Archive Garage Springs Available For Order Now
Discussion in '1st Gen Tundras (2000-2006)' started by speedtre, Jan 20, 2020.
  1. Jan 20, 2020 at 12:17 PM
    speedtre
    speedtre [OP] New Member
    Inland Northwest
    Darkness and mcharfauros like this.
  2. Jan 20, 2020 at 12:19 PM
    TheBeast
    TheBeast The Beach
    they make good stuff. their hangers for the 3rd gen tacoma is pretty cool.
    831Tun and mcharfauros like this.
  3. Jan 20, 2020 at 12:28 PM
    FirstGenVol Brake Czar
    2002 AC
    So Archive doesn't actually make the springs, they just design them? Is that right? They look very nice. I like that they are meant to hold some serious weight. It looks like they have phased out their other design, the "overland" leaf pack. Shackleton must be named after the famous Arctic explorer.
  4. Jan 20, 2020 at 12:50 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Serious leafs right there. Solidly build with the military wrap.
    What does one do about the lean that may happen per the manufacturers instructions?
    What type shackles you planning?
    mcharfauros likes this.
  5. Feb 9, 2020 at 10:13 AM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    2011 White Tundra RW
    2.5” level kit. 35” KO2
    I’d run the hammer hangers they sell. It’s supposed to be better than the shackle flip and give you more overall travel ( mainly droop travel) plus I’ve heard it smooths out any ride even on stock springs due to the rigidity of the hangars compared to the play in factory hangers.
    As far as lean they say to adjust front coil overs (if you have adjustable to help level the rear).
  6. Feb 9, 2020 at 11:14 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I've been looking at these just not sure I'd have enough weight to justify. Contemplating these or just ordering directly through Deaver. Definitely feel that new leaf springs will be needed as my truck was used to haul loads and has almost 300k. Would love to see some feedback from someone else first...who's going to be the guinea pig?
    speedtre[OP] and mcharfauros like this.
  7. Feb 9, 2020 at 12:05 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    I have a set of deavers coming in for an extra 500lbs in the rear. I will test them with stock hangers then I’ll go from there and possibly order these hammer hangers from archive.
  8. Feb 9, 2020 at 1:47 PM
    imDementeD
    Definitely curious about your feedback. I also need to get my OME suspension installed and see what the actual lift will be in the front as that will play a part into what I go with.
    Volt92 likes this.
  9. Feb 9, 2020 at 2:33 PM
    2002 AC
    If these are built for carrying 1,000 lbs I'm guessing the ride would be fairly harsh if the bed is empty?
    Volt92 likes this.
  10. Feb 9, 2020 at 2:37 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Do they make hammer hangers for Tundras? I've only seen them for Tacos and that won't work.
  11. Feb 9, 2020 at 3:06 PM
    Fred
    Hand Protectors
    I’m waiting for some feedback from members who recently installed General Springs Leafs. You can get an OE set for like $230 for Access Cabs with bushings pressed. I’ve heard good things prior. Someone here just put in a HD (heavy duty) set which costs a bit more.
    Having a hard time justifying $800 for another brand when General Springs at $230 plus another $200ish if HD will work.
  12. Feb 9, 2020 at 4:13 PM
    2002 AC
    Not really apples to apples comparison. These are designed for a specific purpose. Since you're not into overlanding I would go with General or OEM.
    @lsaami do you like your general springs so far?
  13. Feb 9, 2020 at 4:51 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    So far, so good. They rusted VERY quickly however. like, within weeks. I'd recommend anyone getting them, paint or powder coat them before install.
  14. Feb 9, 2020 at 4:53 PM
    Fred
    Hand Protectors
    How is the ride compared to your oldies?
  15. Feb 9, 2020 at 5:14 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    Yeah. It’s the Tacoma one first option. I emailed the owner.
    EDIT. Oops. That was a different part.
    He said these are coming in March -April for our tundras!
  16. Feb 9, 2020 at 5:17 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Curious how that would fit. Tacoma leaf springs are under the frame but first gen are outside the frame. Doesn't seem like it would line up to me but would be cool to find out.
    Volt92[QUOTED] likes this.
  17. Feb 9, 2020 at 5:20 PM
    Volt92
    Volt92 New Member
    Tulsa, Oklahoma
    It won’t you’re right. Different design coming in March to April for us.
  18. Feb 9, 2020 at 5:57 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Definitely much harsher and tighter. I don't notice so much anymore, but it a was a substantial difference at the time.
    To be clear, I got the standard springs, not the HD springs.
  19. Feb 9, 2020 at 7:26 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    powder on springs wont last too long
    lsaami[QUOTED] likes this.
  20. Feb 10, 2020 at 6:16 AM
    2002 AC
    The Deaver springs seem to rust easily also. Rheywood posted this last spring after only being on his truck 7 months(1 KC winter)
    You'd have to be diligent about keeping them sprayed with something.
    mcharfauros and Volt92 like this.
  21. Feb 10, 2020 at 6:26 AM
    Fred
    Hand Protectors
    My suggestion on these springs (if brand new or old/rusted) is to soak/coat them in Ospho and then paint them.
  22. Mar 19, 2020 at 5:16 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Got a set on order.. Can't wait to get these. My springs have been crying for help.
  23. Mar 19, 2020 at 6:03 PM
    speedtre
    Inland Northwest
    Interested to hear your review when you get them...:thumbsup:
  24. Mar 22, 2020 at 11:07 AM
    Trailscape
    Alabama
    2006 Tundra SR5
    I'll be sure to update. Hoping the shipping happens on schedule, though it might be a hot minute before I get around to installing them.
    speedtre[QUOTED][OP] likes this.
  25. May 7, 2020 at 7:55 AM
    2002 AC
    I saw on your instagram page that you were able to get these installed. Care to give us a review, including how much weight you carry in the back. I reached out to Eric at Archive this morning and this was his response to my questions.
    "I am working on a mild revision, and ordering another batch very soon. The first batch shipped in April, people are in progress of installing. I find the ride is too firm unloaded but not jarring on my '00 AC. I have an ARE alum contractor Topper which is pretty light ~80lbs, and a Line-X spray in bed liner as my base weight, don't even run around with a spare. Lift is a lot, like 3" unloaded
    Hammer hangers do help the ride as well. The next revision may slightly lower lift
    You may need longer rear shocks, Good lengths would be 14"-15" max compressed/24-25" extended"
  26. May 7, 2020 at 8:58 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I really appreciate the R&D that Archive has been doing on first gen trucks. Nobody else would do such on a 20 year old model with relatively low market.
    :thumbsup:
    Once this scary Covid crap is over I'm getting that shock kit to support them.
  27. May 7, 2020 at 9:04 AM
    speedtre
    Inland Northwest
    I was looking to go with these but was concerned they were a bit too heavy duty with too much lift for my needs....but he did nave a note in there about removing one of the leafs to lower height and carrying capacity by 15%...but he took that note out.....hmmmm....guess I'll keep watching for now...:popcorn:
    https://archivegarage.com/explore-archive/ols/products/archive-shackleton-springs
  28. May 7, 2020 at 9:40 AM
    2002 AC
    I told him that I appreciated that as well. Eric has a 00 Tundra so I'm sure that helped motivate him.
    That's my concern as well but I'm hoping to get some real world reviews before ruling them out. I know that currently my truck can't handle more than 300-400lbs before the ass end starts to horribly sag. I also suspect these may not ride any rougher than my currently shot leaf packs. Hopefully @Trailscape can let us know.
  29. May 7, 2020 at 1:51 PM
    imDementeD
    My concern as well UNTIL I just built my drawer system. Not even done and I think 500lbs won't be hard to hit with gear. I reached out to him 2 days ago to see the next available as i will definitely purchase these
  30. May 7, 2020 at 5:25 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    I haven’t been able to put any real miles on these yet, but I can say they so far do what they promise.
    I removed my air bags and 1.5” blocks in the process. Ride height still increased by an inch, so I’m seeing 2.5” lift over all. Ride is much improved. It soaks up the pot holes a lot better and feels way more planted to the ground.
    I have a lot of crap in the truck, but not everything is carry with me on a trip. Fridge and battery are always in the back, but I’m also betting my shell has grown pretty hefty in weight.
    Edit: Also, an extra ~200lbs in the bed drops the height roughly 3/4".
    FirstGenVol likes this.
