Old Argon bottle for emergency air?
Discussion in 'Off-Topic Discussion' started by Jerry311SD, Nov 25, 2019.
  1. Nov 25, 2019 at 5:18 AM
    Jerry311SD
    Jerry311SD [OP] New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Can I use a old Argon bottle for air off road? I dont have 300$ to buy on already set up.
    Just for airing up tires maybe an air gun for a quick tire change? If I change the valve on the bottle and put a regulator on it?
    Also where would I get the parts from to do this and where would i go to have it filled?
    Or amI just retarted and should go buy one already set up.
  2. Nov 25, 2019 at 6:52 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I would make sure the bottle has no leaks and the connections are good! A welding supply place that can also have the air for the tank.
    Jerry311SD[OP] likes this.
  3. Nov 25, 2019 at 7:08 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You should be able to get it filled with CO2. It will likely need to be recertified.
    Or hit up a welding/industrial gas place and see if they'll let you trade it out for a certified CO2 tank.
  4. Nov 25, 2019 at 7:59 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Warning lights and horns are going off in my head right now.
    Argon = flammable. Cylinder would have to be absolutely clean of argon. Pressure level of compressed gas cylinders = 2000 to 3000+ psi. If certification is expired, cylinder would need to be retested and restamped. Cylinder shut-off valve and regulator would have to rated to the full pressure rating of the cylinder. Since there is potential liability, you may have trouble getting a legitimate gas supplier to co-operate with your plans.
    Black Wolf and Pinay like this.
  5. Nov 25, 2019 at 8:14 AM
    Shark Bait
    Shark Bait Not new anymore
    2019 Platinum
    Argon is non-flammable.
  6. Nov 25, 2019 at 8:14 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    Just to be clear. Argon does NOT = flammable.
    Argon is an inert gas. Same as CO2.
    You probably cannot get it filled with CO2, but you can probably exchange it. As long as it is still in date (10 year certification stamped on the bottle), you can probably exchange it at your local welding supply.
  7. Nov 25, 2019 at 10:10 AM
    JohnLakeman
    My bad...you're right. Argon is used as a shielding gas for tig and mig welding. I must have been thinking of that other a-gas...acetylene.
    In any event, OP should be aware...3000 psi mishandled will be extremely dangerous. The reason OSHA has strict rules regarding the storage of compressed gas cylinders is if one falls over, and the cylinder valve is broken off, the cylinder becomes a soda bottle projectile.
  8. Nov 25, 2019 at 10:13 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That's why it possibly could be redone as CO2. Tank pressure for that is 8-900, still dangerous but far under what's required for argon.
    The exchange is still probably the easiest route though.
    JohnLakeman likes this.
  9. Nov 25, 2019 at 11:08 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    eh, just point the bottle towards the rear, when it hits a rock, you just call it boost.
    TheBeast likes this.
  10. Nov 25, 2019 at 11:21 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    @KevinK can guide you in the right direction.
    I'd go with nitrogen. More bang for your buck.
    khens12, KevinK and rockmup like this.
  11. Nov 25, 2019 at 11:32 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    295k Supercharged 2008
    Swap it out for a CO2 tank at a welding store, it shouldn't cost anything even if they need to recertify the old tank. You can get a cheap regulator and hose and chuck and everything off Amazon for like $60.
  12. Nov 25, 2019 at 3:44 PM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I'll see about trading it in for a CO2
    Its full and I have no use for Argon.
  13. Nov 26, 2019 at 5:22 AM
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    Since it’s argon, it should already have the CGA580 valve which is used for inert gasses like N2, not liquid like CO2.
    Just ask your local welding supply to release the argon and fill it with N2. They can slap a sticker on it to indicate gas type.
    we use N2 on our truck because we also pressurize our water system with it, and N2 doesn’t go into solution as readily as CO2. A soda water shower would be quite invigorating, but not what we wanted. N2 can also be used to fill shocks, inflate tires and run air tools, so it’s a little more useful than CO2. And since it’s a gas and not a liquid, you can mount the bottle in any orientation without having to change dipper tubes or anything like in CO2 tanks (in CO2 the gas is at the top of the bottle and liquid at the bottom, so you either have to stand the bottle vertically all the time, or have a dip tube installed to allow you to mount it on its side or at an angle).
    it costs about $20 to fill and lasts us 3-4 trips of pressuring the water and airing up 37s from 18psi to 37psi.
    Bottle mounted on the right
  14. Nov 26, 2019 at 5:52 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Trade it for N2. N2 is also stable unlike CO2 that changes with the temperature
  15. Nov 26, 2019 at 6:30 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Weld supply company more than likely is not set up to purge the argon out. You would have to send it off, and more than likely get it recertified. Better off selling bottle of argon to a private company or some welding hobbyists. Take the money and buy a new bottle. :cool:
  16. Nov 26, 2019 at 7:32 AM
    bradleykd
    Brad
    Kentucky
    2016 Limited-BLACK
    Perfect! Use it as is!
    https://www.independent.co.uk/news/...eact-thats-why-industry-loves-it-1449740.html
    When it is empty, trade it for a Nitrogen bottle or have the supplier fill it with nitrogen.
  17. Nov 26, 2019 at 8:13 AM
    FrenchToasty The Desert rat, 6 lug enthusiast
    The SoAz
    None
    It actually is affected by temperatures like CO2 just not as bad, and for it to truly do any good, the tire would have to be in a vacuum to remove all the air to be 100% nitrogen. I still use nitrogen to air my tires because it’s fast and accessible to me, but don’t buy into that hype that it doesn’t change pressure
  18. Nov 26, 2019 at 8:38 AM
    rockmup
    rockmup New Member
    Todd
    I didn't say anything about what it does in a tire. I have a shop full of N2 cylinders and I use plain old compressed air
  19. Nov 26, 2019 at 9:01 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    You don't have to have a tire in a vacuum to remove air. You just need to purge it. Its already sitting at about 78% anyway. Purity is not a concern so 3 times would get you close enough. Drain current air till almost empty, fill to about 15psi, drain again till almost empty, repeat 2 more times. Not that anyone would need/want to do that anyway...especially on a trail.
    A shop will not change gas service on a bottle.
    Yes No2 and Ar use a CGA 580 fitting. You should not change these fittings.....there is a reason the CGA was formed and fittings were assigned.
    I doubt a shop will give you any kind of credit for that bottle full. Its going back to the plant and going to get drained before they refill it. So anything in the bottle will just be returned to the atmosphere.
    You could use AR for what you want since you have it...but when its empty swap that bottle for a N2 bottle. You will already have the regulator anyway. C02 regulators have different seals in them because it is more corrosive. Or at least should.
    I would never use CO2 in my tires. Yes I know people do and companies make products for them. Just my .02
    Lastly make sure you leave the collar or protective cap on it so it doesn't turn into a projectile like mentioned above.
  20. Nov 26, 2019 at 9:33 AM
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    I know how they can become a rocket. The metal cap is on. lol
    Ill put it up for sale or trade...
  21. Nov 26, 2019 at 9:49 AM
    bradleykd
    Brad
    Kentucky
    2016 Limited-BLACK
    I'm missing why you wouldn't use it for your intended purpose.
    You will need a regulator, but that is no big deal, then, when you are out of argon, exchange it at the local welding shop for a nitrogen bottle. I've changed bottle types for free several times. You'll be able to use the regulator you bought for the nitrogen bottle.
    Juanjoolio007 likes this.
  22. Nov 26, 2019 at 10:52 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Off topic but kind of on topic.
    It's interesting to see how old some of the cylinders are, we use CO2 in our pool at work and I regularly see ones that are 60+ years old. So far the oldest stamp I've seen is 1913.
  23. Nov 26, 2019 at 11:00 AM
    Juanjoolio007
    Oregon
    I use to play that game while doing my annual inspections on customers that had cylinder backups. I was a Cryo Field Service Tech for about 3 years before this job. I found a cylinder in Oxygen service at a hospital from around the same time. I think it was 1908. I used to have a picture of it. It was hard to read because it had stamps all over the neck.
  24. Nov 26, 2019 at 11:03 AM
    Juanjoolio007
    Oregon
    This is what I was saying. The only down side is that Ar is heavier then N2. But that’s probably not relevant for this purpose. But if he can sell it then I guess he could start with which ever gas he chooses.
  25. Dec 2, 2019 at 9:41 PM
    Aerindel
    Aerindel New Member
    Montana
    I use a 20 year old 2200 PSI SCBA tank for this purpose.
  26. Dec 7, 2019 at 2:37 PM
    KevinK
    Tundras to Sedona
    I’ve been looking at some of the carbon fiber ones and wondering if I can adapt a CGA580 valve onto it for N2. Any idea?
  27. Dec 7, 2019 at 3:17 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Couldn't a old aluminum scuba tank work. Not sure about a regulator, but a 80 CF under 3,000 PSI is a lot of air. And can be filled at a scuba shop for a couple bucks.
  28. Dec 8, 2019 at 2:20 PM
    Aerindel
    Aerindel New Member
    Montana
    Hmm, I'm not sure, are NGT valves conical? SCBAs are straight pitch.
  29. Dec 9, 2019 at 6:17 PM
    KevinK
    Tundras to Sedona
  30. Dec 9, 2019 at 7:24 PM
    Aerindel
    Aerindel New Member
    Montana
    I don't think so. SCBA valves are a straight pitch with on O ring seal at the top. The NGT looks like a conical pipe thread style.
    But SCBA valves are not very expensive. The trick is an adapter from the SCBA male threads to NIP or similar for your hose and fitting, those are available, mostly for paint ballers who use SCBA tanks for air fairly often.
    You will also need your own compressor or an 'in' with the local firedepartment as dive shops will not refill tanks that are not certified or expired.
    This is all doable, just letting you know what is involved.
    I really like using tanks instead of compressors but I work for the Fire department and got dozens of free SCBA tanks when they expired and am able to use the departments 4500 PSI compressor to fill them when needed.
