Member
    Apparently I don’t know how to hold the phone at the correct angle to capture a good still shot of a video screen. I swapped out the last picture above. (Post#1269)
    Here is a 12”x18” flag, camera facing down at about 40 degree angle 30” away.
  15. Jan 13, 2020 at 11:56 AM
    #1275
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Did you have to take the bumper off to mount the camera?
  16. Jan 13, 2020 at 12:59 PM
    #1276
    okcowboy
    okcowboy New Member
    I had to remove the metal brace directly above the bumper cover and then take all of the top bolts out of the cover so I could pry it away from the truck enough to reach in and screw the nut on the camera. I drilled the hole from underneath but then had to get a razor and remove a little material from the top side of the hole to allow for a flat place for the nut to seat. It's a tight fit but I don't have large forearms.
  17. Jan 14, 2020 at 3:31 AM
    #1277
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    Did I read there is a V3 of the harness? Just curious what has been updated
  18. Jan 14, 2020 at 4:04 AM
    #1278
    I believe it is for 2020's because of the different radio, same functions.
    azTony[QUOTED] likes this.
  19. Jan 14, 2020 at 5:04 AM
    #1279
    Jolla_At_Ya_Boy
    Jolla_At_Ya_Boy New Member
    A-A-Ron
    Spokane, Wa
    2020 Limited Crewmax
    BAM 10" Exhaust w/ Toyota black tip, ALL lights LED, added footwell and puddle lights, AMP Research PowerSteps, Wet Okole neoprene seat covers, 100% interior/exterior chrome delete (ajt for interior), trd front and rear sway bars, trd skid plate, King Performace 2.5 front and rear suspension, BBS forged TRD Pro wheels, audio system rebuild, Cooper at3 xlt 275/70/R18’s, undercover swing case, front windows tint matched to rear, spray in bed liner, Rigid SAE Fog light retrofit w/ TRD Pro bezels, FRAC harness with front camera
    Is the V3 available?
  20. Jan 14, 2020 at 6:22 AM
    #1280
    I'm sure @TundraTex will let you know.
  21. Jan 14, 2020 at 9:14 AM
    #1281
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Making some progress on the V3. Hope to have it ready sometime in February.
    InTheRough and jtwags like this.
  22. Jan 14, 2020 at 7:05 PM
    #1282
    Jolla_At_Ya_Boy
    A-A-Ron
    Spokane, Wa
    Sweet. I’m in as soon as they are available. Thank you sir.
  23. Jan 15, 2020 at 8:43 PM
    #1283
    okcowboy
    okcowboy New Member
  24. Jan 16, 2020 at 5:59 PM
    #1284
    Steve9R
    Steve9R New Member
    I run 3 cameras off 1 switch on mine..
    Its a 4 position rotary switch..
    Position 1 is OFF (normal radio operation)
    Position 2 is Camera 1 ON
    Position 3 is Camera 2 ON
    Position 4 is Camera 3 ON
    like this but i got like 5 of them for that sort of $$s..
    https://www.ebay.com.au/itm/PCB-Boa...ctor-4-Pole-3-Position-with-Knob/282883639991
  25. Jan 16, 2020 at 6:09 PM
    #1285
    Steve9R
    Steve9R New Member
    I actually have a quick question..
    Has anyone come across the issue that I have today ?
    I had to disconnect the main battery to reset ECU so i left it off overnight and reconnected this morning.
    Everything worked fine prior to disconnecting, but after re-powered up the FRAC unit isnt working. Im sure Ive seen this mentioned before.. Is it just a case of powering off and on again a few times to get it to start?
  26. Jan 17, 2020 at 12:18 PM
    #1286
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Steve,
    When did you buy your FRAC Harness?
  27. Jan 18, 2020 at 12:12 PM
    #1287
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I’m doing my setup now but my camera came with 4 wires, not 3. I remember reading about it but can’t find instructions right now.
    What do I do with the 2 reds? Wire them together and connect to red connector on the frac?
  28. Jan 18, 2020 at 3:06 PM
    #1288
    paradizecityz
    Richmond, TX
    nevermind I found what I needed. Install was pretty straight forward. Hardest thing for me was going through the firewall lol
  29. Jan 19, 2020 at 6:50 PM
    #1289
    Steve9R
    Steve9R New Member
    Its all good.. re-powered tundra (did you turn it off and on!).. and its all working again.. ;)
    Yzed608 likes this.
  30. Jan 25, 2020 at 10:15 AM
    #1290
    skatebass1958
    skatebass1958 New Member
    Felix Javier
    2017 Tundra SR5 Xp
    Removed mudflaps
    Will this mod still work if I replace the factory HU with an aftermarket one? Like a kenwood or jvc?
