Chris' 1794 Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Cfincke, Jan 8, 2017.
  1. Apr 14, 2019 at 6:52 PM
    #91
    Cfincke
    Cfincke [OP] Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Almost 2 years ago i bought a set of 2017 headlights to retrofit. I held off on retrofitting, debating if i wanted 18+ lights or retrofit. A few months ago @1UPPER was selling his very custom retrofit lights that needed a little work. I picked them, and last weekend he gave me a hand with opening up both sets of lights so the guts of his lights could be transferred to the 17 lights i had. We learned the main reflector bowl is almost impossible to remove from the housing, so we were not able to transfer that. This weekend i finished up painting the main reflector and resprayed the turn signal reflector so i can reassemble the lights.
    Major and 1UPPER like this.
  2. Apr 16, 2019 at 12:32 AM
    #92
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Can't wait to see the retrofit! Awesome build. Love the stories, it felt like I was traveling along with! :thumbsup:
    Cfincke[OP] likes this.
  3. May 19, 2019 at 8:13 PM
    #93
    Cfincke
    San Antonio
    Made some progress on the retrofits today. Got the passanger side projector mounted in and enlarged the holes for all the wires to run thru. Was not able to finish the driver side, as i scratched the painted reflector bowl and exposed some chrome. I would have repainted it today, but it felt like 100% humidity today. I am not going to close the lights up until i wire them up and test everything and check that the cut offs are level and are similar to the stick lights.
    vanthesupreme likes this.
  4. Jul 24, 2019 at 6:33 PM
    #94
    Cfincke
    San Antonio
    Had some time finally to work on the headlights. Got the passanger side RGB lights fully working and tested the switchbacks.
    Had to rebuild the connectors on the RGB and make a Y-cable for the switchbacks
    I took over the kitchen while the wife is out
  5. Aug 25, 2019 at 2:28 PM
    #95
    Cfincke
    San Antonio
    Headlight build is done! That was a lot of work and time.
    Started early this morning at 5:30, so i got to use the KC cyclone lights i have in the engine bay
    Started off with confirming alignment from 25-30 feet away and testing the DRL switch backs, then moved on to testing the RGBs one more time before i pull the lights to seal them up.
    DRL only
    Projector and blinker
    RGBs and blinker
    Then began the process of sealing the lights up and installing. Sorry, no photos during the sealing, was focused on insuring the butal warmed up enough and the lens seated into the channel properly.
    Here is the finished front end
  6. Aug 26, 2019 at 5:44 AM
    #96
    Cfincke
    San Antonio
    Few more photos of the lights from this morning
    vegas4x4 likes this.
  7. Sep 24, 2019 at 5:10 AM
    #97
    Cfincke
    San Antonio
    randomly I was playing with the headlights RGB lights last night. Truck has come a long was in the past 3 years and I still have more plans for it.
    RobertD and salmonfacesalad like this.
  8. Dec 14, 2019 at 10:50 AM
    #98
    Cfincke
    San Antonio
    Replaced the chrome mirror caps with black plastic ones. Down to the door handles to replace.
    Also installed the NSV dash cam. Wired it to the sunroof motor for constant power and ability to record when the truck is off. The screen flips up and the unit is 98% hidden behind the mirror when driving
  9. Dec 14, 2019 at 10:52 AM
    #99
    Cfincke
    San Antonio
    My one and only black Friday purchase is sitting in the garage. Now to save for the LSD and cost for install.
  10. Dec 29, 2019 at 11:51 AM
    #100
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Wow man, tons of upgrades. Truck looks good. Subb’d for future upgrades. Stumbled in here after searching infinite offroad rock lights. Im considering ordering a 12 piece kit, how do u like yours? I see that ur running a ton of them lol
  11. Dec 29, 2019 at 3:41 PM
    #101
    Cfincke
    San Antonio
    Thanks! I am running 24 of the large pod, mine are the first gen which were 6 or 8 watt units with 4 rows of 6 leds. the new large pod is listed as 9 watt and has 6 RGBW led chips, which helps with color blending and a wider spread of the light. I have 1 of the new 9 watt pods sitting in the garage, likely going to order 1 more pod for symmetry and another controller to replace the last IR/bluetooth controller I have with the newer RF/Bluetooth controllers. Since you are are on a 7" lift, you have a lot more distance between the wheel well and the tire and to the ground, so you will get good coverage with the 12 piece. I am on 2.5" front,1" rear lift, so I went crazy to have light coverage.
    vegas4x4[QUOTED] likes this.
  12. Dec 29, 2019 at 6:09 PM
    #102
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    Thanks for getting back to me. U got a ton of lights man lol. The glow must really look sweet in person, i know the pics arent doing any justice. I think I’ll be okay with 12, but the diagram allows for 16 on one controller right? Or am i looking at it wrong?
    Cfincke[QUOTED][OP] likes this.
  13. Dec 29, 2019 at 6:35 PM
    #103
    Cfincke
    San Antonio
    You are correct, you can have up to 16 lights on 1 controller and i did that for a while before i added 8 more lights.
    Here is a pic from a camping trip back in September. It is hard to capture just how bright they are.
  14. Dec 29, 2019 at 7:43 PM
    #104
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    That looks epic! Did too much spending on black friday (full stereo, ‘19 LEDs and fogs, and bakflip tonneau), but my next mod will be this. You’ve officially convinced me. Gonna start with 12, and may add 4 if there are dark spots i dont like :thumbsup:
  15. Jan 13, 2020 at 6:33 PM
    #105
    truefunk
    truefunk New Member
    2020 Cement SR5
    Hello from a fellow San Antonian! Really nice build, where did you get the lights for underneath?
  16. Jan 14, 2020 at 3:38 AM
    #106
    Cfincke
    San Antonio
    I got most from a guy in DFW that was selling an unbranded version of the Infinite Offroad 6w large pods. I had issues with the controllers and replaced with the Infinite RF ones. The rest of the pods are Infinite offroad 6w units. As I add more I will be getting the newer 8w model
    truefunk[QUOTED] likes this.
  17. Jan 14, 2020 at 5:06 AM
    #107
    Cfincke
    San Antonio
    Installed the Diode Dynamics SS3 Pro fog lights into my Magnum bumper
    ckxE9HFPFGSPq9TAyl8C8hRggSicBZLgyDVT7ysr_289ec980fc62ac726f41370d1cf529ac3eed0d8c.jpg
    I thought I had the lights aimed well
    6fQ7dJXPZhAYW6dSI1B5WSro-D8k3CBcj863vrQu_141b335135cf4e4d8fa08cab2129c7a0659a871b.jpg
    But when I backed up from the wall, the Fogs were shining above the headlight cutoff line
    Pp1uFfeZrt5p4gg-7gXmWkP6j-2y-Meb0YPlo3Ro_9931406e6c72c76d15cdc22d0e2a392ad5423f79.jpg
    I adjusted them down a little, but looking at the beam in the fog it may be a hair low now
    rHWqDIc3KBqYoQUMcntQYpP-sq1TmUId8i3hjb95_acd560f305efd7bd84f0217ad775358054e8ded4.jpg
    salmonfacesalad likes this.
  18. Jan 20, 2020 at 5:09 AM
    #108
    Cfincke
    San Antonio
    Relocated the Baja Designs Sport lights to the ditch brackets and replaced the $20 Amazon lights.
  19. Feb 3, 2020 at 5:47 PM
    #109
    Cfincke
    San Antonio
    Got lucky today and picked up a used matching tire from Discount tire for $100. It has a little more tread than my current tires. Just wish I could get a matching 5th wheel, but Method discontinued the machined finish Standards.
  20. Mar 3, 2020 at 5:07 AM
    #110
    Cfincke
    San Antonio
    Dropped the truck off last week for the install of 5.29 gears, Auburn LSD and polyurethane steering rack bushings. Just got the truck back last night and already have 50 miles on it. Still going very easy on the pedal and gears as I am in the break in period. I reached out to DAP this morning to see if I need to have the shift point of the tune adjusted for the gears. At 70mph I am running just below 2300rpm
    IabtIeMkZreKXRx3Q75Vd6LlwaQPFZ0Y98p1k6ks_5e4fbcf7220919d0e6c18caba1346720c3b18730.jpg
  21. Mar 3, 2020 at 5:10 AM
    #111
    Cfincke
    San Antonio
    Ordered the LRA 46 gallon gas tank yesterday, was a little more than the Transferflow tank, but i like the bevels at the front and back, should be here next week, then to recruit a friend to help install
    Trdwillie14 likes this.
  22. Mar 20, 2020 at 7:41 AM
    #112
    Cfincke
    San Antonio
    3-14-2020
    Invited a couple friends over to give me a hand with installing the LRA tank. Luckly one of them is going thru his mechanic certification, so he knew about the fuel line clips and had the tool to spin off the fuel pump lock ring. All total took about 5 hours. Now i have 46 gallons of range.
    DaBoro54 and vanthesupreme like this.
  23. Mar 21, 2020 at 8:11 AM
    #113
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Dude I need this how was it to instal besides the 5 hours and how much did this cost it’s my next project
  24. Mar 21, 2020 at 8:22 AM
    #114
    Cfincke
    San Antonio
    It was not bad, we just took our time. It took a while to drill the frame for the front support bracket. The factory hole used for the bracket was covered by my sliders plate, so I had to drill thru that 1/4" plate too. Getting the fuel line reconnected to the fuel pump was a pain, we had to do it by feel and take photos with our phones to confirm the plastic clip was seated and locked in. The small vent hose that goes back up to the gas cap was 4 inches short, so we ran up to auto zone for a longer hose. We also took a 20 minute break to eat. It was $1900 shipped, the transferflow would have been $1850 shipped. I preferred the beveled front and rear of the LRA tank on the bottom side.
  25. Mar 21, 2020 at 8:28 AM
    #115
    Trdwillie14
    Billy
    2014 trd off road
    Sweet dude thank you. And how far or low does it stick out any pic under the truck? And skids for the future or is it built with a skid
  26. May 9, 2020 at 3:47 PM
    #116
    Cfincke
    San Antonio
    5/9/20
    Ordered some Baja Designs lights the other day from Paul at BD. Swapped the lenes for the amber driving combo. They are to replace the crappy amber lights that came in my grille.
    Got the grille removed and the lights replaced. Having the circuit breaker for auxiliary fuse box makes it quick to kill power to the lights.
  27. Aug 2, 2020 at 10:39 AM
    #117
    Cfincke
    San Antonio
    Drove the camper 800 miles to Navarre Florida for a mini isolation vacation on the beach. This was the first long stretch towing since installing the 529 gears. Truck pulled well, was able to run in 5th on the highway since i only have 34" tires. My rpms in 5th is almost identical to 4th gear with stock gears. Trans temp stayed around 197 the entire way.
  28. Sep 6, 2020 at 8:03 PM
    #118
    Cfincke
    San Antonio
    Got a little dirt on the tires today finally. Took my 2 year old son with me and he fell asleep 10 minutes into the adventure
  29. Sep 6, 2020 at 10:24 PM
    #119
    Sunnier
    Sunny
    San Diego, CA
    How did I never know you have a build thread?!! :notsure: Now I’ve got something new to read! :woot:
  30. Sep 7, 2020 at 9:44 AM
    #120
    Cfincke
    San Antonio
    Yep, I would say I have not done much in the last 2 years since the little one was born, but I just looked thru my build thread and realized all what I have done - headlights, sliders, gears, gas tank, more lights
    Sunnier[QUOTED] likes this.
