Hard starting in morning
Discussion in '2.5 Gen Tundras (2014-2021)' started by cherk76, Dec 4, 2019.
  1. Dec 4, 2019 at 2:26 PM
    cherk76
    cherk76 [OP] New Member
    Rich
    2015 Tundra
    Hello.
    I have a 2015 Tundra 5.7. In the morning especially when cold outside it struggles to start. I have recently put in a new battery and all new plugs. There are no codes coming up. There is no issue when driving. I just towed my camper 800 miles round trip with no issues. I am thinking it may be a fuel filter or fuel injectors. Any ideas on diagnosing the issue? Thanks.
  2. Dec 4, 2019 at 2:40 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Maybe try to prime it a few times before starting it on a cold morning.:notsure: That can give you an idea if the fuel pressure is too low on start up. Turn the key to the on position a few times and let the fuel pump run.
    TheBeast likes this.
  3. Dec 4, 2019 at 2:41 PM
    HappyGilmore
    Trent
    Lakewood CA
    and welcome to the forum!
  4. Dec 4, 2019 at 3:42 PM
    Did you test the new battery?
  5. Dec 4, 2019 at 6:14 PM
    HappyGilmore
    Trent
    Lakewood CA
    Can you clarify hard start? Is it long crank, sputter, start? Or is it slow, labored cranking and then it catches?
  6. Dec 4, 2019 at 6:30 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    I wake up started. Makes it tough to pee out of the gate though. Have your battery checked.
    Tundyfundy and T-Rex266 like this.
  7. Jan 3, 2020 at 7:34 AM
    cherk76
    Rich
    2015 Tundra
    So broke down and took it in to Toyota. Turns out there is a bulletin on the fuel pump. The warranty on the fuel pump was extended to 96 months or 95k miles. As I am under both Toyota is covering the replacement.
    Thank you all for the helpful responses.
  8. Jan 3, 2020 at 8:03 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    Is this an issue with flex fuel engines only or am I thinking of something else?
