OEM Bedlights
Discussion in 'Lighting' started by scurdyness, Dec 29, 2016.
  1. Dec 29, 2016 at 3:39 PM
    scurdyness
    scurdyness [OP] One thing is sure, uncertainty is certain
    William
    Fort Smith, AR
    2017 MBM Platinum_BlackOps
    TRD CAI, TRD Dual Exhaust, TRD rear sway bar, TRD shift knob, T-Rex Sport grilles upper and lower, full window tint and brow, de-chromed, powder coat OEM wheels, blue LED interior, Winjet Tails, Retrofit headlights
    Folks,
    Seen a few posts on here regarding OEM (factory fit LED bed lights), here is a pic of what they look like under a bedcover. Works for me!
    NewImprovedRon likes this.
  2. Dec 29, 2016 at 4:04 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Where did you tap into the truck for these lights?
  3. Dec 29, 2016 at 4:37 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Where is that wire located? The instruction shows the tap behind the driver dash.
  4. Dec 29, 2016 at 4:51 PM
    scurdyness
    William
    Fort Smith, AR
    Can't help you, It was a factory option at invoice, sorry
  5. Dec 29, 2016 at 5:01 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    That's perfect! I have a test light so I will do that. I don't like their instruction either.
    How did you come into the cab?
    What did you use as a ground?
  6. Dec 30, 2016 at 7:16 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    damn @RowdyRon u r da man! thanks! I will try to document this procedure for others.
