DIY: James 12volts Remote Start
Discussion in 'General Tundra Discussion' started by T-Rex266, Sep 1, 2019.
  1. Sep 1, 2019 at 1:41 PM
    T-Rex266 [OP] Elon approved Staff Member
    I had the opportunity to jump in on this GB from @james@tech12volts. At $200, for a complete plug & play how can you not? Out here, in CO this would make it convenient for the truck to warm up before hitting the snow, or for it to cool down on our blistering days (right now its 96* outside)
    This setup was described as complete plug & play. If you're paranoid like me, and not fantastic with electrical then it does not get any easier than this! James provided a video (link here along with instructions via e-mail.)
    It was pretty straight forward:
    Step 1:
    Disconnect battery and then remove the plastic sill on drivers side
    Step 2:
    Remove panel under steering column. 10mm bolt on each side.
    Step 3:
    Gently pull down on the panel after you have removed the two (2) 10mm bolts until it pops loose.
    Step 4:
    Remove both Philips screws with a screwdriver on each side of the steering wheel. It's best to start your truck so the wheel can easily turn from left, to right.
    Step 5:
    Gently pull down the steering column at the seam.
    Step 6:
    Unplug factory ignition harness:
    Step 7:
    Plug the male part ignition of the remote start unit into the female factory harness. Then plug the female part of the harness, into the male ignition plug.
    Step 8:
    Remove the OBD II connector from the mount. This is located under the panel, on the left hand side. It pops out rather easily with a flat head to press the release.
    Step 9:
    Replace it with the male 26 pin plug from the remote start harness. (Factory plug pictured first) Then connect the open two together.
    Step 10:
    Remove the 10mm ground screw, and add the black ground wire to it that is supplied in the kit.
    Step 11:
    Remove the bottom panel of the passenger side dash. I used plastic to pop them off. It doesn't take any force for the clips to release.
    Step 12:
    Unplug the factory TPMS connection. (follow the yellow tube; the connection is up, at an angle and comes out easily)
    Step 13:
    Take a long zip tie (or wire hanger) and feed the TPMS connection that came with the kit, behind the center console and to the passenger side.
    Step 14:
    Plug the TPMS connector from the harness into the TPMS female connection. Then, plug the female part of the harness into the the factory TPMS connection.
    Step 15:
    Reconnect battery (no photos required here)
    Step 16:
    Go back to drivers side. Take the module that came with the kit. Press and hold the programming button, and connect the remaining plug into module until you see both red and blue on at the same time.
    Step 17:
    When BOTH red and blue are lit, release and plug in the remaining small harnesses into the module.
    Step 18:
    Press the program button two (2) times at a normal pace.
    Step 19:
    Turn the key to accessory mode. (should flash rapidly 10 times on control box) It should then flash a steady blue. After a few seconds of it flashing blue, turn off ignition.
    Step 20:
    Close the doors. Press the lock button on the factory fob three (3) times at a normal pace. After you hit the lock command three times, it should start right up!
    https://youtu.be/4jeGhr1gwWc
  2. Sep 1, 2019 at 2:48 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :popcorn:hopefully tomorrow or next weekend for me. Just finished painting the house. Time for a nap!
    Black Wolf, Migraine and T-Rex266[OP] like this.
  3. Sep 1, 2019 at 5:00 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Great DIY. Thanks for posting it up!
    MyFj08, jewsNbrews and T-Rex266[OP] like this.
  4. Sep 1, 2019 at 6:48 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Nice write up! Interesting that your TPMS is on the passenger side...also for my 2019, I did not pull down the dash under the steering wheel column. Just the panel on the left side :)
    T-Rex266[OP] likes this.
  5. Sep 2, 2019 at 9:17 AM
    Plenty of time. Shouldn’t take too long
    Migraine likes this.
  6. Sep 2, 2019 at 9:23 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice work Sean. I know how you love tackling wiring projects lol. I'm very proud of you buddy! This looks like a really nice remote start set up, a plug and play set up is pretty freakin sweet. James comes through again with an affordable yet useful mod.
    Migraine, jewsNbrews and T-Rex266[OP] like this.
  7. Sep 2, 2019 at 9:31 AM
    @T-Rex266
    Great write up. I tried to PM you this.
    Step 8, just remember that.
    If you bring your Tundra in for service ( I brought mine in for the TSS sensor recall/update) the Toyota laptop used to do this couldn't find my computer/Tundra. They tried 3 different computers until 1 very smart Toyota Tech realized the remote start. He unplugged step 8 and plugged it into that.
    The Toyota computer is very sensitive and needs to be directly into the OBD II port. Very simple, once done plug the mod back together and your good to go.
    **Just wanted to post this so if anyone has any problems you don't want them tearing apart your truck.
  8. Sep 2, 2019 at 9:38 AM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    Will this remote start allow you after driving to leave the engine running and lock/unlock the doors with the FOB ?
  9. Sep 2, 2019 at 9:40 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
  10. Sep 2, 2019 at 9:48 AM
    Doubtful. I would never encourage that either.
  11. Sep 2, 2019 at 9:49 AM
    Thanks!
    Lol u know how I hate wiring! This was perfect for a guy like me that doesn’t want to deal with splicing everything lol
  12. Sep 2, 2019 at 10:00 AM
    Pudge
    CT
    :thumbsup:
    Stroke250 likes this.
  13. Sep 2, 2019 at 10:19 AM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    I have had this with the last 5 trucks I’ve owned. GMs do it from the factory. No problems man. It’s just nice to leave the truck running for the pup when you go into a gas station and lock/unlock it while running.
    texasrho83 likes this.
  14. Sep 24, 2019 at 12:00 PM
    TURK8875
    TURK8875 New Member
    SKIPPER
    May I ask where you ordered the kit from?
    Thanks,
    Skipper
  15. Nov 13, 2019 at 8:26 AM
    tundradownsouth
    tundradownsouth New Member
    New Orleans
    19 tundra crewmax
    Quick question would the paid subscription be required for the mycar app? don’t really care for the gps feature just want the ability to unlock and remote start with the phone
  16. Nov 13, 2019 at 8:30 AM
    nowayout
    nowayout New Member
    NY
    17 CM
  17. Nov 13, 2019 at 9:06 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    This remote start does allow for leaving the truck running with key out of the ignition. You'll have to look it up in the owner's manual for the button combination. And the group buy is still on.
    TURK8875 likes this.
  18. Dec 10, 2019 at 6:15 PM
    dru741
    dru741 New Member
    2014 Silver Tundra SR5 TRD CM
    So I have never been part of a group buy, was wondering if there is one soon or how does it work? Would love to get this remote start for my truck, especially now when it’s freezing out!!
  19. Dec 10, 2019 at 6:47 PM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
  20. Dec 10, 2019 at 7:58 PM
    dru741
    dru741 New Member
  21. Dec 11, 2019 at 8:59 AM
    Omen
    Omen New Member
    I can vouch for the stellar customer service on this group buy. I bought my 2018 CM used and had already joined the group buy before realizing the previous owner had already installed this very system. I reached out and explained the issue and was refunded right away. I will be doing business with the seller in the future and you should join with confidence.
    AZBoatHauler and T-Rex266[OP] like this.
  22. Jan 17, 2020 at 10:37 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Uhhhh....[QUOTED] likes this.
  23. Jan 17, 2020 at 3:17 PM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anyone know where these go lol this was supposed to be plug n play
  24. Feb 6, 2020 at 1:07 AM
    primeiro
    primeiro New Member
    Henk
    Netherlands
    i bought mine 3 month ago, and istalled it yesterday, got a lot of feedback from james12volt , questions where answed fast.
  25. Apr 3, 2021 at 10:58 AM
    HMS
    HMS New Member
    This does work on the 2019 Tundra, right?
  26. Aug 6, 2021 at 8:11 AM
    browniemix33
    browniemix33 New Member
    New Hampshire
    2017 Metallic Grey Tundra Limited 4WD
    Great write-up, what I've heard this is the best remote starter out there for Tundras. Looking forward to installing mine this fall to combat the NH winters...
    jewsNbrews likes this.
