Fast blinker?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, Jan 11, 2018.
  1. Jan 11, 2018 at 12:20 PM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    My right turn signal blinker is on hyper speed, left one is normal.
    What causes this and what fixes it?
  2. Jan 11, 2018 at 12:21 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Light bulb is dead. Needs new one.
    Or add more blinker fluid.
  3. Jan 11, 2018 at 12:25 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    either your front or rear turn signal on that side is burnt out, causing the hyper flash.
    NewImprovedRon and TXMiamiFan like this.
  4. Jan 11, 2018 at 1:31 PM
    LML 3500HD
    Don’t listen to these jokers....burnt out bulb...pffftt. I’ll have to post this “how to” video once again, for educational purposes only.
  5. Jan 11, 2018 at 1:37 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    You guys are all wrong! He needs to check is Flux Capacitor!
  6. Jan 11, 2018 at 1:39 PM
    ToyotaTundraMike
    2015 Tundra
    Yes I believe this is it please pm me instructions
    BlueBottle[QUOTED] likes this.
  7. Jan 11, 2018 at 1:41 PM
    ToyotaTundraMike
    2015 Tundra
    Guess I won't be turning right until next time I'm due for service....
    Gonna be a while since they had my truck last week
  8. Jan 11, 2018 at 1:42 PM
    Just spend $2.95 on a bulb and replace it.
  9. Jan 11, 2018 at 1:45 PM
    LML 3500HD
    Jesus man, as a staff member on here, I would expect more sound advice.
  10. Jan 11, 2018 at 1:46 PM
  11. Jan 11, 2018 at 1:53 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Paypal me $20 shipped and I’ll see it out.
  12. Jan 11, 2018 at 3:49 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Yep. The hyoer turn one is out. Front or rear.
    NewImprovedRon likes this.
  13. Jan 11, 2018 at 4:27 PM
    Aurora CO
    Pretty sure Auto Anything has a BOGO blinker fluid sale on now....
    TXMiamiFan[QUOTED] likes this.
  14. Jul 8, 2019 at 5:24 AM
    Ccport59
    Ccport59 New Member
    C
    2010 Toyota Tundra
    Stock
    Mines doing the same thing and both front and back signal lights work
  15. Jul 8, 2019 at 5:40 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    21 SR5 TSS Onroad, 24 Camaro 2SS 6.2 L
    To much to list:)
    A bulb is burnt out or you have a bulb that is not snapped into place all the way.
    waj30 likes this.
  16. Jul 8, 2019 at 5:46 AM
    Ccport59
    Ccport59 New Member
    C
    2010 Toyota Tundra
    Stock
    ok thank you I’ll check it out. Wasn’t sure if it was a relay problem or a bulb problem
  17. Jan 13, 2020 at 7:52 AM
    cshughes79
    cshughes79 New Member
    Chuck
    2015 Tundra 9' lift on 37's
    6' suspension lift with a 3' body lift on moto metals wrapped in toyo open country 37x20x13.50 All memphis speakers in the doors with two 12 subs pushed by to power Rockford amps, LED lights all the way around
    so i have this issue, and all fluids are full ad put brand new bulbs in still hyper flash on both sides of the truck, only time it doesnt is when i turn the hazards on, i even order a blinker relay that goes under the dash and stil the same issue, anyone know if it could be something in the steering column?
  18. Feb 29, 2020 at 12:10 AM
    Berettafan
    Berettafan New Member
    2017 CM
    thanks so much! Such a simple thing. Ran into this issue and thought ‘my lord what is going on here?’ Tundras.com to the rescue!
    Vendeta2k[QUOTED] likes this.
  19. Aug 11, 2020 at 11:28 AM
    Slapnpunch
    Slapnpunch New Member
    2014 Toyota Tundra
    The use of an LED bulb will also cause this hyper blink.
  20. Aug 16, 2020 at 12:24 PM
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
    WHOA! You can't use this blinker fluid, you need synthetic :monocle:
  21. Aug 17, 2020 at 10:55 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    on a BMW motorcycle I had, the blinkers would act funny when the horn fuse was blown.
    I think the idea was that you wouldn't know that your horn didn't work until it was too late, so the blinkers were set up to monitor resistance in the horn circuit and give you some advance warning.
    So... if you can't find anything else wrong, check ALL your other fuses.
  22. Aug 17, 2020 at 11:29 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Dillon Harper?
  23. Oct 14, 2020 at 4:23 PM
    Joseph C
    Joseph C New Member
    So what do I do if I want to put LED bulbs in and not have hyper blinkers?
  24. Oct 14, 2020 at 4:42 PM
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
  25. Oct 14, 2020 at 5:20 PM
    Joseph C
    Joseph C New Member
    Coffee*8) likes this.
  26. Nov 22, 2020 at 8:34 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Customer reviews for this flasher relay indicate that it does not fit 2nd gen tundras.:(
  27. Feb 9, 2021 at 1:58 PM
    RNDABOUT
    RNDABOUT New Member
    17 Quicksand TRD Off-road
    Thx. Kinda helpful!
    What's the part number for synthetic blinker fluid?
  28. Feb 9, 2021 at 4:07 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    #8675309
    GarTX526, shawn474 and JMB like this.
