  1. Dec 15, 2019 at 5:31 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not all LEDs look the same even with the "same" color temp though. These are 5000k but the lumen output makes a difference too.
  2. Dec 15, 2019 at 5:44 AM
    Professional Hand Model
    Fred
    Hand Protectors
    True.
    And not all bulbs put out the lumens they are rated when LED which is why I went with the Sylvanias in the areas I did. I believe their product numbers over the other no name brands even though I’ve never had no name bulb problem. I have no lumen tester except for the eyes.
    Per incandescents, the older bulb filaments reduce in lumens as they wear, accumulate debris on coils, etc.
    because_wumbo-truck likes this.
  3. Dec 15, 2019 at 6:24 AM
    Fred
    Hand Protectors
    Not sure if my other rear side parking brake cable is like this pictured drivers side that recently had the bearing installed. This may very well be why my parking brake isn’t self adjusting due to it not running under that lip. Not sure as the parking brake issue has gone on for much longer than this bearing service (month and a half ago). Disappointing to see this as I trust others to do as I would to them. Maybe an oversight on my mechanics behalf? He ain’t a rookie. The new bearing seal failing torks me a bit too. @Aerindel
  4. Dec 15, 2019 at 6:41 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Waxed it and then read about the PCV valve, so now that’s on order. I checked mine and it’s threaded so I’m assuming it should be even easier and nothing to worry about like the grommet versions on the earlier models?
    NUDRAT, bmf4069, speedtre and 4 others like this.
  5. Dec 15, 2019 at 6:43 AM
    Bubbles
    Bubbles Decent!
    Sunnyvale Trailer Park
    05 Tundra Limited, 96 Supra Turbo 6MT
    Tell me you have a build thread in the works. I love your truck!
  6. Dec 15, 2019 at 6:43 AM
    Bulldog_tundra
    USA
    2006 Double Cab
    Good to know, Ill get this knocked out then. Need to search for a part number now.
    Good deal, thank you. Got to find the part number and then I’ll get it ordered. Seems like the PCV and breather are cheap insurance.
  7. Dec 15, 2019 at 7:04 AM
    Fred
    Hand Protectors
    ‘Top end’ makes even more sense to me as the discussion was about torque and power of the engine.
    TX-TRD1stGEN[QUOTED] likes this.
  8. Dec 15, 2019 at 7:15 AM
    FirstGenVol Brake Czar
    2002 AC
    Your paint looks really good. Well done.
    I think your threaded PCV will still rest in a grommet.
  9. Dec 15, 2019 at 7:17 AM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    Threaded pvc uses threads, no need for a grommet. The new one even has thread sealant pre applied in the package
  10. Dec 15, 2019 at 7:32 AM
    2002 AC
    Doh! Makes sense. I was thinking it still needed a gasket of some sort to seal it, but I see now that it doesn't. That lack of grommet means he's got a lot less to worry about when making the swap. 5 minute job now
    speedtre likes this.
  11. Dec 15, 2019 at 7:34 AM
    bmf4069 Yup, that's car parts in a dishwasher
    It's mainly to eliminate the cap as a failure point. If it gets stuck it'll push diff juice out the axle tubes and into the rear brakes. Call it preventive maintenance.
  12. Dec 15, 2019 at 7:36 AM
    Probably. It's a cheapo I bought two years ago. But, trucks not on so who knows.
  13. Dec 15, 2019 at 7:40 AM
    SOS CONCEPTS
    SOS CONCEPTS SOS Concepts
    ^^^^^This^^^^^ Eddy the owner of SOS had a first gen tundra and made some one off stuff for himself for it. Sadly he didn't make any templates or keep any measurements. This is also when he was in his rented one car garage building stuff with an angle grinder, welder, and measuring tape. I'll try and dig up the pictures.
    I would buy this in a heartbeat for my '05.[/QUOTE]
    The problem with doing a streamline for the 1st gen is there is no real clean area to cut the factory bumper and make it look integrated and not like the bumper was hacked.
    Thanks man and we do, I am a bit biased though. Our armor is tested via the real world not just computer generated load testing. Eddy sits down with a vehicle and kinda gets an idea builds then tweaks and has people test for a bit if he's not happy it doesn't go into production until he's happy. We've had a modular besttop bedrack being tested pretty hard for 3 mo. now.
    speedtre[QUOTED] and Bubbles like this.
  14. Dec 15, 2019 at 7:53 AM
    cammiller
    cammiller IG: cameron.a.mi
    Cameron
    Sulphur, Louisiana
    2004 Toyota Tundra Limited Phantom Grey Pearl
    Kicker speakers, Pioneer AVH-2550NEX Head Unit, DynaMat, LED Dash Conversion
    Definitely not intentional, but this happened to my truck today. 79D09B6F-F68F-49DC-BC6D-6C4FFD0702FA.jpgJust driving down the road and I see my lug nuts falling off. So now I need my drum resurfaced and I’m going to hammer in some new bolts and all should be good.
    hammeron, Filthyphil and Darkness like this.
  15. Dec 15, 2019 at 7:54 AM
    Good info. I'll add a little to it that maybe some don't know yet. Basically, 2700K is a standard incandescent lamp. 3000K and 3500K make a good color option when replacing lamps in your house. 4100K is typical in most commercial buildings. 5000K is what's used in Walmart. Much higher than that is typically used in specific aplications.
    A note about lumens: your typical 10w A19 bulb has 800 lumens, give or take. A 3000K and a 5000K will have the same lumens, but the 5000K will appear brighter due to the whiter color.
    My opinion, I'd go with a 3000K or 3500K due to the redder light. It won't mess up your night vision like a whiter light would. It probably doesn't affect it much, but who knows.
  16. Dec 15, 2019 at 7:55 AM
    :eek2:
    What? How? Why? Uhhhh......
    Filthyphil and KarmaKannon like this.
  17. Dec 15, 2019 at 7:57 AM
    SOS CONCEPTS
    Just as an FYI instead of making your own LEDs, super bright LEDs already makes interior LEDS like you just did just have to match up the style. I switched a lot of mine over using theirs. Relatively in expensive and time savings.
    The chevy's I know had rust issues on a lot of their parts I was a tech at a dealership and we were replacing rear brake assemblies like crazy because they would turn to rust dust. Also I've seen other trucks from up N and holes in the floor and body were common same with pretty rusty frames. I think people just jumped on Yotas shit more and they decided to man up about it.
    No their frames are C channel it wasn't until a few years ago that they started switching to boxed frames and definitely not any thicker from back comparing similar models.
    Here's the Point all vehicle manufacturers have their issues and weaknesses. If one were to build a vehicle that is going to last the ages across any or all different climates and hold up to non typical wear then they wouldn't meet any price points people could afford. Even though trucks are becoming outrageously expensive now.
  18. Dec 15, 2019 at 8:08 AM
    SOS CONCEPTS
    There is a guy on TW that is a lighting engineer or guru of sorts he has made a bunch of good threads on there about stuff.
    Ummmm drum brakes and actually self adjusting :rofl:. Sorry as a mechanic this is hilarious none of them work period. In the engineers theory they work and maybe on the computer they work. But real world it's laughable that's why we recc adjustments from time to time.
    But no your mechanic should of put it back correctly and if that were the case in how he treated the parking brake cable then there is a possibility that he didn't get the seal installed correctly or nicked it or something.
    Bubbles likes this.
  19. Dec 15, 2019 at 8:43 AM
    Bubbles
    Bubbles Decent!
    I wouldn’t run anyone’s armor but Eddy’s. And @ovrlndkull i remember that first place allllll to well!
    SOS CONCEPTS likes this.
  20. Dec 15, 2019 at 8:55 AM
    SOS CONCEPTS
    I wasn't around for that shop but since meeting and getting involved with SOS it's grown leaps and bounds in the past couple of years. SOS is working at expanding into new markets and groups and it's fun to be a pretty big part of that. I am lucky/honored to be in the position I am and work with Eddy on this stuff. Re-introduction of products etc. Just so you guys know my bumpers are coming last to all other orders I put other customers above mine. My rear HC rear bumper I will of waited probably close to a year if not longer before I get mine.
    There is a reason we are targeting you 1st gen guys. It's like the little bit bigger brother to the tacoma and you guys get out and use your trucks offroad more than the other generations. We still want to support them but it's a little different market.
    Rheywood456, NUDRAT, speedtre and 3 others like this.
  21. Dec 15, 2019 at 10:58 AM
    speedtre
    speedtre New Member
    Inland Northwest
    I saved a copy....:DScreenshot_20190721-214317-01 (1).jpg
  22. Dec 15, 2019 at 11:16 AM
    Fred
    Hand Protectors
    Per the self adjusting parking brake: After many years of them not working properly and trying this past year to ‘get it right’ by ‘following the directions’ has been futile. I’ve gone to the self adjusting star via peep hole adjustment method as the one that actually works for me. This new wrinkle of the cable just occurred to me last night when studying the plan for the warranty repair.
    I’ve seen that guru light guys work. Someone reposted his stuff over here a few months back. Good stuff!
    SOS CONCEPTS[QUOTED] likes this.
  23. Dec 15, 2019 at 11:22 AM
    Fred
    Hand Protectors
    Probably won’t ever need another bulb there ever again but good to know. This was plan ‘B’ and I had a few extras from a multi-pack left over. Its fun making things happen for ‘free’.
  24. Dec 15, 2019 at 12:00 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    off-brand 1st Gen
    As others said do it as preventative maintenance. FYI, there's one on the rear diff, but also one on the front diff & one for the trans. Cheap insurance to keep things healthy.
  25. Dec 15, 2019 at 12:09 PM
    SOS CONCEPTS
    The tundra front, trans, and T-case breathers aren't routed into the engine bay?
    Yep that's the only method that ever works I always get a laugh when guys freak out that they aren't working or I bust their bubble that it never works even doing exactly what you're supposed to do.
    Yeah I have to read his stuff a few times to understand some of the technical stuff but it's really good info and unbiased just lets the #s and tests show what works and what doesn't.
    Nice!!! I tried making my own and soldering in LEDs on an old civic I had it was a total failure I am not that good at making them. So when I found these guys that make them it was a eureka moment for me.
  26. Dec 15, 2019 at 12:15 PM
    SOS CONCEPTS
    What about PNW trucks do they get rusted to shit like the rust belt areas here on the East?
  27. Dec 15, 2019 at 12:15 PM
    Fred
    Hand Protectors
    I got lucky on this bulb fab. Didn’t even use solder. Carved off the end tip wings, spread the wires, fed them through the OEM bulbs old prong posts and crimped the ends. The OEM base module actually helps lock every thing together even better once the prongs reinserted.
  28. Dec 15, 2019 at 12:50 PM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    Picked up a really nice mint steering wheel from S54_LXTundra and decided to leather wrap it. Im really happy with how it turned out. Thanks again bud! :thumbsup:
  29. Dec 15, 2019 at 12:54 PM
    Fred
    Hand Protectors
    Which wrap is that? Looks good.
  30. Dec 15, 2019 at 1:03 PM
    ESTundra937
    Eddie
    San Diego
    Thank you! I picked it up from ebay. Pretty inexpensive and was actually easy to install. The only negative was the thread amount included was just enough to get it done.
    Look at this on eBay https://www.ebay.com/ulk/itm/312204357369
