Portable jump start packs?
Discussion in 'Recovery & Gear' started by heytat, May 28, 2018.
  1. Dec 27, 2019 at 2:49 AM
    Zero One Actual
    I have two different sized NOCOs from Amazon and have used them on other people’s vehicles multiple times. They work as advertised every time so far.
  2. Dec 27, 2019 at 3:11 AM
    ToyotaTundraMike
    ToyotaTundraMike Not A New Member
    2015 Tundra
    I have one from Sams / Costco that’s a Stanley Fatmax 1000. Has a battery starter, air compressor, LED work light, and several USB charging ports. Charge it up all the way and it lasts a really long time. Love mine.
  3. Dec 27, 2019 at 10:01 AM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Which ones do you have?
  4. Dec 27, 2019 at 10:27 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I purchased this one as well, Audew. Worked great. I was able to crank over an old vw karmann ghia without a battery with this thing. We shall see if it saves the day in a dead battery situation over the next few years.
  5. Dec 27, 2019 at 6:11 PM
    Zero One Actual
  6. Dec 27, 2019 at 8:08 PM
    jordan0317
    Jordan
    Martin, TN
  7. Dec 27, 2019 at 8:26 PM
    Keoki_m
    Keoki_m New Member
    I wanted the gb40 from Amazon. There was a Black Friday deal on it unfortunately, it doesn’t ship to Hawaii :(
  8. Dec 27, 2019 at 8:50 PM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
  9. Dec 27, 2019 at 10:47 PM
    GSD
    GSD New Member
    Seattle, WA
    2019 Platinum Crewmax
    I've purchased the one's that Costco carries and keep one in every car/truck. Had to use one on a previous Jeep I had as it rarely got driven and battery would always drain down. Having one also saved me when I showed up to ride and my snowmobile battery was dead (no pull start). They're also small and easy to store.
    I'd recommend getting into a routine of charging them on a consistent basis, I usually pull them from all the cars and charge them every Spring & Fall.
    Zero One Actual likes this.
  10. Feb 28, 2020 at 5:25 PM
  11. Feb 29, 2020 at 3:50 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Before we BUY one, we'll look for it at Costco, we BUY a lot of 'stuff' there!
  12. Dec 25, 2020 at 6:58 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum-SOLD 2022 Sequoia, Celestial Silver Metallic
    Got the Audew 2000A for Christmas. It's all charged up and in the truck. :muscleflexing:
  13. Dec 25, 2020 at 10:15 PM
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
  14. Dec 26, 2020 at 5:32 AM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I had 2 gooloo models that I really liked until one went bad. The replacement is a Noco. Higher price but seems to be built better.
  15. Dec 26, 2020 at 6:04 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
  16. Dec 26, 2020 at 7:52 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    I have the DBPower one from Amazon ... https://www.amazon.com/gp/product/B07DWSYYZR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I've used it a few times and it has always worked right away. Only used it on my Tundra once (purposely left stuff on to run the battery down so I could test it) but i've used it on 2 newer F150's and an older 2007ish E350 van.
  17. Dec 26, 2020 at 8:09 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Mag 2650 w/76mm pulley, ADS suspension, 35's, misc overlanding doo-dads and lights
    I have a couple of the DBPower ones. I keep one in my truck and have used it to start everything from dirtbikes to fullsize V8's. Works great.
  18. Dec 26, 2020 at 8:26 AM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Based on the video provided in this thread I’m going to look at Audew. The NOCO shit the bed in that video. I was surprised because that’s the brand I was looking at.
  19. Dec 26, 2020 at 9:20 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    I just used the Audew 1500A on my son-in-law's Camry last night. Worked like a champ, but that's all of 1 use. It was $52 around BF and is back up to $70 now on Amazon.
    BTBAKER[QUOTED] likes this.
  20. Dec 26, 2020 at 12:02 PM
    #50
    Nueces
    Nueces New Member
    Texas Hill Country
    2002 Tundra SR5 AC
    I ran Antigravity Battery ones for a while, an XP-10 and two XP-10HDs. After about 15 months, all three split open while riding in a vehicle. I had been charging them for a few hours only, every 6 months. Trash, in my book. I replaced them with Noco Boost GB40s, but have not used one yet. Nice to hear others have good experience. Note: for convenient storage on my Molle panel Bartact seat cover in the Jeep TJ, one of these units fits perfectly in a magazine pouch designed for M14 mags. In the Tundra, this pouch fits in a side pocket of a Duluth Trading Cab Commander, which I have on the pax seat back. The battery cables and charger fit in a vinyl bank deposit bag.
  21. Dec 29, 2020 at 11:39 AM
    #51
    Omen
    Omen New Member
  22. Dec 29, 2020 at 1:42 PM
    #52
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
  23. Feb 14, 2021 at 9:47 PM
    #53
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    Sorry for the zombie thread revival.
    Just wanted to respond to this question and give some feedback.
    I read this thread and watched the video when it was a live topic. I bought the Audew.
    I charged it and put it, in its case, in my backseat storage compartment and just basically forgot about it.
    Zoom forward to Polar Vortex 2021.
    My town was hit with ice and freezing, and for 2 days we had no power. With 5 phones, 2 laptops, 3 iPads, etc.. we made due with the Audew for charging a lot of stuff. After sitting for over a year, it still had about a 90% charge.
    I didn’t have to jump a vehicle with it yet. But I did have to use it, and it worked.
    tbutler and AZBoatHauler like this.
  24. Feb 15, 2021 at 6:04 AM
    #54
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
    Since you revived it. My battery has been going dead if I don't drive it for around 4 or 5 days.
    I have a NOCO Boost Pro GB150. I used it three times to jump start the Tundra without charging it.
    Last time it was 16 degrees out the battery had 8.5 volts.
    It took all it had to start the last time so I charged it right after that.
    I have replaced the battery with a NAPA Legend 27F. Hopefully this will be the end of having to jump start it.
    If not I have complete faith this NOCO will get me out of a bind.
  25. Feb 15, 2021 at 6:14 AM
    #55
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
  26. Feb 15, 2021 at 6:26 AM
    #56
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    Well. I just use an 18v Milwaukee battery. Attach some 8 awg to each terminal and voila! Also jump started a random lady’s engine at Whole Foods Newport Beach a few weeks ago using battery from my shop vac and some wire.
    panicman and FirstGenVol like this.
  27. Feb 22, 2021 at 2:41 PM
    #57
    Dwarven1
    Dwarven1 New Member
    Ross
    2018 SR5 w/TRD Off-Road.
    2018 SR5 - Bolo Mark XXb - Unit DNE of the Line. "Denny"
    Interesting. I have what appears to be identical to this one, only name branded "MEGAWISE". https://smile.amazon.com/gp/product/B08FD6Y933/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Was able to jump my beastly old Gen 1 with that when the battery started failing this winter. I was impressed enough to buy one for all three vehicles we have.
  28. Feb 22, 2021 at 4:33 PM
    #58
    For you guys that live in hot climates, Do NOT keep them in your trucks all the time. There has been cases of where the batteries have swollen and caught the vehicle on fire.
    AZBoatHauler likes this.
  29. Feb 22, 2021 at 5:10 PM
    #59
    Dwarven1
    Dwarven1 New Member
    Ross
    Wow. Good warning.
    Fortunately, I can safely ignore it... sometimes it gets over 90 in Vermont. Not real often, thank Ghu.
  30. Feb 22, 2021 at 5:26 PM
    #60
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
