Adding USB outlet to cig lighter, wire identification help
Discussion in '1st Gen Tundras (2000-2006)' started by DennisCastro, Dec 8, 2019.
  1. Dec 8, 2019 at 3:10 PM
    DennisCastro
    DennisCastro [OP] New Member
    Ian
    2005 Access Cab TRD
    First post here. just got a 2005 TRD Access cab v8 with 89,000 miles. sold my 03 4runner.
    anyway, id like to wire a usb outlet into my cig lighter. one like this.
    https://www.amazon.com/Charger-Waterproof-Cigarette-Voltmeter-Motorcycle/dp/B07DGNQNLR
    i have done this on other cars, but most only have 2 wires going to the socket. when i removed this one, it has 2 connectors with 4 wires total.
    first question, which 2 wires am i to use for the USB outlet
    second question, i checked the fuse diagram and it appears 32 is the fuse for the cig lighter and other items, do i need to add an in line fuse for extra precaution? i recently completed this on my 04 wrangler, and it had its own separate fuse on the panel just for the cig lighter. some pictures attached.
    the smaller connector was going to a light on the socket? has white with green and solid green wires
    the larger connector was going directly into the back of the lighter, with solid white and solid gray(maybe black?) wires
  2. Dec 8, 2019 at 3:21 PM
    Professional Hand Model
    Fred
    Hand Protectors
    I tried to change that bulb on the cig lighter and gave up. Figured I would have to mangle the entire assy just for a light bulb conversion to LED so I gave up on it.
    How did you get the thing out of there?
    I have no answers for you on the electrical side.
  3. Dec 8, 2019 at 4:00 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Welcome
    grey HOT/white GND
    If you do indeed get the one you linked to, the description suggests/comments about a few things and personally will not dispute what they are recommending. OR you could tap into the gray with the wire they supply with 10amp fuse....double protection.
  4. Dec 8, 2019 at 4:56 PM
    DennisCastro
    Ian
    2005 Access Cab TRD
    so just leave the other connector alone (with the green wires), gray to positive with in line fuse, white to ground, and good to go.
    thanks much! and you asked how i removed it? did you see the area around the socket......
    seth419 likes this.
  5. Dec 8, 2019 at 5:16 PM
    Fred
    Hand Protectors
    Thanks. Thats what I was trying to avoid. Post up some finish pics.
  6. Dec 8, 2019 at 5:22 PM
    DennisCastro
    Ian
    2005 Access Cab TRD
    this video helps. ill post some pictures when i finish up as well. this video helps with seeing how the outside bezel clips in. remove your ashtray as well, helps get behind and remove the connectors.
    https://www.youtube.com/watch?v=1oL1JD9zrZM
  7. Dec 8, 2019 at 6:19 PM
    FirstGenVol Brake Czar
    2002 AC
    :rofl::rofl::rofl:
    That is something I would have done. I tried to replace the bulb in the ash tray and completely destroyed it.
  8. Dec 9, 2019 at 5:24 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Did you consider on of these:
  9. Dec 9, 2019 at 6:14 AM
    Fred
    Hand Protectors
    Because of that video @DennisCastro put up, I now think I have the missing clue to install a new LED bulb for the cig ring. That bulb change dogged me last year to the point of having to let it go. Nobody here had any idea, but it looks like its a counter-clockwise simple twist!
    That area is so tight working from the ashtray and I did not want to remove the lighter so going to give it a revisit today!
  10. Dec 9, 2019 at 6:28 AM
    speedtre
    speedtre New Member
    Inland Northwest
    People replacing the cigarette lighter with a permanent USB port has me scratching my head as to why one would do that (and lose access to a universal 12V power source) when you can use on of the plugs above? They are unobtrusive and work great. Is there a functional reason I'm missing (quite possible) or is it just for aesthetic reasons?
    I'm using one of these for functional reasons until I get my new head unit in (GA is a phone hands free state). It works great and has two USB ports. The cigarette lighter receptacle is the best place for it because the 12V sockets near the passengers feet would not be a great placement for the microphone.
    https://www.amazon.com/gp/product/B07GJ7DHMP/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Wammer and FirstGenVol like this.
  11. Dec 9, 2019 at 6:40 AM
    2002 AC
    This one can be used in the cigarette lighter port? I've never even looked behind the pop out lighter.
  12. Dec 9, 2019 at 6:54 AM
    Fred
    Hand Protectors
    Thats the best device recco I’ve seen that tics all the boxes outside of buying a new stereo. Thanks for this.
    flyfisher and speedtre[QUOTED] like this.
  13. Dec 9, 2019 at 6:58 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Works well too...nobody ever complains about not being able to hear me when I'm using it.
  14. Dec 9, 2019 at 7:11 AM
    2002 AC
    That's amazing. I didn't know something like this existed. I want it purely for the USB charging ports but it would be great for someone needing Bluetooth capability.
    speedtre[QUOTED] likes this.
  15. Dec 9, 2019 at 7:12 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    In my experience with FM transmitters they can either work very well or don't. The key factor in both is how crowded the FM spectrum is wherever you happen to be driving.
  16. Dec 9, 2019 at 7:16 AM
    speedtre
    speedtre New Member
    Inland Northwest
    This is true...I live in an urban environment and I had to try a few different ones before I got one that worked well...then that signal got a station and I had to change it again, but no issues finding a new signal that worked great.
  17. Dec 9, 2019 at 7:46 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I have this exact thing and it works great. The lights aren't really bright but it was cheap and easy.
    speedtre likes this.
  18. Dec 9, 2019 at 10:06 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Yes, I installed the same one and just left the other connector. The power wire will do the trick for charging and illuminating your battery voltage. I also broke the black bezel getting that thing off and had to glue it back together!!! Guess I should have been a little more patient getting that thing out!
  19. Dec 9, 2019 at 10:06 AM
    DennisCastro
    Ian
    2005 Access Cab TRD
    for my truck, the cig lighter wasnt working, so i was having to replace it anyway. And, for a truck that family and friends will borrow, i like always knowing i have 2 hardwired usb ports. i have numerous chargers like the one above, but they always go missing. i have installed the hardwired ones in numerous cars and prefer them, if install isnt a huge pain or the outlet isnt working.
  20. Dec 9, 2019 at 10:09 AM
    DennisCastro
    Ian
    2005 Access Cab TRD
    i have this same device in my 2004 TJ, and it works great. ill probably buy another for the tundra. In my Tundra, i have 3 12v ports in the front, 2 below the hvac, and 1 for the cig lighter, so losing the cig lighter still leaves me 2. i would not have done this if I only had 1 total.
  21. Dec 9, 2019 at 10:10 AM
    Fred
    Hand Protectors
    I discovered black trim bezel was broken this past year. Evidently, it was broken back in 2003 when the XM installers tapped into this region. They used sneaky black putty to fix it. I guess even the pros have a hard time with this piece.
    seth419[QUOTED] likes this.
  22. Dec 9, 2019 at 10:16 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Out of curiosity do the AC trucks have the rear power outlet too? There's one on the lower right hand side of the console in the back seat on the DC.
    That was where I ended up plugging in my Sirius tuner to leave the front 3 open.
  23. Dec 9, 2019 at 10:20 AM
    DennisCastro
    Ian
    2005 Access Cab TRD
    i dont think so.
  24. Dec 9, 2019 at 10:34 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I hard wired for aesthetics and there are also two 12-volt outlets on the passenger side.
    daveeasa likes this.
  25. Dec 9, 2019 at 11:10 AM
    DennisCastro
    Ian
    2005 Access Cab TRD
    mind sharing a picture of yours?
  26. Dec 9, 2019 at 9:14 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    Ducarius likes this.
  27. Dec 10, 2019 at 12:43 PM
    DennisCastro
    Ian
    2005 Access Cab TRD
    looks great!
  28. Dec 10, 2019 at 3:40 PM
    Fred
    Hand Protectors
    This is a hand models equivalent to a NFL running backs fully torn ACL. Out for the season!
    speedtre and NewImprovedRon like this.
  29. Dec 10, 2019 at 5:51 PM
    DennisCastro
    Ian
    2005 Access Cab TRD
    man that one realllllllly hurt. stretch fit ac belt on a friends mazda. had the plugs out and the crank turned really easily and my thumb got struck. awful
  30. Jan 21, 2020 at 6:02 AM
    DennisCastro
    Ian
    2005 Access Cab TRD
    finally finished it up a week or 2 ago. final product looks awesome, and i did straighten the outlet out so its level. if i had to do this again, i would not. im happy how it turned out, but when you cut the 2 wires to hook into the back of outlet, there is no slack and it was a huge pain to entend them.
    Ducarius and bmf4069 like this.
