Battery size and options
Discussion in 'General Tundra Discussion' started by csuviper, Dec 24, 2016.
What battery brand do you use on your Tundra?
  1. AC Delco
    0.9%
  2. AutoCraft
    1.2%
  3. Bosch
    0.6%
  4. DieHard
    2.7%
  5. Duracell
    2.1%
  6. EverStart
    2.7%
  7. Exide
    0.3%
  8. Interstate
    10.2%
  9. Kirkland
    0.9%
  10. NAPA
    2.1%
  11. Northstar
    17.2%
  12. Odyssey
    12.0%
  13. Optima
    8.1%
  14. Stock for now :(
    38.9%
  1. Dec 28, 2016 at 5:46 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    NorthStar 27F has my vote for my needs.
    Well over the needed CCA's for when it is cold (1,080 - 930)
    along with the needed Ah for when the weather is hot (91 Ah)
    As some one stated earlier it will hold and provide the necessary feed for an aftermarket audio system
  2. Dec 30, 2016 at 9:38 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ok NorthStar and odyssey are tied. I will choose the one I can get the best deal on.
  3. Dec 31, 2016 at 7:04 AM
    joeguam
    joeguam New Member
    JOE
    I bought a battery to fit my needs vise popularity. The Odyssey met my needs but the NorthStar met and exceeded the demands of the accessories installed on my truck with additional cushion. I have an original Optima yellow top still going strong with 15 plus years and counting, by paper specifications the Northstar and Oddyssey looks to beat it with no problem.
  4. Dec 31, 2016 at 2:30 PM
    csuviper
    Broomfield, CO
    Northstar - $339.99
    Group: 27F
    Part#: NSB-AGM27F
    Height: 8.86
    Width: 6.77
    Length: 12.44
    Terminal Configuration: SAE
    Pulse Cranking Amps: 1750A
    CA/MCA Rating at 32F: 1080A
    CCA Rating at 0F: 930A
    Reserve Capacity 195 min
    Capacity - 20 hour Rate: 92Ah
    Short Circuit Current 5000A
    Warranty: 4 years full
    Odyssey Performance - $241.12
    Group: 27F
    Part #: 34R-790
    Height: 7.91
    Width: 6.78
    Length: 10.85
    Pulse Hot Cranking Amps: 1500A
    Cold Cranking Amps: 792A
    20hr Nominal Capacity: 61Ah
    Reserve Capacity: 114 min
    Odyssey Extreme - $275.77
    Group: 27F
    Part #: 34R-PC1500T
    Height: 7.82
    Width: 6.78
    Length: 10.85
    Cold Cranking Amps: 850A
    20hr Nominal Capacity: 68Ah
    Reserve Capacity: 135 min
  5. Dec 31, 2016 at 2:35 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    Mine (No manufacturer's name, just that it's a 27F and sold by Toyota) will be replaced in the near future. It has no discernible date code, which tells me it's probably the factory battery. I'd planned on replacing it before now, but as the saying goes: "Shinola happens". When I do replace it, it'll be with a Die Hard AGM. The price difference between Die Hard and either North Star or Odyssey is too great. I ran Optima's for years, but the last few have had short life spans and some sellers limit the warranty to 18 months. Something I didn't realize until one died shortly after the 18 month warranty expired. It says a lot about the quality of a battery when the seller calls bullshit on the factory 3 year warranty.
  6. Dec 31, 2016 at 2:47 PM
    gosolo
    Ray
    NW Oregon
    Nice information my Tundra brother!
  7. Dec 31, 2016 at 8:28 PM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    I can still get you that deal ;)
  8. Dec 31, 2016 at 9:42 PM
    csuviper
    Broomfield, CO
    Probably going that route. Sent you a PM.
  9. Jan 4, 2017 at 7:45 AM
    csuviper
    Broomfield, CO
    Ok i just purchased the NorthStar Ultra High Performance AGM 27F Battery. Excited to have my truck start in the mornings again.
  10. Jan 4, 2017 at 5:19 PM
    joeguam
    joeguam New Member
    JOE
    The weight is a beast but it has the handles to help you install. ;) So where is your vote? It was tied at 5 before you purchased.
  11. Jan 8, 2017 at 9:24 PM
    csuviper
    Broomfield, CO
    Moved my vote to NorthStar.
  12. Jan 9, 2017 at 4:27 PM
    joeguam
    joeguam New Member
    JOE
  13. Jan 11, 2017 at 7:22 PM
    csuviper
    Broomfield, CO
    Did some of my own measuring:
    Stock is 7 15/16 tall not including posts (8 7/8 with), 11 7/8 wide and 6 3/4 deep.
    The northstar is 8 1/16 tall not including posts, 12 1/2" wide and 6 3/4" deep.
  14. Jan 11, 2017 at 7:25 PM
    gosolo
    Ray
    NW Oregon
    Interesting that the dimensions differ from your 2012 and my 2015. Makes me want to double check everything before I buy.
  15. Sep 24, 2017 at 6:08 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Sorry to res an old thread but does Diehard make an AGM battery that fits our truck? When I search their site it comes up with Group 34 but based on above it looks like we use size 24 or 27?
  16. Sep 24, 2017 at 6:44 PM
    I have the Odyssey Extreme that’s kept nice and secured thanks to @Coupe battery bracket
  17. Sep 24, 2017 at 6:49 PM
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Yes, I am running an AGM Group 27 Diehard battery
    1lowlife and Otaku4life69 like this.
  18. Sep 24, 2017 at 7:04 PM
    TundraDan723
    Excellent. Thanks!
  19. Sep 25, 2017 at 10:57 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Northstar all day long, because....all day long
  20. Sep 25, 2017 at 3:22 PM
    #50
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    On my second battery. Called dealer, quoted $120.00 for a new Tundra battery with 24 month warranty. I replace every 3 yrs..under preventive maintenance.
    Paid...:mudding: Turned key vaaaaaaroooom!! left dealership..:burnrubber::burnrubber:
    SouthBoundSteve likes this.
  21. Dec 15, 2017 at 6:48 AM
    #51
    I’m enjoying the Odyssey extreme.
  22. Dec 15, 2017 at 7:08 AM
    #52
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    $150 otd rebranded Johnson Controls AGM in size 24f w/3 year warranty. We shall see how it performs.
  23. Jan 17, 2018 at 9:45 AM
    #53
    Perfected
    Perfected New Member
    2004 Toyota Tundra Double Cab V8 4WD
    Currently, from what the previous owner put in, I have an AC Delco Professional Silver (35PS) - Group 35.
    Thing still works if it doesn't get too cold, however it's over 5 years old I believe. Not bad for a $100 battery.
    NorthStar batteries look nice, however... very expensive.
    May just get another AC Delco one. If it can last me atleast 5 years, and its only $150 or so, then I'm satisfied....
    Hmm... we'll see.
  24. Jan 17, 2018 at 9:53 AM
    #54
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I'm a cheap ass ! This battery is coming up on 1 year.
    Perfected likes this.
  25. Jan 26, 2018 at 4:47 AM
    #55
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    I think Just may go with the Odyssey AGM, a local dealer has it for $260
    ChucklesToy likes this.
  26. Jan 26, 2018 at 12:24 PM
    #56
    Tracker
    Tracker New Member
    Shane
    Where did you get the battery cover?
  27. Jan 30, 2018 at 3:01 PM
    #57
    1BadTundra
    Clinton
    Too Much to List
    The fuse box cover or battery tie down? I made both. The sticker is from ebay, I painted it green, then laid the sticker over it. The Battery tie down is 1.5" Stainless, drilled out with different size bits.
    #57
  28. Feb 17, 2018 at 9:32 PM
    #58
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Another Odyssey Extreme on my 07 Tundra
    NewImprovedRon, Y0TA PR0 and T-Rex266 like this.
  29. Feb 17, 2018 at 9:33 PM
    #59
    Just add this!
  30. Nov 23, 2018 at 6:59 PM
    #60
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5 4x4
    2010 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T 2020 Stock
    I put a 49EXT O’reilly auto parts (super start) battery in about a year ago. It sits on the tray, rather than in. But I have no problem leaving auxiliary lights, 2 12” subs, or powering any other accessories while out camping. It’s 900 CCA with a 185 minute reserve capacity.
    Didn’t see any one else mention the 49 group size, so just wanted to mention that it’s a option! :)
