Mobile Antenna Farm 2.0 - Build Thread
Discussion in '2nd Gen Builds (2007-2013)' started by Lars, Jan 3, 2017.
  1. Jan 3, 2017 at 11:02 AM
    Lars
    Lars [OP] Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    How it looked the day I brought it home (Jan. 2, 2017)
    As of June 14, 2018
    * Electrical
    * Genesis Offroad Dual Battery Tray
    * Odyssey PC25-1400 (x2) batteries
    * 100a Circuit Breakers (x2)
    * Radios Powered on one
    * Off Road Lights powered on second​
    * Smittybilt XRC 12k Winch​
    * Radios
    * Yaesu FTM-400XDR installed
    * Laird NMO Mount 2m Antenna
    * Laird NMO Mount 70cm Antenna
    * Comet Du/Diplexer(takes single VHF/UHF output and splits for 2 monoband antennas)​
    * Icom IC-7100 installed
    * Comet Du/Diplexer (takes single VHF/UHF output and splits for 2 monoband antennas)
    * TarHeel Little Tarheel II on Breedlove Bed front mount.​
    * Midland MXT-400 GMRS installed
    * Laird NMO mount GMRS antenna​
    * Anytone SmartCB installed
    * Browning Base Load NMO Antenna​
    * Armor
    * Demello Plate Front Bumper
    * Trail Toys High Clearance Rear Bumper
    * Demello Dominator Rock Sliders
    * RCI Fuel Tank Skid (10ga Powder Coated Steel)
    * RCI IFS Skid (1/4" Aluminum)
    * RCI Transmission/Transfer Case Skid (1/4" Aluminum)
    * Victory Offroad Rear Diff Skid​
    * Lift
    * Bilstein 6112 Front Coilovers Set on the top ring
    * Bilstein 5160 Rear Shocks
    * Camburg 1.5" Rear Shackles
    * Camburg Uni-Ball Upper Control Arms​
    * Wheels/Tires
    * Stock Rock Warrior 17" Wheels
    * 315x70 R17 Cooper Discoverer STT Pros
    * 1" BORA off road wheel spacers​
    * Next?
    * 4.88 Gears front and rear
    * ARB Air Lockers front and rear
    * ARB Dual Compressor OBA.​
  2. Jan 3, 2017 at 1:11 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Definitely keeping an eye on this build. I take it you're still debating on lift and tire size?
  3. Jan 3, 2017 at 1:19 PM
    Yes to all!
  4. Jan 3, 2017 at 3:58 PM
    Lars
    Lars
    Cedar Creek Texas
    And So it begins.
    I'm a big fan of Ram Mounts.
    Kenwood TM-D700 control head.
    Icom IC-706MKIIg control head.
    AnyTone SmartCB - This would have fit UNDER the lid if I didn't need to connect coax to it.
  5. Jan 3, 2017 at 4:04 PM
    Lars
    Lars
    Cedar Creek Texas
    Yeah, I think I'd like to do 2.5" up front with Camburg UCAs and longer travel shocks. a 1" shackle lift in the rear (again with slightly longer travel shocks) and then see if I can stuff 37" meats under the truck and not have it look terrible.
    Only thing is, I don't know where the limits are on the Tundra the same as I did on the Tacoma. 35" tires on the Tacoma without re-gearing is brutal. And breaking CVs every time I take it out doesn't sound like a good idea either.
    Would I be better off looking at 35" tires for a truck that'll crawl more than the local Simon Mall?
  6. Jan 3, 2017 at 4:07 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    Sub'd. Especially interested in the control head and antenna feeds from the roof/headliner/pillars
    Lars[OP] likes this.
  7. Jan 3, 2017 at 4:12 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I'm not an expert on suspension yet, but it seems that most of the builds on here that have 37's are on 6" lifts or so. It may be possible to fit 37's on a lift less than that, but one of the true suspension experts on here (off the top of my head that'd be @Sean266, @ColoradoTJ, @csuviper, @jberry813) would be better suited for that question. @bandit and @Spvrtan both fit 37's on their Tundra's with LT kits. On a 3/1 suspension lift with wheels that have an offset of +12 to +30mm, it seems to be fairly easy to fit 35's.
    joonbug and Lars[QUOTED][OP] like this.
  8. Jan 3, 2017 at 4:12 PM
    Lars
    Lars
    Cedar Creek Texas
    Here's a Gallery of photos from when I installed radios (Plural) in my previous Tacoma. Aka. Breakfast Taco, Mobile Antenna Farm (v1.0)
    SouthBoundSteve likes this.
  9. Jan 3, 2017 at 4:17 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    I measured for 37's (non-drop bracket and non-LT). It's doable, but not without some work. With +18 offset on a 9" wide wheel, you'd need to remove front mudflaps, tub all of the pinchweld, cutting a shitload off the cab mount (more than just a normal CMC..basically a rebuild), trimmed or removed skid plate, remove fender aprons, tub the core support, and you'll need an aftermarket front bumper or cut the shit out of the plastic bumper cover all the way to the fog lights.
    Stormtrooper81 and zcarpenter92 like this.
  10. Jan 3, 2017 at 4:49 PM
    Lars
    Lars
    Cedar Creek Texas
    35s it is :)
    zcarpenter92 likes this.
  11. Jan 3, 2017 at 6:04 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What he said ^^
  12. Jan 3, 2017 at 8:34 PM
    Lars
    Lars
    Cedar Creek Texas
    I can't wait for the finished product. (At least from the electronics / radios standpoint).....
    Going to put one of these under the cup holders, next to the long thin pocket with my CB.
    This will be there to power each of the three transceivers, and the APRS Transmitter.
    It'll be wired to the battery with a 100a circuit breaker, into a 100a relay.
    The relay will be switched allowing me to cut any residual draw from the radios (The APRS Transmitter is 10w and beacons every 5 minutes, and runs a GPS 24/7 otherwise)
    I'll put this switch next to the Tow/Haul(ass) switch in front of the shifter.
    Cat3ILS likes this.
  13. Jan 3, 2017 at 11:14 PM
    Cat3ILS
    Link for the distribution box?
  14. Jan 3, 2017 at 11:16 PM
    Lars
    Lars
    Cedar Creek Texas
  15. Jan 3, 2017 at 11:18 PM
    Cat3ILS
    Niceee :thumbsup:
  16. Jan 8, 2017 at 6:22 AM
    Lars
    Lars
    Cedar Creek Texas
    I got to spend a little time yesterday working on my truck.
    My fog lights got a significant upgrade.
    These are Black Oak Spotlight pods. Each is 40w, putting out ~3200 lumens on each side.
    The brackets are from Rigid. I had to purchase M3 screws to mount the Rigid brackets to my Black Oak pods since the thread pitch was different than what Rigid D2 lights ship with, but other than that it's a prefect match.
    I also got a little further in the wiring projects.
    Blue Sea Systems 6 circuit fuse panel
    TrailToys No Strings Attached - (This is an 8 channel, wireless light relay box.)
    I'm still waiting on a few more things, like battery terminals, but it's starting to come together.
    I've got a 30" single row NiLight bar I'm going to put in the lower grill opening. It's too deep to fit anywhere in the upper grill it seems.
    I've also got a pair of 18w NiLight flush mount LED Pods that I'll mount on Rigid "Angle Down" brackets on the back bumper. These will get wired with a diode to the factory reverse lights, as well as to the NSA from Trail Toys.
  17. Jan 8, 2017 at 5:31 PM
    Lars
    Lars
    Cedar Creek Texas
    Finished the core of my power wiring.
    4awg from the battery, into the cab, under the cup holders.
    I finished up wiring in the two Circuit Breakers, and NSA from TrailToys.
    And I got a single night shot of the front end with the Black Oak Spots turned on.
  18. Jan 8, 2017 at 5:33 PM
    Lars
    Lars
    Cedar Creek Texas
    My next big projects will be:
    * Drilling 3/4 holes in the roof to mount NMO Antennas
    * Installing the radios behind the rear seats
    * Running Coax from the headliner down to the radios
    * Running control cables to the radios
    * Running Microphone cables to the radios
    Cat3ILS likes this.
  19. Jan 9, 2017 at 12:57 PM
    Lars
    Lars
    Cedar Creek Texas
    This is going to drive me crazy....
    What will it take to make my headlights the same K value as the LEDs? Without being a dick to oncoming drivers. (so no drop in HIDs.)
    HALP!!!!!
  20. Feb 18, 2017 at 1:39 PM
    Cat3ILS
    Any update or cool pics???
  21. May 3, 2018 at 12:27 PM
    Lars
    Lars
    Cedar Creek Texas
    New Shoes . 315-70r17 Cooper Discoverer STT Pro tires.
  22. May 3, 2018 at 12:28 PM
    Lars
    Lars
    Cedar Creek Texas
    I've got a bunch of new Radio Equipment coming in over the next three days. When it all gets here my goal is to spend most of Sunday installing it all in the truck and running all the wiring.
    smslavin likes this.
  23. May 3, 2018 at 12:31 PM
    Lars
    Lars
    Cedar Creek Texas
    RCI 1/4" Aluminum Engine, Transmission, and Transfer Case Skids ordered
    RCI 10 gauge Steel Fuel Tank Skid ordered.
    RCI Heavy duty step sliders ordered (I realize these are basically steps and not sliders, that's ok. for this build.)
    Fox Coil Overs for the front
    Fox Remote Reservoir rear shocks
    and Camburg Rear shackles 1.5" Lift all ordered
    Watt maker and zcarpenter92 like this.
  24. May 3, 2018 at 12:32 PM
    Lars
    Lars
    Cedar Creek Texas
    Stock Fog lights are replaced with Rigid SAE fogs in Rigid mounting brackets.
    Black Oak 40w 10 degree spots mounted as ditch lights on Ragu Fabrication Mounts.
  25. May 3, 2018 at 1:34 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    looking forward to seeing how you do this. i still have to get my yaesu mounted.
  26. May 3, 2018 at 1:46 PM
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    Would like to see the antennas mounted. I see one 2m/440 antenna by the hood. That is a better mount than cutting holes in the roof. I have a Kenwwod TM-V71A and a Yaesu FT-857. Looking to install a scanner in there somewhere.
  27. May 3, 2018 at 2:04 PM
    Lars
    Lars
    Cedar Creek Texas
    Body of the Yaesu FTM-400XDR
    Control head, and external speaker
  28. May 3, 2018 at 2:06 PM
    Lars
    Lars
    Cedar Creek Texas
    Currently the antenna for this Yaesu is on a Trunk/Hatchback edge mount, on the drivers side of the hood.
    I have "stake Pocket" antenna mounts coming that are designed for 3/8x24 thread CB style mounts. I'm going to drill the hole out for UHF thread antenna mounts, and put a pair of Comet SBB-5 antennas on the front set of Stake side pockets.
    The rear pair will get a 2' Firestick on the passenger's side, and my HF antenna on the driver's side.
  29. May 3, 2018 at 2:08 PM
    smslavin
    Hudson Valley
    Some stuff
    this is the radio i need to mount as well. considering mounting the body into the center console but i'll probably need to cut at least one ventilation hole. how is the face plate mounted to the dash? RAM or something else? i'm looking for option to put mine in the headliner console between the map lights. there's some unused space there next to the sunglass holder.
  30. May 3, 2018 at 2:10 PM
    Lars
    Lars
    Cedar Creek Texas
    I put two screws through the mount that came with the radio into the top of the dash... :)
    If I hadn't put the brains of the radio in the passenger's side foot well, I would have attached it to the back wall behind the rear seat. (Double cab) I put it where I did so I could access the USB Port, and the MicroSD card slot for Programming.
