2008 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Jor, Dec 7, 2019.
  1. Dec 7, 2019 at 2:28 PM
    Jor
    Jor [OP] New Member
    I am eyeing a used 2008 Tundra with 3 owners in Texas, nice car both interior and exterior.
    120k Miles.
    What major issues I need to check before sealing the deal?
  2. Dec 7, 2019 at 2:31 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Water pump leaks
  3. Dec 7, 2019 at 2:40 PM
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    Check the frame.
  4. Dec 7, 2019 at 2:45 PM
    Hvactech24
    Hvactech24 MGM
    Kentucky
    2013 Rock warrior double cab
    2-1/2” front leveling kit, spider trex wheel spacers, line-x bed liner, change all lights over to led bulbs interior, exterior, and headlights. All bulbs are from headlight revolutions, RCI skid plates. RCI running boards
    Cam tower leaks?
    08crewmax likes this.
  5. Dec 12, 2019 at 5:57 AM
    Jor
    Jor [OP] New Member
    What major issues can I expect from a 2007 Tundra? 4wd? Any issues. Going for a test drive on 2007 one.with 110k miles. Coat around 13k
  6. Dec 12, 2019 at 6:45 AM
    grannynancy
    grannynancy New Member
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    I have a 2007 with 160K. Other than routine injector, brakes etc., all I have had was a starter motor go out and that was NOT a cheap repair.
  7. Dec 12, 2019 at 6:48 AM
    Jor
    Jor [OP] New Member
    How expensive was that
  8. Dec 12, 2019 at 6:53 AM
    grannynancy
    Nancy
    Upstate SC
    2007 DC TRD 4WD
    I would have to pull the paperwork but I think close to 1K and I am glad we had AAA plus because it rode on a flatbed from Robbinsville NC to Asheville NC as nobody local could deal with it. Still had to drive from Greenville SC to Asheville NC to pick it up.
  9. Dec 12, 2019 at 6:59 AM
    Jor
    Jor [OP] New Member
    Ooh ok. That's not bad .and is it running fine? Well that u can expect on a old vehicle. Not like my Jeep which is already broken at 16k mikes
  10. Dec 12, 2019 at 7:02 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    (AIP'S) Air Injection Pumps :cool:
  11. Dec 12, 2019 at 7:07 AM
    Jor
    Jor [OP] New Member
    And how much for that
  12. Dec 12, 2019 at 7:42 AM
    rons23
    Ron
    Kill Devil Hills
    Pricey! 3-4K. It would be good if you could get the history , maybe they were replaced. There is also a bypass kit and some other options to fix it. Just type it in the search box on the site, you should find some threads on it.
  13. Dec 12, 2019 at 7:43 AM
    Jor
    Jor [OP] New Member
    The one has 2 owners , all repairs done at Toyota dealer. It don't mention anything of AIP. That's what keeps me worried.
  14. Dec 12, 2019 at 1:14 PM
    Tundra_power
    Tundra_power New Member
    Honestly you should be fine i have an 08 with 102,000 and it keeps running. And i dont drive slow either ;)
  15. Dec 12, 2019 at 1:16 PM
    Tundra_power
    Only issues was the starter but check for leaks at the cam tower. Its should have the gray rtv i think thats the good one. And for me the aip system i usually wait a minute after starup so they can close their valves. What kills them are snow/salt and water.
  16. Dec 12, 2019 at 2:18 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Check in the bed and underneath at the four corners where it mounts to the frame. Certain runs of tundras from 07-12 have issues rusting from the underside up. A quick search for Tundra bed rust issues will show you what your looking for.
  17. Feb 15, 2020 at 5:16 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I purchased my 007 in 017 with 270,000 miles on the 5.7L. I replaced the fuel pump within the first month and I added a DAP tune to eliminate the AIP issue before it happened. The truck has 291,000 miles on it today and it's my reliable daily driver.
