LED switch out for my 2010 SR5 TRD CM
Discussion in 'Lighting' started by TRD FreddieZ, Dec 30, 2016.
  1. Dec 30, 2016 at 8:30 AM
    TRD FreddieZ
    TRD FreddieZ [OP] New Member
    Fred
    2010 Sliver SR5 TRD Tundra
    Did LED swap out with Christmas gift cards. Got AUXBEAM heads and highs which are amazing. put JDM ASTAR in the fogs and really not happy with them. Heads and highs are so bright that you lose the fogs totally. Fog lights are not focused beams anymore. But heads and highs are so bright that cant even notice the difference when I turn on 25in Nilight LED light bar. Would recommend AUXBEAM for LED switch out.
    • [​IMG]
    Auxbeam
    Auxbeam F-16 Series H13 LED Headlight Conversion Kit with 2 Pcs of Headlight Bulbs CREE LED Chips Hi-Lo Beam - 40W 4000lm Low Beam & 80W 7200lm High Beam Built-in CANBus
    Cat3ILS likes this.
  2. Dec 30, 2016 at 8:54 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Congrats. Do you have any comparison shots? Do you now get flashed a lot from oncoming vehicles?
    TheBeast likes this.
  3. Dec 30, 2016 at 9:11 AM
    Let's see night shots down a road lows n highs
  4. Dec 30, 2016 at 9:12 AM
    TRD FreddieZ
    Fred
    Forgot to take comparison pictures. But will post nighttime photos later. Not getting flashed but did ride around last night to see how they are tracking. I adjusted aim of lights switch from 0 to 3 seems to get better road coverage. May go back to regular bulbs in the fog lights cause they ain't doing a thing. Was thinking about going yellow cause of 4am ride to work.
  5. Dec 30, 2016 at 9:15 AM
    TRD FreddieZ
    Fred
    Will take pictures tonight and post themy asap.
  6. Dec 30, 2016 at 9:19 AM
    TRD FreddieZ
    Fred
    Put AUXBEAM F-16 for heads and F-S2 for highs.
  7. Dec 31, 2016 at 4:51 AM
    TRD FreddieZ
    Fred
    1st picture is high beam and head light. 2nd picture is just head lights. 3rd is head lights only also.20161230_230140.jpg 20161230_230132.jpg 20161230_214655.jpg
    Cat3ILS, 14burrito and PermaFrostTRD like this.
  8. Jan 2, 2017 at 5:00 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    are these just plug and play with rubber booty modification?
  9. Jan 2, 2017 at 5:07 PM
    TRD FreddieZ
    Fred
    No modifications needed. Unplug old light, plug in new harness and install light.
  10. Jan 7, 2017 at 10:07 PM
    Jwow530
    Jwow530 New Member
    Jay
    2002 Toyota Tundra TRD
    Hey I have 2002 tundra and led haven't been working right I was wondering how u adjust the beam and did u need a decorder resistor?
  11. Jan 8, 2017 at 5:44 AM
    TheBeast
    TheBeast The Beach
    looks good. I have HIDs right now but wouldn't mind trying LEDs.
    check the morimotos XB fog lights. nice match to my HIDs
  12. Jan 8, 2017 at 12:34 PM
    TRD FreddieZ
    Fred
    I have a adjustment knob on the dash to raise and lower the head lights. Mostly for towing but it helpseems flash back with LED lights. There is alooking an set screw on the bulb itself to rotate the leds. No additional canbus adapter needed just plug and play with harness that can with bulbs. Hope this helps.
  13. Jan 8, 2017 at 1:05 PM
    dandailey
    Dan D
    Newport News Va.
    Spweak engwish.
    NewImprovedRon, CM-LENNY and TheBeast like this.
  14. Jan 8, 2017 at 4:21 PM
    TRD FreddieZ
    Fred
    Sorry I was at work plowing snow.
    dandailey and NewImprovedRon like this.
  15. Jan 8, 2017 at 6:33 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Those look pretty good... I would say probably the best LED replacement pics I've seen. Do you think they are better than halogens?
    tomsinamerica likes this.
  16. Jan 8, 2017 at 6:40 PM
    TRD FreddieZ
    Fred
    Oh he'll yes. I can actually see the road now. Amazing how bright they are.
    TruckyTruck likes this.
