Lifted Truck Alignment Pros Chime in!
Discussion in 'Suspension' started by throughitalldude, Oct 21, 2019.
  1. Nov 15, 2019 at 11:01 AM
    #61
    throughitalldude
    throughitalldude [OP] New Member
    Jeff
    Southern California
    2017 Platinum
    3/1 Lift |TSS 20" Wheels | 35 Cooper AT3 XLT | Flowmaster 40 Series Exhaust
    Sounds like you and I were literally in the same boat as one another.
  2. Nov 15, 2019 at 2:44 PM
    #62
    DM 2018 Tundra
    DM 2018 Tundra New Member
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Yea. I might try the KO2 when my wear out. Called David at CB and should have them Tuesday or Wednesday.
  3. Nov 18, 2019 at 2:13 PM
    #63
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    So I did alot more driving this weekend and noticed that at speeds below 50 I am golden the truck drives amazing. When I get onto the highway its a little different still have some steering wheel reaction to the road. Alignment shop believes that it could be the stock struts being too soft....... my caster is maxed out currently and it cannot go any higher. I am comparing my truck to my previous truck which was a 2012 Crewmax with 3" spacers and 35" tires. I feel like the steering on that truck was rock solid where this truck the steering wheel to put it simply is sensitive. SO with all this being said I am still trying to hunt down the solution to the higher speeds issues. A shop near me installs alot of these spindle lifts and claims the only things they could imagine is a fix is alignment and/or wheel balance which both are dialed in. So I am still on the prowl truck drives nice its not TERRIBLE but those little things Im just trying to figure out.
  4. Nov 18, 2019 at 3:24 PM
    #64
    DM 2018 Tundra
    2018 Limted Tundra
    Hate to hear that you still having issues with. I got mine back and after the balanced all my tires again it drove like a different truck!! But I know I have to hit a rough interstate tomorrow and I see how it does. My CB tie rod ends should be here Wednesday. If tire wear on outside still bad And bump steer I will be putting the CB on. Keep me posted and good luck!!
  5. Nov 18, 2019 at 3:28 PM
    #65
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    What from CB are you putting on for the bump steering his tie rod ends?
  6. Nov 18, 2019 at 3:30 PM
    #66
    DM 2018 Tundra
    2018 Limted Tundra
    Yea. David said it will help with outside tire wear and bump steer.
  7. Nov 18, 2019 at 4:31 PM
    #67
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Starting to play with PSI and dropped it down to 35psi seemed worse. Took it up to 45psi actually a noticeable improvement.
  8. Nov 19, 2019 at 8:56 AM
    #68
    DM 2018 Tundra
    2018 Limted Tundra
    I am at 36 all four. Came from 40 psi
  9. Nov 19, 2019 at 9:03 AM
    #69
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Ya did alot of driving this morning and I am noticeably better at 45PSI. Less wheel movement......Smoother ride and having felt any wobble as of yet. I think as the tires wear since they are brand new I should get better and better.
  10. Nov 19, 2019 at 9:15 AM
    #70
    DM 2018 Tundra
    2018 Limted Tundra
    I try 45 today
  11. Nov 19, 2019 at 9:15 AM
    #71
    DM 2018 Tundra
    2018 Limted Tundra
  12. Dec 2, 2019 at 9:36 AM
    #72
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    How did the CB Steering Kit help ? did you get it on?
  13. Dec 2, 2019 at 3:33 PM
    #73
    DM 2018 Tundra
    2018 Limted Tundra
    Still has not got here yet!! I ordered it Nov 14. Just got an email today from David that it was shipped today so it I should have it within 3-5 days. Truck drives really good so far just them rebalance all 4 tires.
  14. Dec 2, 2019 at 3:33 PM
    #74
    DM 2018 Tundra
    2018 Limted Tundra
    You still having issues?
  15. Dec 2, 2019 at 4:15 PM
    #75
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Im actually doing very good..... truck has no shake still has slight bump steering on really bad roads but nowhere near a degree i feel i should be worried at all. I will eventually jump up too the CB Steering kit as well which i have been told will eliminate it completely. Excited to hear how it does for you.
  16. Dec 2, 2019 at 4:50 PM
    #76
    DM 2018 Tundra
    2018 Limted Tundra
    David told me that it will fix my issue and be able to cycle more when I hit dips in the road. I am hoping to have them put on next week if I get them by Friday.
  17. Dec 4, 2019 at 3:00 PM
    #77
    DM 2018 Tundra
    2018 Limted Tundra
    Just got the tracking number!! Be here Friday Night!! Sucks I will be out of town. But I sent you some pictures of them when I get back. 7634374D-6BB8-4336-8068-E44E8C7F3933.jpg
  18. Dec 6, 2019 at 7:01 AM
    #78
    DM 2018 Tundra
    2018 Limted Tundra
    Hey man just got an email saying that my tie rod ends are at my house. We went camping this weekend and when I get back I send u some picture of them before I put them on.
  19. Dec 6, 2019 at 9:19 AM
    #79
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Sounds good curious to hear how they do for you.
  20. Dec 9, 2019 at 1:57 PM
    #80
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Just pulled the trigger on CB steering kit as well...... over all the vibes and movement in the wheel. Touched base with David @Coachbuilder1 one more time to ensure this would help me and he was extremely confident these are going to make alot of my problems disappear.
    DM 2018 Tundra likes this.
  21. Dec 9, 2019 at 2:01 PM
    #81
    DM 2018 Tundra
    2018 Limted Tundra
    Great to here!!! I have not made it home yet but when I do I will unwrap them and send you a picture!!!
  22. Dec 11, 2019 at 6:06 PM
    #82
    DM 2018 Tundra
    2018 Limted Tundra
  23. Dec 11, 2019 at 6:27 PM
    #83
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Look extremely nice! Excited to hear about the difference they make.
  24. Dec 11, 2019 at 6:38 PM
    #84
    DM 2018 Tundra
    2018 Limted Tundra
    Me too!!!
  25. Dec 23, 2019 at 8:55 AM
    #85
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Installing my CBs tonight you ever get yours on?
  26. Dec 23, 2019 at 12:58 PM
    #86
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    CBs are on tough to tell how they feel truck needs to be realigned badly
  27. Dec 23, 2019 at 1:16 PM
    #87
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
    Here are my stock ends. Boots are pretty blown out from the bottom and you can move the threaded rods by hand extremely easy. Safe to say they were pretty much done. CB's were so tight I could not move them by hand.
  28. Dec 23, 2019 at 1:29 PM
    #88
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  29. Dec 23, 2019 at 1:32 PM
    #89
    throughitalldude
    Jeff
    Southern California
    2017 Platinum
  30. Dec 23, 2019 at 1:34 PM
    #90
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    If your issues haven't been resolved or acts up again, I recommend Bear Frame and Wheel in La Puente. @BestGen told me about 'em and I have been very happy with their work.
