2020 speedometer re calibration help
Discussion in '2.5 Gen Tundras (2014-2021)' started by SprinterAE86, Jan 20, 2020.
  1. Jan 20, 2020 at 3:05 AM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    I just ordered 295.70.18 Copper AT3 XLT and was concerned about fitment, but not how to reset the calibration of the speedometer. And so far, there's no tool that shows any compatibility with 2020 yet.
    Did anybody had any luck with this?
    I will have them delay the delivery and might just downgrade to 275.70.18 or cancel all together.
    Thanks!
  2. Jan 20, 2020 at 8:09 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    I have nav on mine which comes with a mode for calibration with new tires. Not sure your setup
  3. Jan 20, 2020 at 8:12 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    My speedo shows about 2 mph faster than real world speed (GPS and speed camera signs), so I was hoping that it'd be pretty close after I get my 35s put on. Do you know what the effect is on the speedometer as you go up in size?
  4. Jan 20, 2020 at 8:27 AM
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    2020 Super White TRD Sport Tundra
    2" level, 34 Mickey Thompson ATZ, tint, Magnuson SC, pedal commander and katzkin leather
    The rough country calibrator works on the 2020. I have it installed on my truck. Talked to rough country and they haven't updated the website but confirmed its compatible.
    SprinterAE86[OP] likes this.
  5. Jan 20, 2020 at 9:18 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    It's a percentage difference, not a flat difference. Going to 35's is about an 8% difference in circumference. So at 35MPH the speedo would show 32.2MPH but at 80MPH it would only show 73.6MPH.
  6. Jan 20, 2020 at 10:00 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, after I posted here I went and actually researched a little and that's what I found. Guess I'll be looking into the calibration as well.
  7. Jan 20, 2020 at 10:01 AM
    SprinterAE86
    Ian
    Nope, I do not have that version.
  8. Jan 20, 2020 at 10:02 AM
    SprinterAE86
    Ian
    I'll
    Do you have the model number?
  9. Jan 20, 2020 at 10:07 AM
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
  10. Jan 20, 2020 at 10:12 AM
    SprinterAE86
    Ian
    nlg4021[QUOTED] likes this.
  11. Jan 20, 2020 at 10:17 AM
    nlg4021
    nlg4021 New Member
    Ocean Springs, MS
    Just FYI, This will correct the speedometer and the odometer BUT will not correct the cruise control setting. For example.... I put 34's on my truck so my speedometer was 2 mph off. Now the speedometer readout is correct but the cruise setting must be set 2 mph less than I want to be at. From what I have read this is due to the cruise being by the ECM and can't be changed by the calibrator.
  12. Mar 20, 2020 at 7:58 AM
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Did it affect your shift point at all? I'm perfectly happy with my 2020 shift point. running 35 and stock 4.3 rear end.
  13. Apr 6, 2020 at 3:46 AM
    PowerUp
    PowerUp New Member
    2" Lift and 295/65/r20
    How does this work if you have Nav?
  14. Apr 6, 2020 at 6:29 AM
    jpod
    London Canada
    Ok, if you have the nav manual, go to pg 106 the calibration follow till you get to the calibration. If not:
    1 Press the “MENU” button. 2 Select “Setup”. 3 Select “Navigation”. 4 Select “Detailed Navi. Settings”. 5 Select the desired items to be set
    Then:
    The current position mark can be adjusted manually. Miscalculation of the distance caused by tire replacement can also be adjusted. 1 Display the detailed navigation settings screen. (P.106) 2 Select “Calibration”. 3 Select the desired item.  For additional information on the accuracy of a current position: P.114 When driving, the current position mark will be automatically corrected by GPS signals. If GPS reception is poor due to location, the current position mark can be adjusted manually. 1 Select “Position/Direction”. 2 Scroll the map to the desired point (P.75) and select “OK”. 3 Select an arrow to adjust the direction of the current position mark and select “OK”. The tire change calibration function will be used when replacing the tires. This function will adjust miscalculation caused by the circumference difference between the old and new tires. 1 Select “Select after a Tire Change”.  The message appears and the quick distance calibration starts automatically. ●If this procedure is not performed when the tires are replaced, the current position mark may be incorrectly displayed.
    t300, ItsNickROFL and TennTun like this.
