Bilstein 5100's in front with stock springs enough to level?
Discussion in 'Suspension' started by rustynail11, Mar 7, 2018.
  1. Dec 5, 2019 at 9:49 AM
    #61
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I installed on the middle setting. I wanted to retain some rake and I got that. The truck is strange though because by eye it looks level, even nose high at times. I can only tell I have rake by measuring, I think it's the giant hood.
  2. Dec 5, 2019 at 11:30 AM
    #62
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    Looks good, I also have a white crewmax, middle setting on the 5100s, used to think it looked nose high, ended up putting a 1" block in the rear, I am happier with the look, doesn't look nose high to me anymore.
    JimboSlice413[QUOTED] likes this.
  3. Dec 5, 2019 at 4:15 PM
    #63
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    I had just the 5100’s on front set to top setting with nothing In rear. Looked ok but to me looked too low in rear. I just added 1.5” shackles to the rear and really like the look. Could possibly add a shim to front but I think I am going to leave as is
    r1-superstar likes this.
  4. Dec 9, 2019 at 9:10 AM
    #64
    GATORthaBEAST
    GATORthaBEAST New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    You got any pics? Let’s see it!!! Thanks
  5. Dec 9, 2019 at 9:14 AM
    #65
    Jeffro22
    Jeffro22 New Member
    Here is with rear shackles installed
  6. Dec 9, 2019 at 11:22 AM
    #66
    Crewmax808
    Crewmax808 New Member
    Honolulu, Hawaii
    2016 Sunset Bronze Mica Tundra Crewmax
    TRD Swaybar, 20"Black Rhino Traverse wheels wrapped in Toyo Open Country ATIIs, Bilstein 5100s on all corners, BAKFlip MX4 Bedcover
    Yeah, I'd like to see it too!
  7. Jan 5, 2020 at 6:41 PM
    #67
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Has anyone ever had the 5100’s installed and aligned and then added the diff drop afterwards?
    I don’t think that would change the steering geometry would it?
  8. Jan 16, 2020 at 11:35 PM
    #68
    sd_cavbluetundra
    sd_cavbluetundra New Member
    2019 Cavalry Blue Tundra TRD Sport
    -Backflip G2 cover -305-55-20 bfg k02
    This just answered every question I had about 5100’s. Thank you sir!
    Beautiful truck btw!
    whiskeydrink[QUOTED] likes this.
  9. Jan 17, 2020 at 12:10 AM
    #69
    wildbill2020
    wildbill2020 New Member
    2020 tundra sr5 crewmax
    5% tint all around, 35% tinted windshield with a 5% brow, removed stickers/decals
    Im new to the Tundra world, and I've seen people talking about shims and diff drops. would i need either of these if i just plan on setting the 5100s at the middle setting?
  10. Jan 17, 2020 at 2:28 AM
    #70
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    No, I have had 5100s on my 2010 since new on the middle setting no issues.
    wildbill2020[QUOTED] likes this.
  11. Jan 17, 2020 at 11:05 AM
    #71
    VBTundra
    VBTundra New Member
    Can you post a direct side shot please? I plan to get a hard cap but I still want some rake afterwards.
  12. Jan 17, 2020 at 11:46 AM
    #72
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    2018 SR5 with 5100's on the middle setting up from and stock setting in the back sitting on 295/55/20 Cooper stt's
  13. Jan 18, 2020 at 1:08 AM
    #73
    wildbill2020
    are those factory wheels?
  14. Jan 18, 2020 at 4:09 AM
    #74
    offshore2005
    TEXAS
    Yes they are.
  15. Jan 18, 2020 at 8:28 AM
    #75
    wildbill2020
    ok thanks! i was trying to decide between 20x9 or 20x10 wheels, but i like the way those sit with the 295s, i may just do tires first and see how i like it before i throw another grand or more at wheels.
    offshore2005[QUOTED] likes this.
  16. Jan 18, 2020 at 11:05 AM
    #76
    sd_cavbluetundra
    From what year tundra? I thought I’ve seen all the stock wheels...definitely not these.
  17. Jan 18, 2020 at 11:36 AM
    #77
    offshore2005
    TEXAS
    2018 4x4 tss package
  18. Jan 18, 2020 at 12:04 PM
    #78
    sd_cavbluetundra
    Such a clean look!!!
  19. Jan 18, 2020 at 12:43 PM
    #79
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    5100s will use your stock springs (unless you purchase them assembled) and the 6112s will come with new springs. Both will work at the top setting. Whether you go for 5100s or 6112s I think it depends on how you will use your truck and your budget.
    When I installed mine, at the time, I could not justify the additional cost of the 6112s and I got the 5100s. Within about 6 months of installing I started off-roading more and regretted not going for the 6112s.
    WxRaider[QUOTED] likes this.
  20. Jan 18, 2020 at 1:02 PM
    #80
    No they are not.
    Those are part of the TSS Dealership Package. Gulf State dealers do this. Most of those wheels are made by Ultra.
  21. Jan 19, 2020 at 12:15 AM
    #81
    wildbill2020
    I just ordered the full set of 5100’s!! Can’t wait to get home from offshore and put them on! From all the post if read and the pictures on the forum, I think I’m gonna put em on the middle setting, and do the 295/55/20’s. Here’s a Pic of my truck the day I got it a few weeks ago. It’s got full window tint(even the full windshield) and pulled all the stickers for now. Once I get the bilstien on, I’ll order tires.
  22. Jan 19, 2020 at 1:45 PM
    #82
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    So, while I was just scanning for suspension upgrade again. I cam across different description on the Front 5100 Height adjustable front shocks adjustable with 3 different lift settings- (.87″, 1.57″, and 2.28″) and on another website its (0" (stock height) to 2.5" of front lift). Which is it?
    I bought a 2" leveling kit. Installed it with the 5100 bottom setting. Do I have a 3" if my 2"+.87? Or still 2" with the 2" level and bottom setting is "0"? My hub center to fender is 24" and I added air in the back to make it 1" higher.
    I did measure my OEM shock's bottom perch to eyelet against the 5100 bottom setting, and 5100 is clearly taller.
    For the past few months, I felt that my tires are too small for the amount of lift I have. But now, I think I have and extra 1" of lift that's why my tires look smaller. I scanned through the all the photo's with 275.65.18 with 2" level kit, they all seam to look right. But my tires looks smaller. I have a big clearance between my fender and tires. Is it just optical illusion? Big tire envy? Insecurity about not having big tires? Trying to keep up with the Jones'? Did I just wasted money in a new set of 295.70.18 AT3 XLT while I only have 6000 miles on truck and tires?
    Please chime in if you know which specification is actually correct.
    Thanks!
  23. Jan 20, 2020 at 1:55 PM
    #83
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    ^^^ This... I have a set of assembled 6112s (2.5") on the way. Been running the 5100s on the middle setting for about seven months and at the top setting for almost a year. I didn't have the money to get the 6112s before but do now. I'm really looking forward to a better ride with the 6112s vs the 5100s on and off road.
  24. Jan 20, 2020 at 2:08 PM
    #84
    GunMetalLou
    GunMetalLou New Member
    19 Gray Tundra SR5 TSS Off Road
    I also have a 19 CM and was debating going 5100. I ended up going with Fox 2.0 non-resi. Love it so far. Huge difference when going off road.
  25. Jan 21, 2020 at 3:11 PM
    #85
    Zum
    Zum New Member
    NS Canada
    With 5100s there at least. 87"s of lift....bottom clip.(if that was your question)
  26. Jan 21, 2020 at 3:48 PM
    #86
    SprinterAE86
    Ian
    Thanks! When ever I see a different description on other off road website I get confused and all juggle up. I measured my OEM against the 5100. The 5100 sits higher. So I have a 2.87 lift instead of 2", that's why my 275.65.18 looks too small for my truck.
  27. Jan 25, 2020 at 8:56 PM
    #87
    pauldrade
    pauldrade Drade Tundra
    Paul
    2013 tundra double cab
    3" lift, 33” tires open country AT2, 18" Mayhem rims, flowmaster exhaust, K&N intake, smoke rear lights and 3rd brake light. Optima RED Top battery, LED Lights all around, Mesh black Grill, Alpine double dash Nav head unit. Suspension 5160s rear 5100s front.
    Can you fit 33x12.5 tires with the 5100s at top setting? Would that be enough anyone know?? Thanks
  28. Jan 25, 2020 at 9:32 PM
    #88
    r1-superstar
    DB
    UTAH
    You should. Depends on the offset though. I'm running 33.6"x12" on 18x9s +25mm with no problems.
  29. Jan 25, 2020 at 9:35 PM
    #89
    r1-superstar
    DB
    UTAH
    Arrived today...Out with the 5100s, in with the 6112s!!! Thanks @BOSS4x4s for the awesome price and fast shipping. It was a ninety minute install. 6112s are so much beefier than the 5100s and they ride SOOOO MUCH BETTER!!!! I had them assembled at the top setting (2.5") and are the same length as the 5100s on the top setting.
  30. Jan 29, 2020 at 7:14 AM
    #90
    sd_cavbluetundra
    Yes at the highest setting you’ll be sitting about 3 cm higher on the front.
    18” method wheels +18 with 35x12.50r18
    mattyd170 likes this.
