$1100 Tundra build
Discussion in '1st Gen Builds (2000-2006)' started by lsaami, Oct 8, 2018.
  1. Dec 21, 2019 at 4:16 AM
    #151
    Professional Hand Model
    Fred
    Hand Protectors
    I’m still blown away by the looks of that drained rear diff fluid!
    lsaami[OP] likes this.
  2. Dec 21, 2019 at 6:31 AM
    #152
    lsaami
    lsaami [OP] Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Yep. It’s pretty darn nasty.
    side note, I have a bunch more updates for this thread coming soon. Just been busy.
  3. Dec 21, 2019 at 7:11 AM
    #153
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    What did you ever do about the cab rust?
  4. Dec 21, 2019 at 10:21 AM
    #154
    lsaami
    Minnesota
    nothing. I'm just letting it be for now.
  5. Dec 22, 2019 at 6:29 PM
    #155
    lsaami
    Minnesota
    Been a good few weeks in terms of stuff accumulation, not so much in truck progress as it's been frigid and snowy here, and it's my daily driver.
    First up,
    Parts truck.
    it's an 01 with 237,000 miles on it. RWD, but it has NO RUST!!!!
    fender, door, and bed swap to come soon.
    empty_lord and speedtre like this.
  6. Dec 22, 2019 at 6:40 PM
    #156
    lsaami
    Minnesota
    Also, I caught a black Friday deal. Eibach Pro-Truck all around coming soon.
  7. Jan 5, 2020 at 11:02 AM
    #157
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    what makes it a parts truck? frame rot?
  8. Jan 5, 2020 at 11:14 AM
    #158
    lsaami
    Minnesota
    Price and 2wd.
    honestly the frame is in pretty good shape. It need a ton of work though. Steering issues, tons of vibrations. Runs and drives though. Once I swap bodies I’ll probably turn around and sell it with the rusty body.
  9. Jan 5, 2020 at 11:15 AM
    #159
    empty_lord
    05 rollover special
    ah, was just curious. if the frames in decent shape it may be a good truck for someone who missed out on the frame recall.. should have all the mounts for a front diff and what not
    lsaami[QUOTED][OP] likes this.
  10. Jan 5, 2020 at 11:17 AM
    #160
    lsaami
    Minnesota
    Yep! I tried to convince my brother to frame swap or 4x4 swap to it, but he decided it was too much work.
  11. Jan 5, 2020 at 11:24 AM
    #161
    empty_lord
    05 rollover special
    It’s a big job for sure. Takes the right kind of crazy to do it
    aka me. Lol
  12. Jan 11, 2020 at 10:32 AM
    #162
    lsaami
    Minnesota
    Yo, It's been a while.
    Last weekend I installed my new rear shocks, bump stops, the ECGS bushing, and tried to do the front shocks. Unfortunately, I ordered 2.5" coilover shocks instead of shocks for my eibach shocks, so I have to return those and get the right ones. It'll be a couple weeks before from shocks go in.
    also, ECGS didn't fix my vibrations, so I ordered a diff drop kit and another u-joint. Well see if that solves it.
    Filthyphil, mcharfauros and speedtre like this.
  13. Jan 25, 2020 at 8:17 AM
    #163
    lsaami
    Minnesota
    Installed the Diff drop a week or so ago, and it helped the vibes, but didn't fix them. I need the truck to get to and from work RN, so I'm just gonna let 'er buck for a bit. Running great and my MPG is back up now that my commute is longer.
    Waiting for warm weather to pick up the body swap again.
    speedtre likes this.
  14. May 14, 2020 at 7:01 PM
    #164
    lsaami
    Minnesota
    Been a while since I’ve updated y’all. Not much has changed. I finally got new springs and the front shocks are assembled. I’ll be installing them hopefully this weekend.
    also, today I installed some new ignition coils.
    A7CF6840-A310-4D48-802F-1C96A5531429.jpg 8418A8F5-FB83-4EB9-87A9-8694E4691D07.jpg
  15. May 15, 2020 at 11:45 AM
    #165
    speedtre
    speedtre New Member
    Inland Northwest
    Do those happen to state if they are made in China or the USA? I've heard some MSD coils are made in China and some are made in the USA.
  16. May 17, 2020 at 6:31 AM
    #166
    lsaami
    Minnesota
    The box says China. :(
  17. May 22, 2020 at 3:06 PM
    #167
    lsaami
    Minnesota
    Got the drive shaft back from the shop. They replaced the orielly u joint I put in last fall, and balanced the shaft. Still the same thing. I’m beginning to think it’s my cheapo CV axles. Everything else has been replaced.
    Filthyphil likes this.
  18. May 24, 2020 at 5:37 AM
    #168
    FirstGenVol Brake Czar
    2002 AC
    I can't remember if someone asked. Did you already replace the needle bearing? Supposedly that vibration only goes away in 4x4 if that's your problem.
    I also liked someone suggestion of the road force balance.
    NUDRAT likes this.
  19. May 24, 2020 at 3:34 PM
    #169
    lsaami
    Minnesota
    I replaced the needle bearing with the ECGS bushing.
    Most likely thing I’m going to try next is CV axles, then redo tire balance.
    anyone have suggestions for high quality aftermarket CV axles?
  20. May 24, 2020 at 3:39 PM
    #170
    empty_lord
    05 rollover special
    Napa remans are decent. If not those fancy off-road ones that were recently posted in the what have you done thread, (spacing out on the name)
  21. Jun 20, 2020 at 7:26 PM
    #171
    lsaami
    Minnesota
    YUUGE progress update!
    installed new CVJ reman axles with high angle boots.
    also installed my “rust-free” bed, and fluid filmed underneath the flares.
    installed the front fenders and flares
    ind painted the topper!
    Installed ditch lights:
    And installed a new reverse/rear-facing combo light.7D897890-066A-4121-9082-A568AE116CCF.jpg
    And here’s how she sits today. I’m currently waiting on new steering rack, powers steering lines, and I’m working on swapping doors next.
    rebmo, Filthyphil, MS22 and 2 others like this.
  22. Jun 20, 2020 at 8:20 PM
    #172
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Why are you in Australia?
    Other than your seemingly strange location change, Great work!
  23. Jun 20, 2020 at 8:21 PM
    #173
    lsaami
    Minnesota
    Not sure why it does that sometimes. It’s wierd...
    Tundra2[QUOTED] likes this.
  24. Jun 20, 2020 at 8:22 PM
    #174
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You could try editing the picture before you upload it, and rotate it 180°. Then upload the "fixed" picture.
    If the picture is already "right-side up" on your end flip it over anyway, and fake the system out. :rofl:
  25. Jun 20, 2020 at 8:28 PM
    #175
    lsaami
    Minnesota
    That’s way too much work. I’d rather you all just flip over your computer screens. :smash:
    FirstGenVol and Tundra2[QUOTED] like this.
  26. Jul 26, 2020 at 7:09 AM
    #176
    lsaami
    Minnesota
    New doors, and Compustar auto start/keyless entry!
    02CEBE69-9C08-4CFD-A55B-F9D354526905.jpg C731D828-8DA6-43FF-B081-F25B57950FE7.jpg
  27. Jul 26, 2020 at 2:14 PM
    #177
    lsaami
    Minnesota
    New kicks! Got em in a craigslist steal for $160. Got a full size spare on a stock wheel too! 16x8 American racing with 1/3 life Nitto Terra Grapplers. They’re old and pretty worn, but they’ll get me through the summer.
    F4BB9954-5688-40E6-AEED-4FBFBEDB59FE.jpg D5EAEEBF-98E5-4D40-A45D-77E7EB7861C4.jpg 14BA4320-AA28-44ED-A3D1-027D9E4D917E.jpg
    rebmo, Boerseun and Tundra2 like this.
  28. Oct 1, 2020 at 12:54 PM
    #178
    lsaami
    Minnesota
    no pics, but since the photos, I've installed a new head unit, rear speakers, and amp and subwoofer.
    Also, Recently ordered some Milestar Patagonia M/Ts. They'll get installed before winter.
    Filthyphil, MS22, empty_lord and 2 others like this.
  29. Oct 28, 2020 at 5:44 AM
    #179
    lsaami
    Minnesota
    new kicks installed. the 25-mile review is this:
    They drive fantastic under 50MPH. over 50, they wander, they shake slightly due to the tread pattern, and they are the opposite of confidence-inspiring in turns, making the truck feel like a big boat, rocking back and forth. We'll see how they do over the next few thousand miles, but I'm unimpressed at this point.
    They look dam sick though!
    rebmo, Filthyphil, MS22 and 1 other person like this.
  30. Oct 28, 2020 at 5:47 AM
    #180
    lsaami
    Minnesota
    hard to believe I started the journey with this truck two years ago! man how time has flown...
    rebmo, Filthyphil, Rex Kramer and 2 others like this.
